adamzan
Moderator
Everything posted by adamzan
  1. Lot's of car work today. New rear flex lines and a caliper on the 94. Swapped out the rubber brake lines to stainless extended ones on my friend's 2015 xterra. And then did o2 sensors on another friend's mazda 3.
  2. What plugs did you use? I only use the ngk V power copper plugs. There is no difference at all with the other fancy ones and autolite/bosch are garbage. My friend's pathy had a gap of .080" and it still ran very well lol. This just proves that there is no need for BS msd ignition crap on these vehicles.
  3. I had a similar feeling, except mine, the bracket to which the UCA bolts to, tore away from the frame. Once it was repaired, it was like a new truck!
  4. Funny enough, I replaced my tank with an aftermarket one, and it didn't have that little area for the pump to sit in...
  5. Helicoil or timesert is your best option. Some people have tapped it to some non metric thread size but that just makes it a PITA for anyone to work on in the future. My old pathy had a helicoil on one size, held up until I sold it, and it was lifted with 33" tires.
  6. Personally I would go with the good runner with lower mileage, and fix the bodywork.
  7. That is sweet. There is a part # on here somewhere but they are impossible to find for some reason...Looks like "Send 1" is drum brake type and "send 2" is disk. Gonna order a set of disk ones.
  8. I use the fan clutch because on the trail I have seen people's fan controllers fail a few times. Leaving them to either overheat or have to wire it to be always on till they get home...My A/C works just fine in traffic...
  9. Yeah, take all those grounds apart, and clean them lightly. Then put them back in tight.
  10. FSM: http://www.nicoclub.com/FSM/Pathfinder/1995_Pathfinder/
  11. Here is the spec for the GAUGE SENDER. It has one wire. Here is the spec for the sensor, with TWO WIRES. This is the one that controls engine mixture. http://imgur.com/a/GecPG
  12. 170-180F Depending on what thermostat, and the weather. In hotter weather I assume it would go up towards 190-195.
  13. Lol. My old pathy had drums. It was okay. The braking difference is marginal, but it is way easier to slap new pads in than playing with springs, shoes and clips at -30C
  14. You guys realize the UCA don't lift the truck at all right? They just allow you to adjust the camber and caster properly. Get the Superlift UCA the 4x4parts ones are okay but the ball joint angle sucks. If you crank the T-bars you need to ensure that you have around 1/2" between the bumpstop and the control arm. Or get low profile bumpstops. Or, since it doesn't matter in this scenario, cut your stock bump stops in half like I did. Don't use cheap shocks. You will have a stiff, yet bouncy ride at the same time. It will handle like ass on the highway when you hit an expansion joint. The Jeep cherokee springs gave me next to no lift. I feel like if your stock springs are sagged to @!*% it will, but mine were in great shape, and I only got 1" out of a brand new set of jeep springs. Sold them to my friend for his wd21 and they gave him over 2".
  15. The pitman is literally just a piece of metal. So short of the hole getting wallowed out or something, there isn't much to go wrong with it. The ball joint is on the draglink, it is the opposite of most domestics.
  16. The problem with "cheap" is that it does not last and you will just end up redoing it later on. The grassroots CL was about $225, new control arms $200, 3" lift springs $125 (that was at the time I bought them). That's 550 just for the suspension and steering. Then there is an idler arm brace so you don't bend it, you can fab those yourself if you're handy, if not, they're not too expensive. Of course you could just use junkyard jeep coil springs, and crank the tbars and do nothing else. But they will be replacing the CL, Idler, and doing an alignment every time. I learned the hard way, pay now or pay later lol. All of this is easily done on a weekend. Or even a day if you're quick.
  17. I usually use the side of an old margarine container. Same idea but with plastic.
  18. I think grafting an Xterra supercharger on would be easier, and you could get better power range out of it as well. The only thing I think that would be hard is adapting the belt.
  19. How much noise was that making? It must have handled like @!*%.
  20. It will work. He may need to swap the sub harness (plug and play no cutting) from his trans to the 94 one. But it will work.
  21. I think you west coast guys forget that on the east coast we are in the middle of winter. Mine will pour out white smoke all day long because it is so cold. If it isn't losing antifreeze or overheating I wouldn't worry about it. It is very rare that a VG30E loses a head gasket, they have 5 head bolts per cylinder. My 94 has 270,000 miles on it and still runs great. My apologies I was wrong about those hoses. Been tired as hell lately. You should be able to find some kind of hose barb that would fit that. As long as it has a good seal you will be fine. I think I used 5/32" hose for the vacuum lines.
  22. That hose is supposed to go where that allen wrench is. I would try a new gas cap for the back area. Get it rust proofed if you're driving in the salt! I'll look at mine tomorrow to confirm.
  23. Lol thanks. One of mine is still missing the circlip 2 years after my attempt to change it. Shows how seized they are. I guess I will be welding mine in place as well. I do have an air hammer so I may try it. Las time I used an impact socket extension and a 5lb sledgehammer. Didn't break free and I didn't want to kill my fingers!
  24. You assume I have a welder....Oh wait, I have 2 20+ year old trucks, of course I do! lol Breaking them free sounds fun. Just put vice grips on them? I'm trying not to fskc the paint on the door if I can help it. What lube did you use on the bushings? I figure regular old grease should be fine?
