cohen Posted October 10, 2006 Share Posted October 10, 2006 extracted...this sounds like an interesting one. do I even want to ask how I would do it....would it even be worth it? Link to comment Share on other sites More sharing options...
RedPath88 Posted October 10, 2006 Share Posted October 10, 2006 They make stud/bolt extraction kits. Basically you just hit the broken bolt dead center with a punch. Then drill a hole in the middle of the broken bolt and follow that with the stud extractor. Which is something like a screw with reverse threads... only a whole lot stronger. You turn it left to drive it into the hole you drilled in the broken bolt. After it gets deep enough into the bolt to get a good grip on it the bolt starts to turn out. Unless it is so stuck that it will not move. In that case you need to drill it out completely and either retread the hole to a larger size and use larger bolts or after re threading it, install a Helicoil and use the original size bolts. Link to comment Share on other sites More sharing options...
cohen Posted October 10, 2006 Share Posted October 10, 2006 and just ask for PB blaster? Link to comment Share on other sites More sharing options...
RedPath88 Posted October 10, 2006 Share Posted October 10, 2006 Yeah a couple auto parts stores up here carry it, Schucks is one that does. They are known as Checker Auto, Kragen Auto or Murray's Discount Auto in other area's Link to comment Share on other sites More sharing options...
cohen Posted October 13, 2006 Share Posted October 13, 2006 so after 3 days of spraying constantly and almost using the whole can. I break off the 2 bolt heads I try to get off...next option. Link to comment Share on other sites More sharing options...
RedPath88 Posted October 13, 2006 Share Posted October 13, 2006 so after 3 days of spraying constantly and almost using the whole can. I break off the 2 bolt heads I try to get off...next option. Well, then I guess I will refer you to a prior post They make stud/bolt extraction kits. Basically you just hit the broken bolt dead center with a punch. Then drill a hole in the middle of the broken bolt and follow that with the stud extractor. Which is something like a screw with reverse threads... only a whole lot stronger. You turn it left to drive it into the hole you drilled in the broken bolt. After it gets deep enough into the bolt to get a good grip on it the bolt starts to turn out. Unless it is so stuck that it will not move. In that case you need to drill it out completely and either retread the hole to a larger size and use larger bolts or after re threading it, install a Helicoil and use the original size bolts. Link to comment Share on other sites More sharing options...
88pathoffroad Posted October 14, 2006 Author Share Posted October 14, 2006 Re-drill and tap the holes to fit some 7/16 head bolts. That's what I had to do. Link to comment Share on other sites More sharing options...
slimer Posted May 4, 2007 Share Posted May 4, 2007 The Rancho that was installed when I bought my car has an issue. The bracket that holds it into place has broken. When I get a new one (Rancho Part #RS130007), do I need to jack it up or do anything special to make it fit? Link to comment Share on other sites More sharing options...
88pathoffroad Posted May 4, 2007 Author Share Posted May 4, 2007 Nope, unbolt the old one and replace it. Link to comment Share on other sites More sharing options...
slimer Posted May 5, 2007 Share Posted May 5, 2007 Beautiful. Thanks. Link to comment Share on other sites More sharing options...
Nismojunky Posted July 19, 2008 Share Posted July 19, 2008 hpw do you install the rancho one? Link to comment Share on other sites More sharing options...
nunya Posted July 19, 2008 Share Posted July 19, 2008 Most Pathfinders came without a steering stabilizer. If you want to mount one on your Pathy, this information and thread is for you. A thread already exists discussing installation of the Rancho steering stablizer on a Pathfinder. It can be found here: http://www.nissanpathfinders.net/forum/index.php?showtopic=1044 The Rancho setup mounts to the passenger's side frame, like this: From post #1 Link to comment Share on other sites More sharing options...
Kittamaru Posted August 19, 2008 Share Posted August 19, 2008 What's the real difference? Link to comment Share on other sites More sharing options...
MikeV Posted August 20, 2008 Share Posted August 20, 2008 What's the real difference? Rancho is much more purty! and a little beefier Link to comment Share on other sites More sharing options...
headpeace Posted December 12, 2008 Share Posted December 12, 2008 The more I look at the pictures on here I think, how hard would it be to fab something for the "mounting"? Q for those of you who have installed one of these Link to comment Share on other sites More sharing options...
