NissanNismoZ
Everything posted by NissanNismoZ
  1. Actually, my gas mileage has SUCKED recently..im now getting 50-60 miles per qtr tank... :\ Where's the harness for the 02 at? I have been questioning my o2 sensor..and im sure the other night where i let it idle for 2 1/2 hours while i rewired all my speakers didnt help either..though i did drive it hard to drive out any carbon that may have built up...
  2. Well i thoght so..but it runs better off stock wiring, than if i wire it directly... I have two MAF's both clean along with a new air filter Hmmm..suddenly like im towing something..like something is pushing in front of the truck, then letting go.. The RPMS will go up faster, then not go up as fast, then go up faster..i want to say like a surging? I can video it, if you want.. I'll try that! Thanks!
  3. Ok, so im starting a clean slate as a few things have changed. My (i think it's hesitation?) For example, if i were to EVER pull out as soon as it stop idling high to warm up (usually around 30 secs to a min, depends) it acts like it doesnt have much power, and as you accelerate to get to speed, it acts like im pushing and letting off the pedal repeatedly, but gently..and it does this until its warmed up (usually around 2-3 miles, but the colder it is, the worse it is.. So i'm wondering, what could this be? I'm trying to figure it out before winter and it just..stops all together.. Ok so if i start it up and let it idle cold, if i listen closely, i can hear what sounds like a slight miss/stumble (i can video it if needed, but its slight..) My CEL no longer goes off, and my codes are: 12 Air Flow Meter/Mass Air Flow Sensor. 51 Injector Circuit. 45 Injector Leak. 34 Knock Sensor. 23 Idle Switch.
  4. It's all because it has a half-tank of gas. If it were near empty, like most, it would be 2k. Gotta know how the system works, people!
  5. anyone ever thought of replacing the N with a W on their gearshift? so it goes PRWD21?
  6. hmm..nope actually the speedo is right on with the GPS..havent had any problems so far.. that's why im not sure what it is.. Now the CEL is doing it again to where it wont even go off..
  7. and i'm also looking in the EC section, i have no EF/FC section..not in any of the ones i can find..? Nevermind..okay, i found it..it says it uses the VSS for it, as well..and i have a VSS code...? i just have no idea on where to start for the VSS...
  8. Pathy's need a sharper turning circle, anyone else agree?!
    1. Tungsten
      Tungsten
      Learn to powerslide
    2. Slartibartfast
      Slartibartfast
      You can probably remove the steering snubbers, though I dunno if the CVs would like it. Plan B: put a Waggy front axle in the back. 4x4x4 FTW!
  9. Here are the results.. 12.3v/600RPM Everything ON, in drive (heater on full blast, headlights on, defrost on) 12.6v/650RPM Everything ON, in neutral 13.0v/750RPM Everything OFF, in neutral seems like the alty cant keep up with the voltages needed... BUT as Kingman said, my voltages are fine at 750rpm or higher... and everything i turned on, made the idle lower and lower..
  10. I'm trying to see if anyone can come up with what i can do to pathy to help the idle..such as, at night with heater blowing on 3, headlights on, radio going, when stopped at a stop sign it idles at 550-600 rpm (in drive) any ideas? it didnt do it since messing with my MAF wiring and trying to run the new wires, which i restored to stock wiring coz it was trying to run at 2RPM (no joke) Thanks!
  11. hmm..what to do to improve pathy's performance..seeing how i've given up on my CEL..which acts more like its a VSS code than a MAF code. Any ideas?
  12. my blinkers actually click loud enough to hear when its cold out!
    1. Reshma
      Reshma
      XD i never hear mine cuz i always have music blasting. Sometimes i end up driving miles down the freeway with the blinker running. XD
    2. NissanNismoZ
      NissanNismoZ
      so it was YOU!
    3. Reshma
      Reshma
      XD yes...yes it was. :)
  13. ..violent misfire.. thats what SHE said!
  14. So..today..i was cruising to the redlight (radio was off for some unknown reason) i hear the clank (metal sound) as soon as i hit the brakes (as usual) the light turns green..i let off the brakes to accelerate..and notice..this same clanking sound..ticks faster and faster..still staying at a quiet volume..it just gets faster and faster...any ideas what this could be? Thanks!
  15. Thanks for the suggestions guys! it's appreciated ill keep the cardboard idea for the winter, thanks!
  16. Oh really?? Do you know which side or the whereabouts I would find this gremlin? it does seem to play with the CEL more after/around when it's rained...
  17. next project....push button start!
    1. Show previous comments  2 more
    2. NissanNismoZ
      NissanNismoZ
      if you do, make sure you include a write up! would you wire it up through the relay...or what?
    3. Tungsten
      Tungsten
      Do you mean remote start or a button on the dash board? If you want to start from a button on the dash and not from the key just don't do it. PM me and I will explain why.
    4. Reshma
      Reshma
      Well the old truck you had to put a key in then push a little red button and she would fire right up. :)
  18. So ive noticed in 35F or lower, it sounds like the starter turns slower than normal, and it surges on acceleration, until its warmed up some..it usually doesnt take long for it to stop, but..is this a problem, considering it goes away after its warmed up? Thanks!
  19. CEL went off as soon as i pulled into work..and came back on as soon as i pulled into my drive way.. hmm..i noticed (ECU never game ME the code) the scan tool i used on it only showed MAF and speed sensor (ECU never read the code for that to me, only the scan tool... so could it be related to the speed sensor? cruise control lioght always quits, starts flickering, then the CEL comes on.. so..could it be that?
  20. Did that, and it wasnt showing any voltage.. MAF wasnt sending anything out with my wiring..i was thinking..ok..since pin B is a ground, should i ground it while it runs to the ECU from the MAF or..what? I'll try the alty thing when i get time Thanks guys!!
  21. it's definitely worse..at first i bought bigger wire than needed, then bought 18 gauge and..still nothing.
  22. After wiring it up straight to teh ECU, i get the proper voltage IN (Pin A is left alone, it reads battery voltage) but..its not sending anything out, which makes me suspicious about pin B so i tried replacing one wire at a time..so.. i left pin C stock and B new wiring..no change. i leave pin B stock and pin C with new wiring..and..pathy runs at 200-300rpm, shuddering horribly? O.o
  23. Okay..so..i gave up (until i can get an idea from someone) and rewired it to stock wiring..
  24. reference..you mean the power to the MAF? i left that wire alone, i only ran new wires to B and C on the MAF..which are pins 16 and 17 on the ECU
  25. why isnt straight wiring the MAF sensor to the ECU working??
    1. Tungsten
      Tungsten
      How did you connect it? Two wires go to the ECU and one goes to the battery.
    2. NissanNismoZ
      NissanNismoZ
      B to pin 17 and C to pin 16
