221
Everything posted by adamzan
Dennis has lots of experience with 20 year old condoms.
Dealer will be able to get one.
I'll make it easy. If it has never been messed iwth it should be in that "tree" of connectors on the passenger side. 3 wires. It will have that wierd jacket o2 sensors have on them. Unplug it there, fire her up, and test drive it.
Unplug the o2, and start the truck. If it runs better, you know that's what it is. If one plug is more rich like that, could be the injector is leaking. If it is, fix it quick or it will thin out your oil and wear down the cylinder walls.
Pathfinders don't have vacuum advance!
New Guy Seeks Your Wisdom (Same Old!)
adamzan replied to Fast_eddy's topic in 90-95 WD21 Pathfinders
What about the timing? Distributor itself look like it was messed with at all?I would get a timing light and check. Timing belt could have jumped a tooth as well. It would run like a bag of @!*%, but it will run. -
Timing belt and water pump, all fluids, service the brakes, o2 sensor, clean the MAF sensor, new thermostat, and tension/strut rod bushings. -
Weathertech all the way. Husky is good too, but fit was not AS good in a 2000 pathfinder.
Just find one from a 4wd.
Weird noises (with video)... still...
adamzan replied to JayTheGent's topic in 96-2004 R50 Pathfinders
This is not one of those vehicles where the head gaskets just "go". It would take multiple severe overheats or running for years with water or never changing the coolant. They have 5 head bolts per cylinder! -
Blue smoke at startup-how long do I have?
adamzan replied to NovaPath's topic in 96-2004 R50 Pathfinders
Yes the Valve Stem seals, while not "hard" to replace, there is a lot of things to take off. You could try some high mileage oil to see if it reduces it a bit. Otherwise nothing will fix it other than replacing them. -
Just throw a new (used) xterra transmission in there and be done with it. It will run you 400-800 dollars depending on where you source a trans but the truck will run forever afterwards.
Did you check all the fuses in the fuse panel? One of them will kill the cruise, and it isn't even labelled so you wouldn't know. I would just check them all and go from there. There is a computer module in the rear drivers side you have to take the trim off to get to it.
1998 Pathfinder Rear Main seal replaced still leaking
adamzan replied to yanstep99's topic in 96-2004 R50 Pathfinders
You can get a repair sleeve to fix the crankshaft. Why didn't they do that. -
I suppose if you buy the direct fit one you don't have to do this? My Xterra has a cabin filter but it would be nice for the WD.
That would have been nice to have lol
I think it is an error on the manufacturers part. There is only two cams and one crankshaft seal. My kit only came with two.
Looking for part number or name--transfer stabilizer bracket
adamzan replied to stormtrooper0059's topic in General Forums
I just took a self tapping screw and went from the metal side into the rubber. Never had another problem. Normally I would not suggest hack fixes but removing bolts from the exhaust can be a pain. -
The bolt pattern of the 2012 xterra is not the same as the pathy.
Doubtful. That sounds more like a bad o2 sensor or cylinder head temp sensor.
Cut off the flanges, and then either weld or clamp a sleeve on. Easy 1 hour fix tops. I had to do it on my parents 2000 pathy.
Bad compression, two cylinders...need help/opinions
adamzan replied to barnum's topic in 96-2004 R50 Pathfinders
Why wouldn't it. Just use the intake parts off the old engine. The blocks and heads should be the same. -
Sounds to me like the power valve screws may have dropped into it at some point. It has happened before. Just comp test the Jy engine before hand and you should be fine. Just check and loctite the power valve screws. There's a how to here somewhere.
