adamzan
Moderator
Everything posted by adamzan
  1. If you have drum rear are they properly adjusted?
  2. I had the same issue and turned out it was a combo of bad center link, tie rods, and drivers side wheel bearing being loose.
  3. Can you scan and post that page? That's awesome!
  4. I broke free my old tires on dry pavement. I find they have plenty of power for daily driving. For gas mileage sake though I've learned to drive slower.
  5. Isn't synchromesh for 5 speeds???
  6. I hope they flushed out the stock cooler as well. The problem is that it clogs, I still haven't found the time to install an aftermarket cooler in mine but when I removed everything to do the timing belt I flushed out that stock cooler real well. Seems to work OK so far.
  7. After 3 or so changes with the 4.4L bottle I can usually poor the remainder of the other ones and make one nearly full one. It's great I don't have to buy backup oil for the truck. Not that it ever needs it. 266,000kms and the oil stays full for the full 5k or or 7k if I get lazy.
  8. If you use the nissanmatic C fluid, it will correct the rough 1-2 shifts apparently.
  9. up here we have all the salt and crap as well. I think a well sealed boot would be a good idea...
  10. Yeah mine reads lower than it actually is too. I can drive all the way to my moms from school with the fuel light on.
  11. I found a wire that goes across from one headlight to the other that didn't look factory, I cut it to see what happened and the drivers side drl went out. Someones cheap ass fix is going to cost me one of these days! It's funny these drl highbeams are actually brighter than my regular high beams.
  12. Just wondering, but is the wd21 DRL module the same? And would it failing cause my DRL to be my highbeams at full power. I got pulled over and warned 2 days ago
  13. Well we are both canadian burton8it, so 80L is good enough
  14. according to google: 21 US gallons = 79.4936475 liters 21 Imperial gallons = 95.4679295 liters I'm pretty sure everyone is speaking in US gallons. Maybe having such a low tank triggered a sensor. I know if you don't screw the gas cap on all the way it will come on.
  15. Maybe you could get a headliner out of a 93-95 pathfinder. Like this.
  16. My 93 and 95 manuals state that it is an 80 liter tank.
  17. Since the door sensor doesn't work for my drivers door you can open it with the key and not have the alarm go off. But as soon as you put the key in the ignition and turn it, it disables the starter and sets off the siren.
  18. I've been down that road before. Luckily for me I use a copied key all the time and keep a spare in my wallet. But now that I got the keyless entry/remote start working, I'm so glad I never have to use the keys to open anything.
  19. Or wheeling with the mafia. You would need a pathy to find a secluded area and to haul the bodies
  20. Mine does something similar. It will fire up right away but stumbles up to idle. Also when I first got it, and it was sitting at the shop for inspection I wanted to try it out. And when I did, it took like 3 attempts to get it to go.
  21. Everyone I know calls it mudding or off-roading. I'm the only one of my friends who call's it wheeling.
  22. You have to take off the power window switch and the trim around the door handle, there is a screw holding the armrest down, once you get the armrest off there are 2 more screws. Then you gently pull off the door panel and lift it strait up, it is kinda hooked onto the metal part of the door. I have the same speakers as you, you will have to cut the plastic basket to make them fit. They sound great though
  23. Just go around and tighten up all the little clamps. That's what I did, it can't hurt.
  24. Check the brake fluid. Also if you do have abs it is rear wheel abs only.
