32
Everything posted by Citron
If you have trouble handling the load, try a load equalizing hitch.
Saturn, can't see the pics since your using Photobucket.
So that would make you the Elvis? I always wondered where that name came from. Yours, not Elvis.
Nice that you learned, many people wouldn't. Getting a ticket 15 years ago for reckless driving, which is a felony, cured me. Luckily, I pled it down to careless driving, which is a misdemeanor. Learned the lesson though. Good luck with the body work.
Hey Slartibartfast, I just read your comments on the unicorn article on Jalopnik! Crazy, like meeting a celebrity!
R50 Tire Carrier Mod: Let's settle this!
Citron replied to hawairish's topic in 96-2004 R50 Pathfinders
Yeah, I like their site. I need to get some sheaves with ball bearings for a non pathy project I am working on. -
Check McMaster Carr. They carry all if those kinds of raw material to make the rubber sheet. -
It's a rarity to see anything like that in Gray's harbor.
The new bypass hose?
What year is yours? I have done it on the vg30e. Plug the intake and the exhaust, cap the vaccum line and good to go. You won't see any power or milage gain. It will run just like it did before. The only reason to do it is if the egr is not working correctly and you don't want to buy a new one. Mine was working fine, I did it more for curiosity sake.
Great job! The only thing I would recommend is using heat shrink over the wire solder connection. Since it is already together, electrical tape would work to keep the hot wire from contacting. Maybe you did this already but it's not in the picture. -
Two days to a year +/-. I would repair something that has the ability to leave you stranded before making a trip. It would be a lot easier to fix at home then on the road. At the least, get all the parts needed, so if it does fail on the road, it can be repaired without needing to wait on parts.
1st generation pathfinder starting problems
Citron replied to mrspeedk's topic in 90-95 WD21 Pathfinders
Unless testing was done nothing is eliminated, he is just guessing that the connectors, relays etc are good. If it is truly a problem with the starter, a push button will not help. -
Buy a multimeter. Test the wire that energizes the starter selenoid coil. If there is no power, work your way back until you find power, then you will find the problem. Or start at the other end of the wire and work forward until you find the spot where you lose power. Test at devices and at connectors. -
97 Pathy R50 Dead rear axle. Advise!
Citron replied to Mattmill91's topic in 96-2004 R50 Pathfinders
If they are like domestic rear ends, the rear axle bearings are lubricated by gear oil. As long as you keep clean gear oil and full enough that some can migrate down the axle tubes to the bearings, you should be okay. -
Excellent example of why to do diagnoses before throwing parts at the problem. -
Wiring electric trailer brake controller
Citron replied to colinnwn's topic in 96-2004 R50 Pathfinders
Cold side? Never heard that before. -
That is awesome. It is always fun learning a new skill. I had a pretty steep learning curve to make my bumper. I actually made a lat tower before starting the bumper just to practice welding. I would really like to see your project when it's complete.
Tried taking my Pathfinder for a swim
Citron replied to ubertalldude's topic in 90-95 WD21 Pathfinders
Time to get rid of the carpet and relocate the ecu. -
Do you actually need new innards? You should be able to get away with installing a new right axle shaft, unless the bearing failure damaged other things besides the shaft. -
I have read that the Japanese brands are more popular in the PNW then other parts of the country. Explains why we have so many options in the jy compared to other places. It would be a fun car, I would much rather have one of these then a Vette or some muscle car.
Instant too.
