adamzan
Moderator
Everything posted by adamzan
  1. My friends gmc sierra turns worse than my pathy, again it is a pickup. And an suv with a mushy suspension like the exploders and blazers will just make it handle like crap. Kingman, I bet your shocks and swaybar parts are all original, replace them, you'll see how well these trucks can handle. I can take a 40kmh on ramp at 65kmh and not even feel any body roll. And GG. I didn't know you could adjust the steering stops. I'm going to try that sometime.
  2. adamzan
    Rear brakes
    I think you also need to swap the Parking brake cable
  3. Those guys were so biased. Not to say I am not. But 5 years down the road lets see which one has had more repairs? Man those blazers were fugly!
  4. to the left of the oil filter you should see something sticking out of the block, that is the oil pressure sensor. It goes in there. That looks like it's been messed with before.
  5. I got one of those hide a key things but none of my pathy keys will fit in it. The key was too long IIRC
  6. It does it all the time. The PO told me that it once locked itself with his kid in the truck. On that rig, none of the key locks work for some reason. He said to always keep fresh batteries in the fob. I've heard that the lock actuator can mess up on these trucks. My DD pathy hasn't given me any issues, thank god. Maybe temporarily keep the fob and key separate so you can at least unlock them until you get it fixed?
  7. My recently purchased 95 has a viper remote start/alarm and every time you start the truck, once the engine fires up, the doors lock, and once you turn it off, the doors unlock. The PO warned me that they do that. Kind of pisses me off too.
  8. I bet they touched the sensor while removing the oil filter. It's right beside the filter.
  9. Check the alternator, maybe the belt is too tight.
  10. I hear if you fill it full it reduces vapors. Nige told me that he stuffed wet rags around the tank and lines.
  11. http://www.jegs.com/i/Performance+Accessor...4/4053/10002/-1
  12. I will be doing this probably this coming weekend after I replace my alty. I will post pictures and info on how to do it without the template or instructions. The guys at AC didn't update their listing until after I complained about it. Stay tuned.
  13. I think it's like that from the factory. Not tmorgans. I mean alex's
  14. It had about 240,000kms on it when I tested it out for him B. So about 150k miles. It's probably the cleanest pathy you'll find around here.
  15. 87-93 is on the signal arm. The 94-95 and r50s have it on the steering wheel.
  16. Well my wiring at the sockets has obviously been messed with by the looked of things compared to the FSM. Btw you can get the 5 wire (with 87a) relays at princess auto for 5 dollars each.
  17. I heard somewhere that as long as you're going perfectly straight and your tires are all the same size and tread, that you can use 4x4 on dry roads. But I don't know what the point is.
  18. MSRP Price Gear assy - Power steering - Power steering 93-95 $1,793.23
  19. adamzan
    tranny
    Also maybe something is wrong elsewhere. For example when my catalytic clogged, the truck would shift at 3000 grand and barely keep up with traffic. I guess the tranny was just compensating. I also have a rough 1-2 and a slow/soft 2-3. 3-4 is fine though. I've heard that using the nissanmatic tranny fluid solves the rough shifting issue.
  20. I was just looking at the stock headlight wiring diagram, for the canadian model, and after thinking about it for a few minutes I realized that it's a bit different than the non DRL setup. I was going to use 2 relays one for the high beams and one for the lows. But I think that it would just make a whole big mess of things if I did that. Tell me if I'm retarded but would it just be best to use 4 relays, one for the high and low on each side? That way I don't have to mess with the damn DRL and get pulled over by the fuzz.
  21. I would remove belts one by one and see if the noise stops. Hopefully it is a belt.
  22. it's only illegal if you get caught, although we have yearly emissions checks here, so I won't being doing this.
  23. adamzan
    axle seal
    Much better I bet they'll have to order that seal, because they (for obvious reasons) don't stock parts for 95's.
  24. adamzan
    axle seal
    B that was a front axle seal Mike maybe if you call the dealer tomorrow they will have it by the weekend. I know tony graham can get stuff for me next day usually. http://www.rockauto.com/catalog/raframecat...p;parttype=2348
