5
See, things like this would be good to have in Game FAQ. I had no idea about any of this before complaining to the world in the forum. And then NoDeathAwaitsUs decides I'm a dickhead for complaining and mugs me and trashes my rig. This day just gets better and better. "You're not cut out for playing RPGs. You seem to understand your rig better than you do a game. Just hope you don't go insinuating people have special minds when you're out on the trail or the mud hole cause they'll probably leave you in a bind..."
Like I asked in the forums for the game...what the HELL does owning a house have to do with Will and why? Why is this stuff not noted or documented? What the HELL?
How can i rip out my entire retarded alarm system?
88pathoffroad replied to sammyb33's topic in The Garage
A stock alarm uses the stock horn AFAIK. -
Check your headlight switch...even with relays it could be corroded or dirty inside, causing the contacts to give poor performance or none at all.
POSITIVE BATTERY CABLE REPLACEMENT
88pathoffroad replied to PATHFINDER95NI's topic in 90-95 WD21 Pathfinders
Dude. $6.99 for a new cable at local parts store, $.99 for a terminal. Done and fixed. -
Read the posts above?
Sure, easy for you to say with your 100+ levels already and better @!*% than I have...I can't beat ANY of the guys I've tried. This fxcking game is pissing me off, I think I'll just plain stop playing it. What a lame goddamn POS. There's SH1T for documentation and SH1T on the "fun factor" until you level up far enough to be able to do more. I can't go anywhere, I can't make any money, I can't do anything but attempt to build up stats daily and hope I get a break? WTF? http://www.4x4country.net/forums/viewtopic.php?p=7468#7468
Unplug it. It's under your driver's side seat. -
Wear gloves? *snic*
My advice is that you likely don't need new t-bars unless you have a heavy front end with a winch bumper or winch. Stock t-bars work fine. Re-index them if you need more lift. I've run stock t-bars for years after reindexing with no problems.
Shocks don't have anything to do with ride height...
Check the order of your spark plug wires. They should go 1-2-3-4-5-6...
I have a 12 gauge shotgun and some Country MT tires for grabs if anyone needs one. LMK. I'll send 'em on over.
Heavy trailer - good tires necessary
88pathoffroad replied to radudel's topic in 2005-2012 R51 Pathfinders
A/T's of your choice. I don't tell other people what to buy...get what you want and you need and can afford. -
New flashers are only $5 or so. Try that, maybe. It shouldn't freeze up if one bulb isn't working. Electronic flashers are a bit more expensive but they always flash at the same rate, unlike thermal flashers.
k9sar: Take that. Mwuahahahahahaha! I'm waiting for them to fix the trails thing tonight. It's pulling your trail tool from the old DB, so it still says I have a shovel when I actually have a high-lift now. Ugh. Oh, and the rig challenges just got damn near impossible...one guy on the forums took 2300+ turns to beat someone...and that's how it's going to stay, apparently. Let's complain in the forum, that's f*cking ridiculous.
HID's aren't just bulbs. They need ballasts to produce the high voltage that HID's require to produce light. HID's are arclights, much like a welding arc. Electricity at high voltage passes between two electrodes gapped precisely far enough apart to produce the desired light. Standard bulbs use filaments that heat up and produce light when current is passed through it. Totally different animals. Um...try your local library for an auto electrical book? I can't do classes over forum posts.
The ones I have came off an auto 89.
JB Weld, baby. Works every time. I have a JB Weld patch on my WATER HEATER at home that sprung a leak last year. Still holds water.
This is funny...I moved to Volcano Mountain early in the game and then they changed the places you can go and took out Volcano Mountain. I guess nobody else can attack me now? And what IS IT with the money in this game? How the holy hell do you make enough to buy $150000 price-tagged crap with a $100 a day job and finding a little bit at a time? VERY unbalanced game.
That's some expensive octane booster, man. Heh.
You can figure out the spring rate by measuring the overall height, coil count and wire thickness. I Googled for a spring rate calculator and got a few.
Nah, the factory winch was mounted on a brushguard. Someone made that.
New guy and problem ridden 87 pathy
88pathoffroad replied to Boondocker's topic in 86.5-89 WD21 Pathfinders
Yeah, but you'll lose power in the low range. I've run 33's for years now and I'm not all that happy with them. -
I hate to tell you this, but the only factory service manuals for a 87-93 are all on paper, no digital copies. There's never been a downloadable copy. Someone would have to take a copy and physically scan each page to make a downloadable version.
