GrimGreg
Everything posted by GrimGreg
  1. Actually you can bring it over if you can get a title on it that says it's over 25yrs old .
  2. IIRC on mine to fill it I connected to the valve on the long hose that comes across the firewall.
  3. How did you manage to split the thing?
  4. I think they actually removed (or added crap) half of what was good about the WD-21s when they made the WD-22s. Rear suspension, rear glass that can be opened, a gas tank that didn't hang so low, no worthless plastic filler parts on the body or bumpers....
  5. Got one sitting on my workbench out of a 95, got it in the junk yard out of a wrecked one
  6. Unless it is a tight fit in the bushings and hinge mount it will wobble. The replacement pins are easier to get out, unless you mushroom them with a press like the factory ones.
  7. Maybe a basic mini pressure switch hooked onto the speedo needle.
  8. Here is a pic of the parts for both setups back to the split. Sorry bout the size.
  9. Sounds like your fusable link from the description.
  10. Good to here it was a simple fix, could have been much worse.
  11. Yep, the firewall and dash are the same, under the truck might be another story though.
  12. Nope, not on one that old, I tried that myself. If you know a good locksmith, the cylinders can be rebuilt.
  13. I felt cramped in the one I sat in at the autoshow. I don't like em, but if you and the wife like it
  14. Less than I did have, but still enough to goof off
  15. Hey, at least we can open it unlike an Xterra How about the low hanging exhaust crossover pipe, and the oil filter location.
  16. Change your oil as soon as possible, if your intake was wet you probably sucked a little water into the engine and when you tried to start it you might have forced any water sitting in an open cylinder past the rings into the crankcase.
  17. Does the starter turn or does it just do nothing when you turn the key?
  18. And every biker wannabe has Iron Crosses on everything -thnkboutit-
  19. Not all of them came with one, but you can upgrade, I did . The wire harness is already there, plug and play
  20. He didn't, you did, like every other freakin post you make. How do you know he wasn't talking about an S-10 Blazer? -thnkboutit-
  21. Ooops, forgot they changed things on the 94 dash, duh....
  22. That hole is where the power mirror adjuster goes. No cupholders in the ceter console?