Precise1 Posted December 12, 2008 Share Posted December 12, 2008 Not hard at all for a machinist/fab guy. I have 2 brand new Pro Comp 1000 stabilizers in the garage. 1 is going on the new truck once I replace the CL with a hoohaa version, the other will be sold. All that's really needed is a drop bracket, swivel mount or the like. Why do you ask? B BTW, Howdy Headpeas! It's been a while... Link to comment Share on other sites More sharing options...
headpeace Posted December 12, 2008 Share Posted December 12, 2008 (edited) Well I want to install one but sheesh the price for the shock is around $30 but when I try to find anything with "everything included" the price is around $60 - $75 I just thought if I could get some bar stock and cut/drill something that it would be cheaper?? But then again I'm not a big welder/fabber guy. Thought I might be able to save some $$ And yes my friend it has, good to see your back a bit more now, I noticed a while there where you were seldom on. I just check in once in a while much more than I post anymore. And you got a new PF? You wanna sell one of those soon?? Edited December 12, 2008 by headpeace Link to comment Share on other sites More sharing options...
audiwhore Posted December 17, 2008 Share Posted December 17, 2008 Does anyone know where to find the OE (or aftermarket) pin bracket that bolts to the frame other than the dealer? Is there a place online that sells it? Link to comment Share on other sites More sharing options...
5523Pathfinder Posted December 17, 2008 Share Posted December 17, 2008 AC has several options.. https://www.4x4parts.com/catalog/index.php?cPath=435_430_429 You could aslo try Ebay maybe.... Link to comment Share on other sites More sharing options...
beastpath Posted December 17, 2008 Share Posted December 17, 2008 Does anyone know where to find the OE (or aftermarket) pin bracket that bolts to the frame other than the dealer? Is there a place online that sells it? IIRC Rockauto has the pin and the monroe OE shock Link to comment Share on other sites More sharing options...
Precise1 Posted December 18, 2008 Share Posted December 18, 2008 And yes my friend it has, good to see your back a bit more now, I noticed a while there where you were seldom on. I just check in once in a while much more than I post anymore. And you got a new PF? You wanna sell one of those soon?? Yeah, I took a break there for a bit. Life got too distracting... Don't be too much of a stranger though!! Yeah, I bought a stock 95xe with 96k miles on it for $3300. A bunch of new parts, vehicle is about 95% condition. I'm pretty happy with it and have a bunch of the usual mods slated for spring (BL, SL, headers, exhaust, etc). The old 95 is going to be parted out, the front frame damage makes it junk and I couldn't justify a SAS. If I had more time/money/room I'd do it as a trail rig, but that's not the case today. I'm off for the next two weeks so I'll dig in the garage then. Yes, I'll sell you one but let me see what kind of brackets I need to make for you first. Yes, rock auto has a stabilizer bracket ( RANCHO Part # RS5533) for $23.79 but no picture so I don't know what to expect... B Link to comment Share on other sites More sharing options...
headpeace Posted December 19, 2008 Share Posted December 19, 2008 Sounds like you got a good deal B Glad to hear it. If you find a SS let me know bud Link to comment Share on other sites More sharing options...
adamzan Posted January 17, 2009 Share Posted January 17, 2009 Yes, rock auto has a stabilizer bracket ( RANCHO Part # RS5533) for $23.79 but no picture so I don't know what to expect... B I got my stock one from the dealer for 16 dollars. And I got the monroe shock from rockauto for 29.99. But beware, it didn't come with a metal shield like 88's pic OR a Boot Link to comment Share on other sites More sharing options...
Precise1 Posted January 17, 2009 Share Posted January 17, 2009 Boots hold dirt in as well as they hold it out. I don't have any boots on my shocks... B Link to comment Share on other sites More sharing options...
adamzan Posted February 14, 2009 Share Posted February 14, 2009 up here we have all the salt and crap as well. I think a well sealed boot would be a good idea... Link to comment Share on other sites More sharing options...
