221
Everything posted by adamzan
That's what I did and left it that way, not intentionally, but because @!*% came up and I had to drive somewhere. It has been that way for like 5 years, and I don't think I even taped it up lol. I didn't wire the tweeters back in, I have aftermarket speakers with built in tweeters that sound great. The reason they used the amps in the first place is because it sounds better. The stock system when it was newer sounded pretty good compared to other cars of the day. If you want to use the amps you need to connect the blue "remote" wire on the new deck to the blue amp wire in the adapter harness.
My steering wheel is wacky but steers correctly.
adamzan replied to oldpathfinder's topic in 96-2004 R50 Pathfinders
As soon as I hear that from any mechanic, I walk away. If I thought it was too much to fix I would have just scrapped it myself already! -
Steering rack bushings. Not sure what idiot mechanic could miss that. They are easy to change and will make it steer like new again. -
Try this, I found it years ago and it worked great. You don't even have to hack up the amps if you want. On mine I just tinned some short pieces of wire and jumpered the connectors to go direct to the speakers. Easily reversible if you want to go back to stock. http://www.nissanpathfinders.net/forum/topic/24612-how-to-bypass-factory-amps-in-your-clarion-equipped-nissan/
Speedo flutters, no Temp reading, limp mode...
adamzan replied to windcalmer's topic in 90-95 WD21 Pathfinders
I had this same issue in my old one. It turns out water was getting in after a recently replaced windshield. It was coming in through one of the trim fastener holes... The shop fixed it under warranty so I never looked any further. But it did the exact same thing. I would check all connectors for moisture/pull up the carpet on the edges as the wiring runs along there somewhere on both sides. May not be a perfect answer but hopefully points you in the right direction. I remember it would be fine on a hot day but on a dewy morning it would act up. -
I hate aftermarket control arms. Wherever possible I always try and get used OE ones and replace the bushings in them. The aftermarket ones seem cheap and thin.
I have never found a need to replace those.
In the service manual it states you need to check the timing when it is fully warmed up, so it would make sense that it reads too advanced when cold cause it is idling higher.
If the timing is correct, then you may have another issue. Any codes? If the timing is too far off it usually will have no low end.
Any mechanic/tire shop will have one.
- 1 reply
- 2
Using the automatic transmission vs the manual for towing
adamzan replied to brc19761's topic in 2005-2012 R51 Pathfinders
With the newer automatics you really should run the OEM fluid. Yes it costs more, but a new transmission costs even more. They are more complicated and not like the old ones that will run forever on cheap generic @!*%. I would consider 250 dollars cheap as I could probably not even have my WD21 auto serviced for that price. -
haha serves them right for selling used @!*% for as much as a new one costs. What wreckers was it?
Blew up the engine on my Xterra:
This happened to me too... Replaced timing belt/water pump/etc. Was fine for about a week until someone in the Mcd's drive through says my truck is pissing coolant. Got to change that in the driveway in January in Canada. Fun.
209 dollars for a used distributor? What the fskc? I have a used one out of a 3.3L Xterra (same) that I would have driven to you from Ottawa for that much money lol.
Electrical issue? No speedometer, underpowered, throttle.
adamzan replied to 95wdnewbie's topic in 90-95 WD21 Pathfinders
On your egr valve you will see what looks like a second little round valve... Do you see a small 1-2" long hose connecting 2 metal hoses? Mine had a split in it and was causing the code 32. Looks like this: -
Worth it? Body lift cranked bars and rear lift springs
adamzan replied to Texasledfarmer's topic in 90-95 WD21 Pathfinders
I had have a 3" body lift with the 4x4 parts 3" SL for years. I've got no complaints. If you crank the bars but don't lift the rear it will have a huge rake. -
The xterra seats are worse. Trust me, I have one. I get into my wd21 and I'm like "ahhhhh". To be honest I would try and fine some of the leather seats out of an SE or LE. I love mine and they have adjustable lumbar. Even my old 95 SE cloth seats had adjustable lumbar. I'm guessing the 92 didn't. Rebuilding them would be nice, then you'd have something new. I've driven a wd21 across the country twice from Ontario to the Pacific Ocean. Last year being the most recent time. Had no complaints about the seats.
VG30 to VG33 SWAP, Step by Step Starting Today 8/26/17
adamzan replied to OH6PILOT's topic in 90-95 WD21 Pathfinders
Can you PM Pezzy? -
Are you expecting it to last as long as the 95 did? Sure they don't have the rust issues but the rest of it just doesn't seem to be built as well.
97 Pathy R50 Dead rear axle. Advise!
adamzan replied to Mattmill91's topic in 96-2004 R50 Pathfinders
What the other guy said, you can't really repack them. Once and while I will jack up the rear end and check for play/smoothness. All you can really do without tearing them apart. I'm sure if I did that would just be inviting a @!*% storm to start. -
Take the dizzy cap off and check to see that the rotor turns when you crank it. If it does possibly a distributor issue. If not the timing belt could have broke, though unlikely while sitting.
Sounds like the timing is off... Take it apart and count the teeth. Do not mess with the distributor unless you removed it or adjusted it previously otherwise. If it is in the factory location it will be the belt causing the issue.
Changed the oil... First oil change interval complete with the relocation kit on and no leaks. Probably can easily extend it to 7 or 8000km instead of 5. The oil was almost like new when draining.
Literally makes no difference. Takes a little clutter out of the engine bay but that is about it.
