32
Everything posted by Citron
Using the automatic transmission vs the manual for towing
Citron replied to brc19761's topic in 2005-2012 R51 Pathfinders
Shift points are more based on RPM instead of speed for manual. If it has a tow mode, just use that and let the auto work. -
If you have trouble handling the load, try a load equalizing hitch.
Saturn, can't see the pics since your using Photobucket.
Nice that you learned, many people wouldn't. Getting a ticket 15 years ago for reckless driving, which is a felony, cured me. Luckily, I pled it down to careless driving, which is a misdemeanor. Learned the lesson though. Good luck with the body work.
R50 Tire Carrier Mod: Let's settle this!
Citron replied to hawairish's topic in 96-2004 R50 Pathfinders
Yeah, I like their site. I need to get some sheaves with ball bearings for a non pathy project I am working on. -
Check McMaster Carr. They carry all if those kinds of raw material to make the rubber sheet. -
The new bypass hose?
What year is yours? I have done it on the vg30e. Plug the intake and the exhaust, cap the vaccum line and good to go. You won't see any power or milage gain. It will run just like it did before. The only reason to do it is if the egr is not working correctly and you don't want to buy a new one. Mine was working fine, I did it more for curiosity sake.
Great job! The only thing I would recommend is using heat shrink over the wire solder connection. Since it is already together, electrical tape would work to keep the hot wire from contacting. Maybe you did this already but it's not in the picture. -
Two days to a year +/-. I would repair something that has the ability to leave you stranded before making a trip. It would be a lot easier to fix at home then on the road. At the least, get all the parts needed, so if it does fail on the road, it can be repaired without needing to wait on parts.
1st generation pathfinder starting problems
Citron replied to mrspeedk's topic in 90-95 WD21 Pathfinders
Unless testing was done nothing is eliminated, he is just guessing that the connectors, relays etc are good. If it is truly a problem with the starter, a push button will not help. -
Buy a multimeter. Test the wire that energizes the starter selenoid coil. If there is no power, work your way back until you find power, then you will find the problem. Or start at the other end of the wire and work forward until you find the spot where you lose power. Test at devices and at connectors. -
97 Pathy R50 Dead rear axle. Advise!
Citron replied to Mattmill91's topic in 96-2004 R50 Pathfinders
If they are like domestic rear ends, the rear axle bearings are lubricated by gear oil. As long as you keep clean gear oil and full enough that some can migrate down the axle tubes to the bearings, you should be okay. -
Excellent example of why to do diagnoses before throwing parts at the problem. -
Wiring electric trailer brake controller
Citron replied to colinnwn's topic in 96-2004 R50 Pathfinders
Cold side? Never heard that before. -
That is awesome. It is always fun learning a new skill. I had a pretty steep learning curve to make my bumper. I actually made a lat tower before starting the bumper just to practice welding. I would really like to see your project when it's complete.
Tried taking my Pathfinder for a swim
Citron replied to ubertalldude's topic in 90-95 WD21 Pathfinders
Time to get rid of the carpet and relocate the ecu. -
Do you actually need new innards? You should be able to get away with installing a new right axle shaft, unless the bearing failure damaged other things besides the shaft. -
Why lose the manual in either situation? The vg33 will work with a manual transmission. There are tons of write ups and discussion on vg30 to vg33 swaps.
The internal pic looks pretty standard to me. The only odd thing I see is it looks like the retainer on the right(top) shoe is missing.
95 pathfinder/terrano2/mistral transmission
Citron replied to Dino3310's topic in 90-95 WD21 Pathfinders
The solenoids I was referring to are for shifting. Once you drop the pan you can usually find some bolts to drop the valve body and the shift solenoids are in there. At least on the stuff I am familiar with. -
In hydraulic systems, if the fluid is ported through a small opening with a sharp edge under high pressure, it will heat the oil, sometimes to the point of burning it. I have seen this when the lands of spool valves don't shift far enough to clear the oil passage. Since it was stuttering in OD, I wonder if the solenoid wasn't shifting fully, causing the burning. A bit of crud can cause the solenoid to stick, or if it is an electronic tranny, a faulty solenoid coil. Remember, this is all speculation on my part based off what I know of Ford transmissions, heavy equipment, and industrial hydraulic systems. It needs verification by the Nissan manual and some testing.
