88pathoffroad
  1. I spent some time working out tonight...350K in Nut Mix and 17 Will bottles later, I went up by about 4x what I used to have. Whew!
  2. Try tapping on the starter relay under the hood by the battery. It may be stuck internally. If that fixes it, I'd buy a new one. You can also try sticking the key in and turning it on and off a few times while the battery is disco'ed, just in case contacts inside the ignition switch are somehow messed up...
  3. According to Invision, they were migrating the forum to a new server due to a hardware change.
  4. Stock alarm or aftermarket? Remote start equipped? Weird.
  5. Bots are against the rules, you'd get put in Fed Jail for that. You need more stats. Work out as much as possible every day. Save up and buy the best shop you can get first. Being at a higher level is good but if your stats are low it's worthless.
  6. Why? TBS's don't add power, give you better mileage or do anything special otherwise.
  7. If anyone wants to deal shaylee some more damage, go ahead. She just did it to me again!
  8. Throttlebody or idle air control valve setup being crusty, perhaps.
  9. Well then, he never did post one of the 4+3+3, did he?
  10. I had to save up for two days to buy that thing, too.
  11. You'll need to crank them up at least a little to get your camber and toe close. Then you will need an alignment, yes. If you just put them in without lifting it will still likely need an alignment.
  12. I've been hitting up one guy for levels, 5 oil per hit for 5-6 levels is a pretty good deal. Trailchaser, your boss even let me have a free hit just cause he liked my Pathy!
  13. You CAN combine all those lifts and get 10" if you like keeping IFS. I believe the 3" BL and a SL(one or the other), but that's not 10" of lift. The lack of installed parts pics kinda tips him off. Wouldn't you take pics of a new 4" SL and Calmini steering if you just dropped $1000+ on each? And gears? Sheesh. Suuuuuure. This is what mine looks like with 3+3 on 33's. No way he has 3-4" more.
  14. Someone have fun with shaylee, #7067 for me, will ya? I got mugged a while back by her and decided to see if I could win in an attack now, so I tried and got squashed in 4 hits by her... At this point I get attacked and put in the hospital again...
  15. You're &^%ing meaner than mean, DJDank! lol
  16. Chatting with my GF on AIM about the game....
  17. My GF started playing too so I have to give her all my old stuff. Sorry, guys. Still waiting for that trail tool bug to be fixed...the owner showed up on the forums today and said he was working on it. BTW, when you're in an attack, don't edit the weapon number in the address bar of your browser to try and get higher hits. It gets detected as cheating and you lose all your current EXP.
  18. Check the build plate under your hood. Under Axle Code you should have a HG43 or a HG46. HG43 is 4.3's, HG46 is 4.6's... Unless R50's don't have one, I haven't actually checked any out.
  19. HOSPITAL k9sar [7485] 161 42 minutes Left by 88pathoffroad Told you so.
