adamzan
Moderator
Everything posted by adamzan
  1. That's too bad. They worked out great for me.
  2. Just rotate it as your pulling it out. It should come out no problem. Going back in will be easy.
  3. I like that. My parking brake doesn't work anyways. Too bad there isn't a leather bench to match the rear seats! (on mine at least)
  4. Stock exhaust? You could pry the heat shield on the pipe out of the way a little. The way I did it was use more extensions and go from further back to get a better angle.
  5. Good luck, I have never installed an oil pump so I'm not the guy to ask, but hopefully the new one serves you well.
  6. To be fair, most dealers don't do that anywhere. They will outsource it to a local transmission/drive train shop. But they should have done that instead. The only time I call Nissan is for parts. Domestic and German vehicles keep mechanics in business. At least that's what the garage I use says, lol. When I had my X in for the inspection he said this is like the 4th time he's ever worked on one!
  7. OEM nissan pump, or aftermarket? Aftermarket parts are such @!*% these days. I'd rather take my chances with used/lower mileage nissan pump.
  8. Hubs, lego's, 100% will fit. The rear ends are the same, minus the spring mounts. Skid plates you may be able to mod to fit. I have an Xterra and like it. I have the 5 speed supercharged version and it is fun to drive.
  9. Sounds like 1. you need a new mechanic. 2. If it IS the converters, and they were replaced, they should have warranty. If not, well you're SOL there. So you clear the codes and it runs fine for a bit? If the converters are plugged bad enough it will run like @!*% all the time. Sounds like to me you have a wiring issue. But seriously, find a new garage.
  10. I have an Iphone but all the "Good" apps are for android. I just keep my old galaxy S3 in the truck for use with the obd2 adapter.
  11. I would take Champion over Autolite, that is for damn sure. My lawnmower has run well for many years with Champion plugs.
  12. Yeah, people boost the VG all the time and never have issues. Could have even been a problem that was there forever, but was exaggerated by the turbo.
  13. I bought a Delco Remy alternator, sure it was twice the price of the parts store rebuilt, but it has lasted 3 years (of wheeling seasons) so far...
  14. Really? I have always run the BKR6EY plug and have never had any issues. Truck runs great, with good mileage for what it is. Theoretically ANY plug that is the right heat range will work fine, for example the garage that installed my new engine in my Xterra, used Delco plugs. It runs great, so I'll leave it, but NGK is what Nissan calls for and what it will work best with.
  15. With the 3.5L you are probably okay. I would try the tires and see how it feels.
  16. I have 3" of lift and have never had an issue with the CV axles. I run 33" tires and a little common sense on the trails (don't let the tires spin to 50mph and then grab traction). I replaced the originals 5 years ago due to torn boots but that is it. I would not worry about it.
  17. This is the proper repair. Common problem, relatively easy fix if you're handy. No need to remove the LCA. Just the 2 bolts that hold the rod, and the big nut on the end of the rod (it's a 24mm or 15/16" wrench you'll need). I found poly bushings really firmed up the ride, if you don't like it too rough, stick with oem rubber ones.
  18. The auto hubs are nice for a street driven truck that you use in the winter, no getting out in the cold to lock them. If you wheel a lot, the manual hubs are 1000X better. No more unlocking when trying to rock the truck, or having it slam into 4wd when the hubs decide to lock. Plus no one ever lubed them right so in the cold they would stick and not disengage.
  19. You might get lucky and find a colour matched fender at the wreckers. Not bad for free at all. Weird how the rad is cracked but the AC still works? The Rad is behind the AC condenser lol.
  20. The fuel lines are 5/16". Not sure if you can get the sending unit from nissan anymore. They weren't too expensive on their own, like 70 dollars or something. Best bet would be a junkyard. I'm sure there are still ton's of wd21s around in BC, at least I saw a lot when I was there last year haha.
  21. I would leave the evap and PCV. They don't hurt performance at all and smelling gas would be annoying. I would put a catch can on the PCV system if blow-by is an issue. EGR, I left mine alone as it works fine and to be honest I would focus on more offroad performance mods. Do what you want with the cat converter, a purely offroad (trailered) rig it may be better to delete it as they can cause grass fires. But the o2 sensor you need for the motor to run properly. Without it, the oil will dilute with fuel and that will kill the rings/walls quickly.
  22. Took the 94 for emissions test. Passed perfectly.
