221
Everything posted by adamzan
The strong arm ones are good. Mine rusted really fast though.
I'm switching my 4.6 out for some xterra 4.90. That should help with 33s. Sent from my SGH-I747M using Tapatalk
Something is wrong with those uca. They look way too short. I have the same ones and I needed about 3/16" of shim to get it perfectly to 0. Has your truck been in an accident to your knowledge? How did it look when you bought it? I'll take a look at mine tomorrow morning and snap a picture. It is entirely possible you got a defective set.
And another starter bites the dust.
adamzan replied to SpecialWarr's topic in 90-95 WD21 Pathfinders
Where are you buying them? I have a car quest in mine. Been working fine for almost 5 years. Sent from my SGH-I747M using Tapatalk -
Those t-bars don't even looked that cranked. Something is wrong. Are the uca's on the right side? Maybe you got a bad set? Mine even with no shims wasn't that bad. Can you take pics of the uca installed. I wouldn't even drive it like that to be honest.
If you need to add more shims, which you likely will, purchase longer bolts for the arms. M14x1.5x60mm. This is 10mm longer than stock. Then you can safely add more shims. Don't add more than 3/8" though.
KYB's suck. The used to be good, but I'm not sure what happened. We put a set on my friends 95, and it was more bouncy than the 20 year old stock shocks we took off. If you want just stock replacement, get some monroe sensatrac or oe spectrum, or whatever they call them now. They have lifetime warranty, and at least monroe is a decent brand.
Another reason not to buy a Cherokee. It brings your luck down! Sent from my SGH-I747M using Tapatalk
And by the looks of those wheels, a brake job and a good cleaning.
truck sitting for years--how to remove old gas
adamzan replied to Cuong Nguyen's topic in The Garage
You could take the fuel line off at the rail and use the fuel pump to pump it into a jerry can. Then evaluate from there. -
None of my u joints that were bad on the pathy ever felt loose they were always binding. So you could only tell by taking the driveshaft off.
Open up the top of it and look? Mine sat for 2 years, I just put fresh gas in and fired it up...it was fine. Didn't even look in the tank to be honest. -
My truck is 7 years older than yours, with likely double the mileage. And it has towed somewhat regularly for most, if not all of it's life, I have an extra transmission cooler. I'm pretty sure its fine. Please don't make assumptions about how I treat my vehicles. If you want to cut into your hood and start corrosion, and make your truck look like a riced out honda, to each their own.
As long as the engine isn't overheating who cares if you can feel it? Mine is like that all the time. Cutting into the hood is stupid and just allows rust to start somewhere else. Sent from my SGH-I747M using Tapatalk
Mine looks the same. Blower was actually bad. It started with fluctuating speed. But then you had to hit it to make it work. And then you get no heat eventually.
Lol. It does not get hot enough in Canada to require hood vents. Actually I have climbed long grades in the summer, with 33's and a trailer, and a fully loaded truck. You just need to make sure your cooling system is in good shape. Clean coolant, no debris or a mud filled radiator. You can tow in OD once you're up to speed, but the main thing is not to go long periods of driving with the torque converter unlocked. Making sure the TC stays locked will seriously reduce trans temp. How big is this trailer, uhaul? I've towed the 6x12 covered trailer they have for a couple hundred km with no issues, even with my WD21, which has probably 100 less hp than your 3.5L. You'll be fine.
fskc people are so stupid!
Can't help you with the clutch, but my pathy has outlasted my last 3 relationships. Lol. Sent from my SGH-I747M using Tapatalk
Unfortunately they're either dealer or part out only items Sent from my SGH-I747M using Tapatalk
As long as you get a high quality aftermarket one, it's fine. Mine's been in there for 3 years. I find intermotor or BWD to be decent. Sent from my SGH-I747M using Tapatalk
Actually its ford-autolite and Chrysler-champion. Sent from my SGH-I747M using Tapatalk
Get one out of an Xterra. Don't bother with anything else.
If I had to do it again, I would only do a 3" lift and 33x10.5x15 tires. If you plan to do a lot of off roading you should get or make skid plates, and sliders to protect the rockers.
I found my pathfinder 1/2 way low on oil on the stick, this weekend on a trip. I'm not sure if it's burning or leaking (the valve cover is very wet), but I had no oil to top it off with. So I just used 1/2 a litre of ATF. It's been 6000km on that oil anyway, so I guess I just did an engine flush lol.
Yeah, I used them before, found absolutely not difference. Here, it is 10 dollars for 2 pack of g power. Or 2 something a plug for the V power. Easy decision for me.
