adamzan
Moderator
Everything posted by adamzan
  1. My grandfathers neighbour has an 08. He is very happy with it. I've been in it and although I don't care much for the style, it is one nice ride.
  2. I swapped SE seats into my XE. They bolt right in. Also the wiring for the heat seat to the fuse panel was there, and the fuse was even in the fusebox, but the wiring that goes from the switch to the seat isn't. You'll need to swipe that and the switch from the donor.
  3. I have monroe sensatracs and find the front ones quite mushy but the rears are way too stiff. I've heard good things about kyb.
  4. What I did was use simple green like B said. Then I re sealed the whole driveway
  5. How about one of those "Remove to tow Chev's" or ford or dodge. Pick the domestic that you dislike the most
  6. I used BFG Radial Long trails for my street tires. They ride real smooth but they suck in snow or mud. But you aren't going to be using them in that are you lol. They last a long time as well. Or you could just go to a tire shop get some highway all season tires, which is what the long trails are.
  7. If he puts a cooler on it I think it would be fine also because the tranny itself is strong, it's just the heat and clogging cooler that kills it, no?
  8. I'm thinking about getting a set of those. My truck keeps popping bulbs on the drivers side though.
  9. I'd buy yours lol. Provided it was rust free.
  10. Our pathy's take two 19 inch blades I believe. I'm pretty sure that I could put 21s on there though.
  11. bosch icons are 26 dollars a piece here.
  12. I used a nissan belt and the white marks worked perfectly for me.
  13. Try removing the wiper arms and lubing the part that moves...That happened to my rear wiper.
  14. He probably loved the pathy too much
  15. I'm still driving it for now. The floor doesn't seem to be heating up
  16. Someone once told me they used Iodine to free seized plugs and un seize a motor.... May that would work.
  17. For the beeping remove the drivers side kick panel. Its too the left of the brake pedal. Water got in there on mine and made the seat belt timer short out and constantly beep. Which = annoying. The panel is the plastic trim piece below the hood release...
  18. Why would they care if the truck breaks. It's your own risk anyway lol
  19. Riveting is illegal there? Damn. Thats how the current "patch" is being held in. This time it will be welded. If not I will rivet as best as I can.
  20. That's why you lie about what you're going to tow lol. Tell them your picking up your buddies broken down geo metro.
  21. My friend has recaros in his 92 jetta. They are so uncomfortable, well to me at least. Plus he freaks out if you don't "Get in the right way"
  22. There are alternatives to salting the roads. Like people learning to drive properly. Though we know that will never happen! So in two weeks I will drive to brantford to help nismojunky and hopefully we can get this rust all patched up. Great time to bring out the mig welder!
  23. If it is dangerous, thats too bad because it is my only mode of transportation right now
  24. The rear window and doors should be the same.
