221
Everything posted by adamzan
Yes, the country without a cheeto for a leader
Tire choices for original wheels? 1992 SE Advice? Thanks.
adamzan replied to 92SEPathFindr's topic in 90-95 WD21 Pathfinders
Those look great...Might get a set for my Xterra. -
Most of the Canadian part store chains don't turn rotors/drums anymore...
Is there any play anywhere when you move the wheel? The bearings be really loose?
Cruise Control Transplant 94WD21 to 95 WD21
adamzan replied to OH6PILOT's topic in 90-95 WD21 Pathfinders
I think the plugs should be there. The wiring for most options is all there. Since you'll have a donor truck any sub harnesses, you'll already have. You'll need to swap steering wheels, and add all the components like the brake switches, control module in the back, pump, throttle cable, etc.- 1 reply
- 1
It looks like some ham fisted moron probably broke the plug and siliconed it in place.
Will Rough Country D21 2" lift UCA's work with a Pathfinder?
adamzan replied to Backpacker's topic in The Garage
Could be. I've only ever had the control arms. Rugged rocks sells them separate from hardbody lift kit, just for pathy owners. -
It would seem that way, but I've been here for 2 weeks and the family (that lives here) is starting to wear me down, lol.
Lol they are the same parts. Just a different colour. -
Wiggle the fusible links on the battery, check them to see if they're corroded in the connector, or burnt.
I have driven a couple of SAS'd pathfinders. One was done "right". The other was done, I wouldn't say wrong, I would just say without experience. Let me tell ya. The difference is staggering. The one done right I was hard pressed to tell the difference from an IFS pathy. Drove great. The other wallowed and wandered everywhere and felt like I was going to die at any speed above 40km/h.
Actually, that's a lie. Because one of the wires got pulled out of my door switch connector, and the dome/floor lights don't come on and neither does the light on the dash. But the key ring light still comes on when the door is open. So I think it actually has it's own circuit! Weird. I'd confirm for you but I'm currently in italy lol
It's on the same circuit as the dome/floor courtesy lights.
Mine has the lighted key ring, came with it. I think you can still buy the part from Nissan. Last time I remember it was like 30 bucks.
Chasing an intermittent but consistent sputter
adamzan replied to Nate94XE4x2's topic in 90-95 WD21 Pathfinders
you can probably fix the odometer by removing the cluster, and tightening the brass screws on the back of it slightly, they are the ground points. I've fixed several "bad" clusters this way. You could even go as far as to remove the screws and use contact cleaner on the thin board with the contacts. -
In this thread, broken timing belt...
adamzan replied to clkindred's topic in 96-2004 R50 Pathfinders
I feel like VG33E are "less" interference than VG30E. I have not heard of many 3.0 surviving a break, but a lot of 3.3L. Between the Xterra and pathy alike. -
I believe it is a counterweight so when you use the column adjustment, the motion is smooth.
Building an engine for the Turbocharged Pathfinder
adamzan replied to snowboard419's topic in 90-95 WD21 Pathfinders
I would still rather use a used oem pump (or new if they still make them). The OE manufacturer is atsugi. -
I went there once. Never went back I used to live about 30 minutes from there. The time I went there were a few pathfinders. One of them was on 35" swampers and was trailered to the park.
With the hoses the kit came with, the options are right by the fuel filter, or in the wheel well, in front of the tire. The factory filter still fits on the kit, or you can use the PH8A size filter. I think it's a Ford V8 Filter. I didn't do an oil change at the time and i had to add 1/2 a litre to top it up. So now I can put 4 litres in at each change. After I installed the kit, the oil light was on for about 10 seconds. Got a little nervous but no clattering from the lifters or anything so I think it is fine. Goes out instantly now.
Yes, figure out why. My parents r50 went well over 300k km on the original converters, never an issue... Yours also could have been bad for a while, but the old sensor was @!*% and wasn't picking it up. Great if you want to run headers, lol. Misfires, running too rich (due to misfires or bad primary o2, or other sensors), and burning oil destroy converters. They are technically designed to last the life of the car, they don't just "go bad". They just get destroyed by other issues that most people don't notice right away. Unfortunately once that code comes up there isn't much you can do short of replacing them. Don't fall for any of that cleaning your cat BS. You want to be very careful with the manifold converters. On my Xterra they came apart and scored the cylinder wall of my engine. Which = massive oil consumption.
When you drop the rad you have to cut the rad support and weld/bolt in the drop down so if you can avoid it...Well it wouldn't be the worst thing. Today I installed my oil filter relocation kit, 7 years after I got it, and 1 pathfinder later lol.
You could use supercharged Xterra injectors? -
94 LBYD21 headlamp relay location
adamzan replied to CONNOR_PALMER's topic in 90-95 WD21 Pathfinders
That's funny, same happened to me. One was good for years, the other lasted only a few months. I assume it has to do with my driving habits at the time. More day or night driving. -
If they fit correctly, and you don't live where @!*% rusts, they will last a long time.
