tmoore4512
Everything posted by tmoore4512
  1. Looked at several transmissions bur none were in any better shape than mine. Im dreading it but I may just take a wack at rebuilding her. Ive done quite a few domestic transmissions but not an import...yet. maybe I can score a working one before it goes completely out... Sent from my old brick of a phone!
  2. Yes... good news. All of the maintenance that hasnt been done by previous owners and not knowing what has been done or hasnt always makes things difficult. Sent from my old brick of a phone!
  3. Wow bro lookin good! Sent from my old brick of a phone!
  4. In my experience with winches looking at the type of motor is important as well. The older HF winches used PM (permanent magnet) motors and the new Badlands winches use a series wound motor. There is pro's an cons to both, but the series wound is a MUCH better option. With that said, I still have an 8k PM HF winch that is bad to the bone. Has saved my tail many times. It just gets hot pretty quick and needs to cool down in between pulls. I wouldn't hesitate to buy another HF winch.
  5. Mine came yesterday. The only concern I have is that the gauges won't have enough to grab on to when installed... But I don't have any to try out just yet. I'm not complaining, I'm actually pretty excited about this. Thanks again Adam!!!
  6. Just saw your updated thread and gotta say its wicked cool. Good job bra.
  7. Can I take a 2wd trans from a 98 pathy and remove the tail shaft and put ony T case on her? Site unseen, maybe someone has been here before...
    1. Tungsten
      Tungsten
      I am going to say yes because the T-case is detachable and the transmission is the same.
    2. tmoore4512
      tmoore4512
      Hmmm interesting
  8. Sweet. So the ball rolls farther... I had actually forgotten. About this, heheh... I'm getting stoked again.
  9. So this is an old thread, but what are the updates if any bra? Still good to go? I am about to do the same to mine and hope to goodness that I did not lose my tranny completely...
  10. So after 337K miles, this trans has lost reverse. This sucks.
    1. Show previous comments  2 more
    2. Towncivilian
      Towncivilian
      Yeah that ain't bad, that transmission doesn't owe you anything at that mileage... I take it you've kept up with maintenance given the surprising mileage. Get an HD version of the trans as Tungsten said unless you want a manual swap of course.
    3. Harbinger
      Harbinger
      Mine died after 163k. :) Seems to be a rash of people losing reverse lately though.
    4. adamzan
      adamzan
      That is a good amount of mileage, even most domestic transmissions don't last that long.
  11. Didyou pull the yoke off and check the splines on the pinion already? My lockright has 8 springs too... Weird that yours has only 4
  12. Brother, almost sounds like the splines on either the drive shaft (if it is a slip yoke style) or on the pinion gear are stripped... Is the T case going into gear as it should? Maybe something slipping in the case as well but the drive shaft is what I am leaning towards...
  13. Hey bud, just saw your post. I would ask him some more questions... Inquire as to what has been done to the top end, as about timing belt service, and check the mileage... Looking at little things will tell you alot about how the previous owner drove and cared for it. IE pedals, boots on the CV axles and tie rod ends, look for cupping or excessive wear on front tires, is the steering gear box leaking, etc. I know its a vague answer to a blanket of other questions...
  14. As usual, it looks great Ryan. Did you make the scoop functional or is it just for looks?
  15. If you have kids like me... Then they will just pull on em and they won't be aimed where you need em when you need em anyway!! Haha
  16. Yikes, sounds like a mess. I was going to suggest pulling distributor and inspecting the gear but if the belt isn't moving....
  17. I have the factory rack from when I did my X swap. If you strike out I can ship it to you, its complete... Minus threadserts... But you wouldn't want to reuse those anyway....
  18. After 4 years I finally installed the new lift supports on the back glass... Why did it take so long? Well I just found them... Was not going to buy another set when I knew good and well I had the new ones somewhere. Turns out here were in my rolling tool box.... I found a huge amount of missing items in it when I started cleaning it out.... Bought some new floor mats, mine had huge holes in em. Tinkered with rear lighting, thinking about putting a dual element LED unit in the cargo area with red and white as well as up front....
  19. Yea, they do look good. How do you like em?
  20. No problem, just put an X rack on your truck and then the basket on top....
  21. Looks great! I am curious how many wires I can run behind my A pillar.... hahaha right now I have quite a few on the passenger side... Hey, thank you for going through the time and work it takes to get all the bugs worked out!
