ethanrobinson1203242
    Screwdriver Mechanic
    Choose
    Choose
    des moined
ethanrobinson1203242's Achievements
  1. Well I say that because the cat had some glow to it last night after driving. I know that's a sign of a clog
  2. Ok... I'll check maf today.... an if not that, would a clogged cat cause a rough run
  3. I'll c heck it out off the top of my head I do remember it being weather checked
  4. It does it but I haven't noticed it having anything to do with moisture..
  5. At low idle it's running rough then after a few minutes it will eventionally die... but at about 1800rpm and running dow the road it runs fine. New fuel filter, air filter, plugs,wire, distributors cap rotor clean the mass air flow sensor clean the screen out check for vacuum leaks can't find any that I'm aware of. Thinkin o2 sensor next but thought I'd see if any advise
  6. At low idle it's running rough then after a few minutes it will eventionally die... but at about 1800rpm and running dow the road it runs fine. New fuel filter, air filter, plugs,wire, distributors cap rotor clean the mass air flow sensor clean the screen out check for vacuum leaks can't find any that I'm aware of. Thinkin o2 sensor next but thought I'd see if any advise
  7. At low idle it's running rough then after a few minutes it will eventionally die... but at about 1800rpm and running dow the road it runs fine. New fuel filter, air filter, plugs,wire, distributors cap rotor clean the mass air flow sensor clean the screen out check for vacuum leaks can't find any that I'm aware of. Thinkin o2 sensor next but thought I'd see if any advise
