Citron
Everything posted by Citron
  1. The ones I bought came with new metal cups.
  2. The other possibility is the new plug wire is leaking and when it is in the plug well it is arcing over to the head instead of sparking the plug. I have never heard of it with a new wire though. Is there any whitish discoloration anywhere on the wire to evidence arcing?
  3. I am an amateur in fabrication, so take this with a lump of salt, but personally I would go with either square or round tube. I used 1 1/2" x 1/8" square tube.
  4. I think he is missing fuel. So the plug would still be sparking away but no detonation. That's why I asked if the valve was opening, because that is about the only way to get a no fuel condition to a single cylinder on a tbi, a stuck closed valve. Especially considering that the compression is good so we know that the exhaust valve is closing completely. Does the plug look like it is lean?
  5. I found that when I hit something with outer wings that it transferred the energy to the point where the bottom edge of the lower panel met the center section and bent the center section there. For reference my center is 1/4" plate and the outer is 1/8". I have a peice of square tube welded down low on the 1/4" plate spanning the gap for lateral support. I should have made sure that the lower panel edge and the square tube were in the same spot because of that energy transfer. Instead, my tube is about 3 to 4 inches lower.
  6. http://www.nissanpathfinders.net/forum/topic/18-rear-spring-options-for-lifting-your-wd21-pathy/page-12?do=findComment&comment=791277 There you go. I feel like I just linked this thread for someone else recently.
  7. Is he sure the intake valve is opening? I have never heard of issues with Nissan cams, but Chevy was notorious for cam lobes rounding off. The only thing that is missing is fuel, since he has spark, compression and correct timing.
  8. That's awesome. I don't have the patience to mess with photo editing, so it is always impressive to me when someone does. Yes, that is the Amazon one, didn't realize it was so small.
  9. https://m.ebay.com/itm/Spare-Wheel-Tire-Cover-Series-Nissan-Pathfinder-Tire-Cover-Heavy-Denim-Vinyl-/302405573916?fits=Make%3ANissan&hash=item4668c6dd1c%3Ag%3AX5IAAOSw-YVXlfTc&_trkparms=pageci%253Af192d964-b3a8-11e7-bb1b-74dbd180c7b4%257Cparentrq%253A2d3b579115f0a9c555cbd1fbfffc3335%257Ciid%253A18 I really like this one. If I could only find it a little bigger and not shipped from China. At one point I checked with Fluerys to see if he would make a NPORA tire cover, but it was a no go. Logistics of sourcing the blank tire cover in Canada made the end product too expensive, if I remember correctly. I have seen the same tire cover you have on Amazon for around $45. Might be an option for others.
  10. http://www.nissanpathfinders.net/forum/topic/18-rear-spring-options-for-lifting-your-wd21-pathy/page-12?do=findComment&comment=791277 12 pages. Happy reading.
  11. Lol, he looks like the type that would go for a food bribe.
  12. Repaired the cracked weld on the bumper. The 220v welder from horrible fright got better penetration than the 110v Miller so it should hold.
  13. What are the symptoms of a faulty bypass? I am assuming that it will release too slowly, but it still fully releases?
  14. The lights weren't working on the climate control cluster. Pulled it out, turns out the main connector wasn't plugged in all the way. Now I have full lights on the dash.
  15. http://coffeesupremacy.com/best-portable-espresso-maker-2017/ There you go. Gotta keep the wife happy.
  16. Lol! Joking, but it would be nice.
  17. Where will the espresso machine go🤔
  18. That is exactly what I did. I even bought a belt tensioning tool to achieve the 22 lbs of pressure on the belt. It isn't too bad to do. This is the one I bought on Amazon. Gates 7401-0076 Pencil Type Tension Tester And most any feeler gauge of that thickness is about .5" wide.
  19. I believe you can request a copy of the police report. They draw little sketches of what happened and where. Might help.
  20. I really like the idea of cupholders. The mustang seats look nice too. Thanks for all the ideas guys. I will need to investigate cost and time now and make a decision.
  21. Are those double lip seals? If not, give that a try. McGuire Bearing should be able to find those seals in a double lip configuration. They have a store in Tacoma, don't know if they have one in your area.
  22. The owners manual should have all the information on towing.
  23. Over the weekend I spent about 7 hours in the Pathy, and determined that the seat is horrible. Makes sense, it is 25 years old with 256000 on it. I believe I have two options, either new springs and padding for the seat, a rebuild, or new seats. I would like new seats, maybe with adjustable lumbar. Does anyone know if the seats out of something else will fit? Xterra, maybe, or really anything. Mustang seats are nice. Any ideas?
