Precise1
Moderator-
207
Everything posted by Precise1
Sorry, a bit late to the show, but here is a link to everything you have asked for. http://www.nissanpathfinders.net/forum/index.php?showtopic=24503&view=&hl=tranny%20filter&fromsearch=1 This is part of the reason I didn't use the ECU input signal, also for redundancy... Dr Bill, as RJS so well said, don't over think this or try to short cut it. It's not too hard to do cleanly and properly where there will be no problems, simply benefit. The 'wiring a sensor onto a tube' is so hokey it makes me cringe; I don't recommend it at all. Do it right, do it once and move on... B
Same idea, try an engine flush. What weight oil are you running with what mileage motor? May be time to go thicker... B
MY1PATH just did an hidden snorkel that is exactly what you are asking about. Pretty cool idea, really. Let me know if you can't find it. B
Good decision JJ, don't muck around and get the 3" kit. The truck looks great like that, too bad you can't turn... I have a set of 235/75/15 Michelin LTX on stock chromies I'll give you a deal on... B
'95 XE - V6 Driver's Side Door Lock Broken
Precise1 replied to DoctorBill's topic in 90-95 WD21 Pathfinders
Dr Bill, did you not download the FSM in PDF for your vehicle?? It is free... B -
You have dual cats?? Pictures please... I have the Delta Flow 60, but no good way of recording it. See the other thread for a discription... B
I have the Thorley headers, 2.25 pipe into a 2" magnaflow cat (all I could get in CA), back to 2.25 into a Delta 60 Flowmaster. It sounds good at idle/low end, a bit ricey mid range and downright raspy 4500rpm+. Not exactly sweet music, but is seems to have some bottom end and likes to rev with power so I'm not messing with it for a long time. There are for more important things to do, one of which will be a custom snorkel... B
Good luck with the shopping. I'm sure you know what you are doing, but don't be afraid to walk away if it doesn't seem like a good deal, or at least sleep on it. B
I am glad she is ok, that is all that matters although I regret the end of such a good looking pathy... We bought an R50 for my wife to commute in for exactly that safety reason, there are too many big trucks around here to drive 60 miles a day in a Honda Civic. I do have to ask, how is it she left the road when it seems to be open, straight without cross traffic? B
Well my melted marshmallow, $4k for a 100k R50 isn't bad at all. I happily paid the same for 99 with 150k. The mileage isn't a big deal as it is our 3rd car and will get low mileage, but they should run reliably for about 250k. As for light off roading, that they can do, but read up, it's all here... B
Does yous knows what the codes mean?? Out of the 98 FSM... I'm dealing with code PO0301 myself, but just started so I don't have specific help other than I read some threads that were the general PO0300, not a specific cylinder. One was a worn out dizzy shaft, another was knock sensor related and I don't remember the rest. Did you search?? B
Damn, no reply as to the fix. I hate that... The wife's 1999 R50 is giving me a PO0301 misfire on cyl #1 code. Going through the forum via search first. I haven't checked anything yet because I worked 12 hours today and don't have it in me. Onward with the searching... B
R200A front and HB233B rear IIRC?? Better wait for confirmation, I can never remember these things... B
That's about the same price I was quoted by local tire shops too. The Pacer and the Crager rims are identical, made at the same plant, and if you cross reference some web sites, even have the same manufacturers part number. That's why the make logo is on the center cap... Simple FYI, I bought 5 Crager Soft 8 rims on sale at Summit Racing. Total shipped to my front door was $211.95 B
Just realized this was in TOTM so i moved it to the General section... Yes, it can and I have heard this also. An alarm guy told me to get a dual level alarm because some thieves tap on the glass and if there is no warning chirp they know there isn't a good alarm installed, if none at all. A blinking alarm light might stop involved thievery, but probably not a smash and grab like someone did for my wifes purse last year. It sucks, but but some people are opportunistic scum who think they have a right to damage/steal. I can not sufficiently express my disgust for such cretin. B
These are the two most effective things you can do. Personally, I don't put any expensive or high powered audio in any of my vehicles, just a decent deck and aftermarket speakers that fit into the stock locations. It just isn't worth the hassle and sounds plenty good anyway. 800 watts in a broom closet is way overkill... Sorry to hear this happened, but chalk it up to life experience. B
That is really odd. I can't think of any reason for that other than the steering box is putting a large load on the motor and the ECU is overcompensating. Han you hear or feel anything abnormal when it does this? It makes sense that it is only then you are idling and stationary (I'm assuming) because the wheels turn much easier when the truck is rolling... B
Back to the subject please... (LOL@Nunya and crew) B
Well, I'm not sure what you are used to, but yes, many of us drive WD21s daily. 1) Not the best for gas mileage but hard to best for over all reliability and ability. 2) Revving it should work fine, but you won't be passing car at 75 mph at will. 3) Some wind noise but not bad. Street tires and sock/quiet exhaust will be the biggest noise factors. 4) http://www.nissanpathfinders.net/forum/index.php?showtopic=20670 5) http://www.nissanpathfinders.net/forum/index.php?showtopic=19042 Just buy one and get a taste of how it all started... B
6 hole on 5.5" bolt pattern. Backspacing may vary. Older Chebby rims can fit also... B
.....my pathy is startin to blow blue smoke.....
Precise1 replied to Kyle94's topic in General Forums
How many miles and what weight oil are you running? B -
Foot well lighting... Flashlight. Seriously though, the 94-95 dual map light rear view mirror is an easy install and works quite well. Someone bought mine to do the swap, beastpath I think?? Anyway it is a good upgrade and probably all you need, especially if you upgrade to LEDs like Kiwipete did. He has a write up IIRC, maybe in his Members Rides thread? B
Exactly, all 2wd... B
There are two suspension threads here, there should be info... http://npora.ipbhost.com//index.php?showforum=67 Otherwise our questionable search function may be of assistance. B
Yes, I used a light film of RTV, Permatex grey I believe but any of it will work for the waterpump IIRC. Read the tube, I think the blue specifies that it is antifreeze resistant. Same with the thermostat. Make sure to put the bleed hole up... I just did the timing belt last year and replaced everything also as I don't want to go into it again for the full 100k mile interval. I changed the crank seal, cam seals thermostat, bypass hose, timing belt, tensioner, spring, waterpump, both radiator hoses, coolant and all fan belts. I kept all spares of course... The problem with not replacing the bypass hose or waterpump is that if it leaks on the timing belt (almost impossible to remove without spilling a lot) the belt needs replacing as the antifreeze degrades the belt... B
