221
Everything posted by adamzan
The bolt pattern of the 2012 xterra is not the same as the pathy.
Doubtful. That sounds more like a bad o2 sensor or cylinder head temp sensor.
Cut off the flanges, and then either weld or clamp a sleeve on. Easy 1 hour fix tops. I had to do it on my parents 2000 pathy.
Bad compression, two cylinders...need help/opinions
adamzan replied to barnum's topic in 96-2004 R50 Pathfinders
Why wouldn't it. Just use the intake parts off the old engine. The blocks and heads should be the same. -
Sounds to me like the power valve screws may have dropped into it at some point. It has happened before. Just comp test the Jy engine before hand and you should be fine. Just check and loctite the power valve screws. There's a how to here somewhere. -
Yes, power loss, more fuel burned, and your vehicle sounding like crap as it will get worse. It's not the worst job in the world to do but it is cramped in there.
How to - Removing the hood decorative vents
adamzan replied to Terranovation's topic in 90-95 WD21 Pathfinders
And unless you are some kind of engineer, or have access to a wind tunnel, you can't say it makes any difference for sure. -
It says in the owners manual if the trailer is over 2000lbs it should have brakes. So, go with that.
It's screwed in. And it is a bitch to take out.
Try cleaning out the rad fins. Mine were hard packed with mud and I had to take it out to clean it right.
It could be the sending unit the thing the pump is attached to, just had to change mine, check the wires on top of the tank. They will be corroded where they have those plastic white caps. You can bypass them or buy a new sending unit.
They have it at canadian tire. In the section with all the body work stuff.
Nice job. It took me a year to complete my motor swap, on a pathy I bought for 500 bucks... For the KYB shocks, I found them way to bouncy, I installed a set on my friend's 95 and it feels worse than the stock shocks I took off.
What's the OEM mass air flow sensor connector look like?
adamzan replied to Madcheshire13's topic in 90-95 WD21 Pathfinders
It adds an additional ground. I spliced one into my old pathy myself and bolted it to that bolt with the alternator ground on the rad support. Never had another issue. -
That is a factory part. It does look terrible, but it was to add another ground to the MAF sensor. You can try plugging it in direct, but it may bring back the issue that the sub harness fixed, which is stalling, erratic idle, and an engine light with code 45. -
I still don't get why people care about book value. If you like the vehicle, keep it, fix it, whatever. Case closed.
If you are driving it like that, and it is an ignition miss, you will be dumping a lot of raw fuel into the cylinders, which will dilute the oil and wash the oil coating on the cylinder walls away. This will kill your motor in short order.
An aftermarket one should be just fine, as long as it is a good brand.
Just tighten them yourself, takes 5 minutes. Make sure you only tighten enough to stop the noise. 2 or 3 turns should be enough. New belts break in after a little bit and stretch.
Try gravity bleeding or the old fashioned way. Also you need to bleed it starting with the left rear tire. It is actually furthest from the master as the line run on the pass side frame rail. Also I'm not sure how well clamps and hose will hold up. Why not just get a roll of brake line from the parts store?
If it is good while cold but bad when it warms up, it is definitely sensor related. Check the o2. The easy test is to unplug it then drive the truck to see if it runs better.
Manual transmission TSB
adamzan replied to madkiwi's topic in Technical Service Bulletins & Recall Information
For what it's worth, I just did this on a 95 SE I bought cheap and put a new motor in. It did have a slight whine in 1st and 2nd, but not too bad. I figure it will probably last a while. I used ACDelco syncromesh fluid as it was all I could find here in canada at a reasonable price. As for pouring it in the shift hole, I already had it all apart so removing the shifter was cake. It did not take any time at all to pour it in like some here are saying. It seriously took all of 5 minutes to pour in...And I didn't have to cut the zip tie, I just slid it off carefully and then back on when I was done. It looks like it was never touched, but the oil that came out was clean, but was not the 5.1 litres it should have been. I just used the 5 litres of the delco fluid, and 100ml of some VW manual trans oil I had leftover from something else. -
95 Pathfinder Dimmer switch bypass -Which Wires?
adamzan replied to ScottThompson1982's topic in 90-95 WD21 Pathfinders
Why not go to the junkyard and get a new one. Then it is fixed "properly" and you can dim the lights. -
FWIW I just swapped a new to me engine into my 95SE and I had half the vacuum lines unhooked, egr not hooked up right, and IACV unpluged, and it still ran halfway decent lol.
The EGR, IACV, and PCV will not cause misfires. They would cause poor idling, bad gas mileage, failed emissions test, and burning oil (pcv).
