Leo94
Everything posted by Leo94
  1. I have posted this in op's other thread but because it was unseen here it is. Also could a mod merge the other thread with this.
  2. I can email you a service manual for a navara with the z24i engine. Its the same one I use for my 89 terrano which has the vg30i engine and the manual has both.
  3. Nah I meant like pretend I didn't post before and your identity is unknown but I was half serious.
  4. Thanks although now I kinda feel bad for ruining your plan. What really got my attention was the white coolant elbow, after seeing that and the blue valve covers I though to my self that it might be some crazy coincidence but after some stalking/investigating I could confirm it was you but by then I couldn't delete my first post. Maybe we could all still play along like this wasn't uncovered straight away? But that aside good job with the supercharger .
  5. Also the original picture is here notice the username? MY1PATH has a 1979 Yamaha xt500 and so does this guy yamaha sr500 same username. Its the same guy. Conclusion It is him.
  6. MY1PATH has a 89 2 door same colour body, valve cover, coolant intake and was going to supercharge a vg33. Coincidence no? EDIT: He even looks abit like him if this is his yahoo profile, maybe its just me? Also MY1PATH photobucket is ghj018
  7. It also depends on your wheel dimensions such as width, offset and backspacing. Offset and backspacing being a big one, If you can find a set of wheels with a nice offset and the right lug pattern jump on it.
  8. See that blade connecting on the bottom of the second photo? If i don't have my immobilizer remote then I have to use that to deactivate the engine immobilizer and to make it worse when you use the connector you have to do it in a certain patter something like (Key-ACC position, connection off, Key-on, connection on) I'm pretty sure that's wrong but when i didn't have batteries for my remote I had to play around with the patterns till I got it right .
  9. When I had my instrument cluster un hooked my stereo didn't want to turn on, this probably doesn't help but just throwing it out there . Tell me about it... I'm going to throw away my: Stereo, speakers, factory amplifiers and associated wiring. From there I can start fresh and clean up my wiring mess. Good luck .
  10. Gave my tire carrier a quick paint job mainly because i was getting rid of the surface rust, it looks much better than before but close up you can see the imperfections. I suppose I will give it a thorough do over when I buy more paint.
  11. I think it was the gearing or something because of a different idle speed.
  12. Ah ok, well ill be sure to let you know when I post the how to .
  13. Its would be easier on a 2 door as you don't have to worry about cutting into the rear doors so on a 2 door you can really open up your wheel wells. Watch where you cut though, someone cut into theres and went straight though a wiring harness.
  14. Did some bodywork, Painted the tire carrier rest points that mount to the body and wd40ed the tire carrier greasing points and boy did it make a difference. I will put grease when I buy some but now I can move the tire carrier with just my pinky .
  15. A line or two wont be enough but I will do a short write up with pictures when I buy a convex mirror. Did you need to change yours urgently or did you just want to replace good flat mirror with a convex one?
  16. Figured out how to replace the side mirror glass by practicing on my old mirror. Now I don't need to buy a whole mirror unit just to replace a broken mirror glass and now I can replace my drivers side flat mirror with a convex mirror to match my passenger side convex mirror. Convex mirrors really do make a difference and i highly recommend them.
  17. What makes you think it's the throttle body or a piece of it, if you fuel filter hasn't been changed in a while it can make a huge difference like it has for me and like mentioned before make sure to check your codes and let us know what you get.
  18. Replaced the driver side mirror and the shifter boot.
  19. Have you checked Supercheap auto, Autobarn, Repco and the wreckers? How urgently do you need it?
  20. Wait so some of the pathfinders didn't have middle seat belt making them a 4 seater?
  21. Is this all the time or when slowing down or when turning or when going over a bump or when accelerating or a combination of the listed?
  22. Get google chrome and it will translate the page for you .
