GrimGreg
Everything posted by GrimGreg
  1. The cup holder, if really for a Pathy, fits the ashtray space (looks more like one out of a Dodge mini-van though).
  2. That is to mount it in a basket on a rack. If you have a basket, you can make a simple clamp to hold it in place with a piece of flat bar and 2 J bolts.
  3. My 93 has 3 blue relays on the passenger side fender that are not in the relay box, 1 is right behind the battery attached to the fender, the other 2 are behind the relay box 1 is attached and the other is just laying in there. All of them have relays in them, but none have labels.
  4. , I went out, opened my hood and looked, couldn't see where it went, so I just reached in to feel where the other end of the hose went.
  5. Undo the 2 bolts holding the UCA to the frame and put shims or washers between the cross bar and the frame, all the alignment shop will do (if they know what they are doing).
  6. They still sell your exact tire, they just call the "odd" sizes LTBs.
  7. That is out of the back of the upper half of the intake right? If so it goes to a spot on the back end of the lower intake manifold.
  8. Going through the fenderwell without a body lift, watch you don't slit your wrists on the inner fender edge.
  9. GrimGreg
    Parts
    All but the torsion bars.
  10. Looks like a custom built rig, if it's the same one as on the bottom of this page: http://www.brian894x4.com/Hiluxgeneration1.html
  11. Not the regulator....it's the MAF wiring.
  12. Hell, people run 33x12.5 on the stock 15x6 chromes without issues.
  13. Nah, my 93 will stay unmolested. I bought the 88 to have fun with, so I'm going to. Besides, I don't wear woman's underwear.
  14. Found a new one for $130 today, will be here tomorrow.
  15. Look into the cost of machining if you are going that complete of a tear down. Overbore (if you need/want it), at least getting the lip taken off the top of the cylinders and the cylinders rehoned. Valve seats reground and the head plained if needed, etc.
  16. The only ones I have seen were cover ups, they used the dimond plate bed rail caps for a pickup and stuck them over the rocker.
  17. I started pulling the interior panels, and taking some measurements on my 88 today
  18. Here are some of my photo-chops, the 88 is a maybe, the 93 one was for an example to someone one time:
  19. Same direction, if so it is LSD?
  20. Yeah, mine too. For the LEDs you should be able to get a flasher add on though.
  21. Glad you are home without to much trouble. Almost sounds as bad as one of my trips across. We slid into a ditch in the Ozarks, got stuck in New Mexico for 2 days because the roads were closed from snow, then lost an alternator in Arizona and had to wait another day there for a new one.
