88pathoffroad
  1. I've never noticed any difference between any "el cheapo" station's gas and "the big boys" gas. Not once. Just an FYI.
  2. I'd check prices on the FPR, if it's cheaper than buying a fuel pressure guage, get a new FPR and see if that fixes it. If not, put the guage inline after the regulator and check fuel pressure, you should have 43 psi IIRC. Or was it 46? I forget. Somewhere in there.
  3. NOOOOOO, don't use BJ spacers. They ruin stock UCA's and they will make your CV's break if you lift it that high. Even with aftermarket UCA's. I wouldn't run BJ spacers for any reason, they weaken the upper BJ mount considerably when you lift it. You can't use longer torsion bars, how would they fit into the stock crossmember?
  4. Glass Flats: The Shattered Bottle The Outback: Walkabout Junction The Lochs: Nelly Supply Ice Lake: Ice Cave Discount Lava Fields: The Cleated Pawn
  5. Death Grounds: The Black Shop Temptation Truckstop: Matt's Xtreme Off-Road Polar Waste: The Yeti Supply Carnage Canyon: Mick's Black Market Blood Woods: The Bard's 4x4 Emporium Bandit Hollow: 3rd Owner Discount Rock City: Granit Mart (misspelled unless this is a play on Minit Mart, heh) Thanks go out to Mekanik, who took the time to take and edit screenshots of each shop from here down: Axle Alley: The Twisted Shaft
  6. Miles, WTF? You expected me to reply from work with a tool belt on and a hammer in my hand? Or did you expect a specific response? Sorry... I didn't outright DELETE the info, I saved it to my puter for later. Here you go. 4x4 Country Trailheads: You can travel around in 4x4 Country to different trailheads by selecting "Explore" on the left menu of your screen, then click "Cruise 4x4 Country" under the heading of "Serious Money Makers". In each area there is a different shop with different things to buy in each shop. Access to each trailhead is determined by your level. The higher your level, the more expensive the items are at each shop. There are also User-owned shops in many areas that you can look through to find items that are unavailable in your current area. Another reason to travel the trails is to escape attack by lower-level players that may have higher stats than you do. If you are level 100 and are still working on raising your stats, you can travel to an area that players at lower levels can't go to, thereby escaping muggings and hospital time incurred by attacks. Higher level players can still attack you but are less inclined to pick on people at lower levels than they are because they won't get as much EXP per attack as they will by attacking higher-level players. 4x4 Country Shop Items, Listed By Area With Screenshot of Each Area: The Badlands: Mike's Weapons Shop The Desert Waste: Stacey's Gun Shop Deep Woods: Forest Pawn Volcano Mountain: Rock Quarry Store The Rivers: Wetlands Gun and Pawn The Pit: The Cavern Store The Hallowed Gorge: Warrier's Supply (misspelled) The Ice Mine: Eskimo Joe's
  7. It would have been nice to know how that shxt worked before doing it blindly. I was actually having fun with it up until we got wiped out.
  8. With no write-ups of ANY info on how gangs work, I had no idea. Nice of people to attack while everyone is at work and can't do anything about it. I removed the Guide. No, I'm not angry, not at all.
  9. Damn, that's a nice bug to find.
  10. I paid 5 Will bottles to borrow a Nuke Shop and used like 17 Will bottles I saved from Christmas time to build my stats up. I have around 450K on Strength, 475K on Agility and 380K on Guard, then about 180K each on Rig stats. We have an Armory and items up for loan now. The Gang is also accepting donations from members to fund the purchase of a Nuke Shop of our own to pass around. Check the Forums in the Gang area for more info, we get our own private little forum!
  11. OK, 12 slots total. Final_Frontier and 95HardbodyXEV6 from NOR are already in on the gang.
  12. We have a gang now. Come join up. How many slots do I need to pay for? It's $10k each member, first 5 are free. $1M for an armory, you can dunk oil and money into the Vault, all kinds of interesting things I never knew about.
  13. That would be a stock alarm switch, (probably has all the printed symbols rubbed off) with the alarm not working due to missing switch wiring or something. The alarm module is under your driver's side seat, but to go the simple route I would just pop the switch out of the dash and unplug it. It shouldn't affect the alarm being as it probably isn't working already (tell me if I'm wrong).
  14. I think it's time to form....DUN DUN DUN DUN DUN...a NPORA Gang. I just passed level 300. I was at 205 two days ago.
  15. I guess! You must have 500K on strength, agility and guard, eh? Oh, I wrote the beginning of a Player's Guide on the forums. http://www.4x4country.net/forums/viewtopic.php?t=1061 Lemme know how that looks.
  16. If it's a 98, it could be control arm bushings being shot, could be the back end bottoming out repeatedly, needs new shocks...no way to tell from here.
  17. You can't, it's a unibody. There's no frame for you to lift the body off of.
  18. IIRC the crank pulley can be reinstalled in 6 different positions, someone may simply have put it on the wrong way after doing the t-belt. The balancer is keyed for one position so it only goes on one way, but the six bolts on the pulleys mean it can be put on any which way. I'd check into that first.
  19. Rig attacks don't work any more. FYI. Well, unless you have all the best gear and 500K on rig stats I suppose. The coder denies touching the rig challenge section but it happened right after they messed with it last. I found a guy that loaned me 300M for a Nuclear Shop so I could build up stats. I got 4-5 workouts per Will bottle starting at 28,000 points per workout and going down from there. My stats are WAY higher than they should be for a 200+ level player now.
  20. Screamin' deal! I like it! Get it going! Is it a 4-cylinder? 20 MPG out of the V6? Impossible! heh
  21. You can buy them for $1 each or 12 for $10 by clicking on the "Click Here and Get Money, Oil and Energy Faster" link at the top... I beat up csutke. *ashamed* He stole an attack out from under me, though! *snicker*
  22. Search...tons of topics on this around here.
  23. Ditto, one hit for 24K damage.
  24. Told by who, someone who read and believed hype off the box more than real-world results? Seriously, I've never seen a dyno sheet that says a TBS does anything for you by itself. Stories of disappointed people who shelled out $100-$200 for one are all over the internet. Magazines hype them as well, of course, because they're advertiser-driven and they pretty much HAVE to print what the vendor says it does, even if it's all a lie. Don't believe the hype, they don't work, they don't boost HP, MPG or mix fuel and air better. Fuel doesn't even enter into the equation until you get to the cylinder head!
  25. The frame already has drain holes. I see them every time I wash my frame out.
