GrimGreg
Everything posted by GrimGreg
  1. Yeah, the Pathys that came with Lego wheels had 31s stock.
  2. Now there is a sound clip you won't find too easily..... I don't know the reasoning for the straight pipe, but I would highly doubt it's for tonal qualities.
  3. There are holes that will line up, but you won't be able to use your stock bolt/bracket parts. Just buy 4 1" long by 3/8" nuts and bolts. I used longer because I had 4 random bolts that fit laying around. Here is a pic of mine, I only have a 2" BL, but I think you would use the same ones.
  4. Love my manual locks, no "back-talk".
  5. You can make your own (for cheap) gap guards is what he was trying to tell you. BTW, with Pathfinders, being 2wd doesn't matter too much, most everything is the same for 2wd and 4wd as far as suspension, steering, etc.
  6. Those are for if you carry a lot of weight or tow. They keep your ass from saggin'/draggin'. They don't do much of anything for you untill you start to compress the rear.
  7. Though it looks like a nice place and clean install, you are going to make a mess when you go to change it with it installed like that.
  8. I haven't used mine since like 2001 or so, lol, and at that I might have 3 purchases on it.
  9. Yeah, they are sad looking, but at least they had the part you needed . Did you see the rolled Xterra back there? Been thinking real hard about grabbing it's axels, 4.9 gears .
  10. Yeah, 90-95 ought to use the same part.
  11. The VG33 ought to fit right in and bolt right up to the tranny. They are basically the same block with different heads.
  12. If you want a high $$$ one, go to 3C, they enjoy over pricing things for insurance companies.
  13. Yeah, leave it in there behind the y someplace. It is still an important sensor fo your ECU, cat or no cat.
  14. GrimGreg
    Coolent
    Your radiator cap might be bad, allowing pressure to bleed off and coolent to come out around it (and not touch the stuff in the overflow).
  15. Actually if that is labor and material for $120 that doesn't sound too bad. One other place that will allow in some noise is the T-case boot (the rubber one under the leather). If it is torn it will let in a lot of noise and heat.
  16. All that is kinda like a dentist going through your ass to pull a wisdom tooth.
  17. At the end of Little Ave. (East end) off of Brown Rd. http://maps.google.com/maps?ie=UTF-8&tab=wl
  18. Yeah, the PO of my 88 couldn't understand why the window wouldn't go all the way down....
  19. Which light (D or P)? Did you check Cantley's? If not DON'T CALL, I know they have at least 3 Pathfinders in there, can't remember what the rear lights were like (if still there). They'll let you wonder the yard for $1 there, then just pull what you want and take it in to the counter. Usually show up at the counter with something like that, they'll just make up a number (usuallly smaller the part, smaller the number ).
  20. Keep an eye out on the Nissan boards in the classifieds for one. I picked up a stock one not too long ago for $50.
  21. The only one I ever drove ( a former girlfriend's sister's 89) needed all the PS it could get. Even with the PS it was a dog on turns. I had a R&P non-power assist BMW 320i at the time that was easier to manuver.
  22. Wonder where he plans to stick the PS pump?
  23. If you ever plan to offroad your Pathy, don't get the Manik one. It drops way down and ruins your approach angle, and with the way it mounts if you were to hit it on something it will bend right into the grill and hood. (I had a Manik on mine for the first year after I bought the truck.) If you do like the Manik style one, check out WAAG brand also, they are similar and cheaper if memory serves.
  24. I agree. Either replace it with new or ef'n deal with it. Damn crybaby!
