RF600
Everything posted by RF600
  1. RF600
    cutting out
    That's what I'm thinking. I doubt there would be a difference in flow rates. Most of the replacements I have seen list the oem number and the replacement number. The replacement numbers are the same for both colors.
  2. RF600
    cutting out
    My trip to pick and pull was disappointing. I didn't want to pull the intake so I was hoping I could find enough injectors to replace all of them. I have black dots and all I found was blue. I didn't pull any because I couldn't find 6 of them. Either they had really corroded terminals or the ohm test failed. I did find a couple other things I needed though. I'm going to hopefully find a matching one. If not, I guess I will buy a set.
  3. RF600
    cutting out
    Well it looks like the injector for cylinder 2 is out of spec when I did an OHM reading. I can't tell what color is on the injectors. It's either blue or black. I tried wiping off some dirt with my finger and the colored dot came right off. From what I have found the dot represents flow rate. I just can't seem to find out what the flow rates are. If it comes down to replacing all of the injectors, will it matter if a different color injector replaces the other? I will keep them all the same color.
  4. RF600
    cutting out
    I checked the codes. 34, 51. The knock sensor is still there. Now I need to find some time to check out my injectors. I would assume the knock sensor is a result of a bad injector(s)?
  5. My first question is have you checked to see the contact points of the bendix to the ring gear? That would be the first place I would look. Even if the starters look the same or are supposedly the same. Start with the easy stuff first.
  6. I bought a clutch kit from nissan. At first I thought something was wrong. The pedal was really light. I felt like I was going to put foot through the floor when I depressed the pedal. After driving it for a while I have adjusted to the lack of pressure. My guess is most clutches, besides racing clutches, are going to be soft depending on who manufacturers it. Maybe it's nothing? If you still feel it is too soft have you tried to reverse bleed it? From the bottom up. I have had to do that on a couple different vehicles before. Worth a shot.
  7. RF600
    cutting out
    Vacuum lines are good. Today it started and ran really rough. The check engine light came on. The engine light turned off after a couple minutes. I wasn't around my place so I will hope it is stored in the ecu until I can pull the code and see if that will direct me what to look at next.
  8. RF600
    cutting out
    The O2 is new. So the wiring up to where it plugs into the harness is good. I have not checked the voltage of the O2. I had to put a new O2 in because it failed smog last year. My assumption is the O2 is working properly since it passed easily after installing. I have not checked it though. As far as I know the fuel cap is original. I will look at the vacuum lines around the canister. The vacuum lines around the engine are good. I have inspected and changed out some bad ones.
  9. RF600
    cutting out
    So I am having a cutting out issue. When it acts up the check engine light does not come on. There doesn't seem to be a specific time when it does it. No specific throttle input. Nothing I can pinpoint to a certain time when it will do it. While driving it will cut out. Usually only for a couple seconds. Then it picks right back up. Even with the cruise control on it will do it. It will do it while driving around town. Sometimes it will die while sitting at a stop light. There is no rough idle, it just idles down and dies. It will start right back up. A couple times it didn't want to run when started. I had to keep my foot on the gas for a bit, then it would idle on its own. A little history on my rig. Within the last 10,000 miles I have done the following, distributor, cap, rotor, wires, plugs, fuel filter, iac valve, iac controller, O2 sensor, coolant temp switch. I did pull 2 codes, 33 and 34. Since it cuts out at random I'm at a loss for where to look. I have not checked the injectors or fuel pressure. Ideas
  10. You can do it by sliding the trans/xfer case back. The 2 are very heavy. Tranny jack would help a lot.
  11. I would go with fuel injection, not carbed. Drop a LS engine in there. Should get decent mileage.
  12. I'm not telling you to use the rubber you have. The 1/16" longer shouldn't matter. There should be plenty of threads in the strut rod to compensate for the extra length. Honestly, I would buy poly bushings for that spot. They see a lot of road grime and get worked really hard. The poly shouldn't wear out. It shouldn't let the wheel move around much, if at all.
  13. It sounds like the teeth are off on the belt. You can reset the dizzy to compensate. Does it work, sure. Is it proper? I will let you answer that. I'm not trying to be a jerk. If you take it to a shop they will not be very happy when things don't work properly. I assume you had to put the plug wire of the timing light on a different wire?
  14. I'm now a bit over 232000. Hopefully I can get another 200+ out of the old girl.
  15. If you are taking apart the switch be very careful if you have a window lock button. What makes the button stay down when pushed is a small steel ball. I have a switch at home that I couldn't get the window lock to work properly after the ball fell out. I put the ball back in and it doesn't work properly.
  16. The larger companies like that seem to have bad customer service. Although customer service in general seems to suck from everyone. I have ordered from Rock Auto in the past and have had no problems. I usually won't order from them or the other whores like that. All they care about is moving products. I try to keep my money local if possible.
  17. I bought a stock replacement at my local Napa store. When you replace the radiator I would recommend hoses also if you have not done then recently.
  18. I think 194 is too bright for the cluster? If you do put 194's in, you can dim it. I want to say the bulbs are 158?
  19. That rig looks familiar.
  20. What won on Sunday, sells on Monday. Most of you will know that quote.
  21. You can still find a good sender at the wreckers. I would look first before having to spend the money for a new part. Your other issue could be a vacuum leak?
  22. Unless I have the wrong idea copyright infringement. It only applies to something copied, exactly, and sold for profit. So I think they are reaching, a lot, for copyright issues. All we are doing is fixing what is broken, or replacing broken items. I'm not buying the copyright thing.
  23. I had a bad sender on my brother's rig. Even though you have cleaned up the resistor board it may not work. Take a multimeter with you if you go after a used sender. I recommend not letting the fuel tank go under 1/4 tank. The fuel should keep the board lubed.
  24. When the shtf we will all head your way. $6500 for 30 acres, yeah not possible in ca. I don't think $6500 would buy much of anything here. Good for you.
  25. Rant on, Just because someone works at a dealer, doesn't mean they are any good. When I worked at a dealer, parts dept, I knew more than some of the techs. Sometimes parts were redesigned and instructions were included. You might be surprising how many of them wouldn't read the directions or not be intuitive enough to figure it out. So to say that the dealer knows more than we do, I think is funny. They may have the fancy tools that we don't, but I think most of us do quite well without the tools. Rant off.
