32
Everything posted by Citron
Mig or stick work well too. A left twist drill bit is handy. Sometimes just using that will twist the bolt out, and if it doesn't, you still have a hole.
You will need to pull the timing belt to change the crank shaft seal.
Valve Train Noise w/ Castrol EDGE 10w30
Citron replied to onespiritbrain's topic in 96-2004 R50 Pathfinders
I run Valvoline conventional (yellow bottle) 5w-30 in all my vehicles and have never had a problem. 5.6 Titan, 3.0 wd21 and 2.5 Subaru. Since both of yours are 30 weight, it shouldn't change anything when cold. The 5w would just be a little thinner when hot. Weird. -
And these people vote.
Xterra, 4runner. Armada should be good, same running gear as the Titan. Need to beef up the rear end if you tow a lot, and add a better tranny cooler. If you are thinking that size, the seqouia is nice. Idk what else is body on frame.
They have a ton of different sizes and styles. That is where I bought the one for the rear window seal.
Bulk seals are so cheap from Amazon and JC Whitney, is it worth trying to rehab them?
Lots of white smoke from exhaust in the morning
Citron replied to calvinM's topic in 90-95 WD21 Pathfinders
If it has a sweet smell, it is coolant. Otherwise, water vapor like SpecialWarr said. -
I was also looking at spots inside the frame rails for mounting mine. The wd21 just doesn't have much spare space under the hood. Interstate makes quality products.
Mysterious Coolant Leak Issue?
Citron replied to SquadCarPathfinder's topic in 90-95 WD21 Pathfinders
I bought a generic molded hose from the parts store and cut it to fit. -
AutoBlog: Junkyard Gem: 1989 Nissan Pathfinder
Citron replied to RedPath88's topic in General Forums
Yeah I read that the other day. The author is all wrong about the switch to 4 door. I have heard it was more to do with import taxes calling all imported two doors a sports car that fell under higher tax rate. -
Have you checked the oil level?
after AT tranny rebuld, still won't go past 2nd gear
Citron replied to oldpathfinder's topic in 96-2004 R50 Pathfinders
Bypass what? Starter selenoid, relay, ignition, park safety switch? -
My experience is that the dimples on the backing plate are more of a guideline. The dimples on the cam gears get close, but do not necessarily line up exactly. I would say that one of the cams rotated a little when the last person did it, and they didn't realize it.
I wouldn't. I am not sure the particulars on that stuff, but I would be concerned with flushing scale loose and have it plugged something else.
Pull the accessory belts off and spin the pulleys by hand. It is probably bad bearings on alternator, idle pulley, etc.
Are you still running a clutch fan? Could also be A bad fan clutch, so the fan isn't coming up to speed. Or just a bunch of crud in rad fins.
Recently moved (mid December) and after driving the pathy the 3 hours to my new house, I lost the key. Also forgot my password to the forums. Recently found the key in the bottom of my wife's purse, so took the pathy for a spin to the post office after it sitting for a month and a half. Also, reset my password. I am back!
If your torque converter isn't unlocking sometimes, or locking when it shouldn't, it can cause die at stop lights/idle. Check to see if you have any codes stored.
VG30 to VG33 SWAP, Step by Step Starting Today 8/26/17
Citron replied to OH6PILOT's topic in 90-95 WD21 Pathfinders
The p stands for pawesome. It's a silent p. -
JK Unlimited, commonly known as the JUnK by Cheap. 😁
Welcome! We can't see the pics. Try not Photobucket.
Check all the connections, both on the alternator and on the battery.
Did you have "We are the champions" on the radio?
Primary Cat Removal: Defeated by a shield bolt.. lol!
Citron replied to microfiz's topic in 96-2004 R50 Pathfinders
Can you fit a die grinder with a cutting wheel and cut the head off?
