slimer
Everything posted by slimer
I was using chains. Its over. Steve's Pathy 5, Builder's Hydraulic Lifter 4, Bushes 0
So are you saying that I should back it up?
So a few weeks ago, I ripped 5 cypress bushes out of the front bed. Wrapped some chains around the stumps, soaked the ground, slapped it into 4wd and they went bye bye. Today, I tried the same thing to these little bushes and the would not budge. I blame the semi drought that we're having.
Maybe because the front is the same as the hardbody?
Is there anyway to make the DOHC heads fit?
I never tried it, its never been wired. PM me your addy and its yours. I have to go to UPS tomorrow anyway. IIRC I think the directions for wiring is there too.
I found an old O2 sensor in my garage the other day if someone wants it. I won't be needing it.
Seat Diffence Between My Se And Xe(both 95)
slimer replied to MikeV's topic in 90-95 WD21 Pathfinders
My frame is solid, but I think I may visit the JYs next week to look for some new seats. Can I bolt the R50's in? I drove 4 hours yesterday and I'm sore (maybe its because I'm working out again.) -
Did you make that bracket yourself?
Has anyone done the Intake Box hack, where they increase the amount of flow through a K&N drop in with cutting holes in the lower portion of the air box?
I didn't even know there were better seats out there. I may have a quest out there. -
I thought either that or the fuel pump. How many miles on it?
There is a check box that says "Remember these settings"
I have one that I've never used. I bought it for my old Max. $25 shipped. It doesn't have the bypass for when its too cold, but I'm assuming it works.
I had a faulty ignition switch on my Maxima. It would start when you jumped it, but would act like you're describing the rest of the time. It took me less than 30 minutes to do and never had a problem since. After I took it out, there was grease blocking the connection.
What do they say? Yeah, step 4 could have been eliminated, but working with cars always needs to be interesting.
Beautiful. Thanks.
It just seemed like it would be a tight fit to go that way.
The Rancho that was installed when I bought my car has an issue. The bracket that holds it into place has broken. When I get a new one (Rancho Part #RS130007), do I need to jack it up or do anything special to make it fit?
I know that I'm bumping an old thread, but that design is by far the worst place for cupholders.
Going through the font end wasn't too bad. The headlights tilt out nicely.
I guess I have massive hands.
So I'm a new member here, I have a few suspension mods, but thats not why I'm posting. I just got done with putting in new headlamps and it is such a PITA. Is there an easier way? 1. Took out the corner lights 2. Popped the tabs and unscrewed the front grille 3. Unscrewed the Headlights 4. Lost some of the screws and then found them again. 5. Exchanged the Headlamps 6. Tried to figure out how the tabs popped back in and figured it out. 7. Put everything back together. I know in my other Nissans you just unscrewed the harness and replaced the lamp.
