kdj Posted August 1, 2014 Share Posted August 1, 2014 I bought the new sticker for my licence plates on Tues.(my birthday) so I put it on today and took it for it's last drive. Came home and pulled the plates off and parked it in my juck yard. I'm going to miss the truck but at least I can watch the rest of it rust away in the barnyard. R.I.P. (rust in pieces) to my Chilkoot. Sad day for me. Link to comment Share on other sites More sharing options...
adamzan Posted August 1, 2014 Share Posted August 1, 2014 Can I come by and pick parts off it Link to comment Share on other sites More sharing options...
kdj Posted August 1, 2014 Share Posted August 1, 2014 Can I come by and pick parts off it Hey Adam let me know what you know what you're looking for. I have a '96 Hardbody as well that parts might fit yours. The Chilkoot has new exhaust, 31X10.5x15 Wranglers, front rotors&brakes all in the last 6 months. Lots of other good stuff. Link to comment Share on other sites More sharing options...
lerch641 Posted August 1, 2014 Share Posted August 1, 2014 Picked up my fifth wheel, and installed my Warn manual hubs. Link to comment Share on other sites More sharing options...
Kingman Posted August 1, 2014 Share Posted August 1, 2014 Readjusted the wheel bearings. Perfect. Link to comment Share on other sites More sharing options...
stovanovich Posted August 2, 2014 Share Posted August 2, 2014 Fitted the new tires & rims. now i just need to find some fresh mud! Link to comment Share on other sites More sharing options...
Slartibartfast Posted August 3, 2014 Share Posted August 3, 2014 Mine did its stall-instead-of-warm-idle routine again, which as usual cleared up after I messed with a few plugs. I figured I'd pull out the coolant temp sensors and clean them better, maybe clean a few other things up, check some wiring... So of course I tore into the throttle body, the EGR, the vacuum lines, and a couple other things that got in the way. I'm fairly sure the EGR valve is supposed to have threads there. Link to comment Share on other sites More sharing options...
adamzan Posted August 3, 2014 Share Posted August 3, 2014 You should probably replace those original looking spark plug wires Link to comment Share on other sites More sharing options...
kdj Posted August 4, 2014 Share Posted August 4, 2014 If I had to do that much work to get mine running well I'd probably junk it. Oh wait I did just junk mine and it runs puuurfect. To bad it has rotted away underneth. Does anyone want some new recall strut repairs? Mine will come off without tools. What a POS. Link to comment Share on other sites More sharing options...
Craig1902 Posted August 4, 2014 Share Posted August 4, 2014 (edited) Fitted new front shocks, tomorrow is towbar install day, picked one up from the yard for $150, its class 4 (50x50mm hitch) and would have been almost $800 new so cant complain. Also picked up new front grill as mine is missing a few mounting point (has 2 left lol) and some rear seat headrests, were missingwhen i got her. Final job for tomorrow is new headlight globes. Edited August 4, 2014 by Craig1902 Link to comment Share on other sites More sharing options...
Slartibartfast Posted August 4, 2014 Share Posted August 4, 2014 Think those are original? I did wonder a bit about the wrapping. Anyone know if Sumitomo was the OEM for plug wires? KDJ, sorry to hear the glue fix crapped out already. Link to comment Share on other sites More sharing options...
CNAM Posted August 5, 2014 Share Posted August 5, 2014 Ugh... started on the timing chain etc... Thermostat was bad for sure. Link to comment Share on other sites More sharing options...
SpecialWarr Posted August 5, 2014 Share Posted August 5, 2014 I had no choice but to replace both tension rods as I broke the rear-most half of one off with the tool that I fabricated over the weekend. I ended up getting both sides done in about 3 hours with my way-too-wide tool that I had to pull on until it hit the torsion bar, take it off turn it around pull another 10mm take it off, turn it around and go at it again..... why didn't you tell me that it needed less than the whole socket length? And I'm just waiting on Canadian Tire to let me know when the DuraTracs are in so I can get them installed just before our annual product launch Link to comment Share on other sites More sharing options...
CDN_S4 Posted August 5, 2014 Share Posted August 5, 2014 Towed my boat with it: Link to comment Share on other sites More sharing options...
stovanovich Posted August 5, 2014 Share Posted August 5, 2014 Took a better photo of the new 32s for all you picture addicts The ladyfriend & I have found some mud to go test them out in this weekend coming too! Link to comment Share on other sites More sharing options...
Rebel526 Posted August 5, 2014 Share Posted August 5, 2014 Fired up the Pathy to move a dead '92 Dakota around the yard to prep it for rebuild. The Pathy, in 4-low, drug the Dakota around like it wasn't even there lol. I've got to get time and funds to get back to working on the Pathy again... Link to comment Share on other sites More sharing options...
CNAM Posted August 5, 2014 Share Posted August 5, 2014 And it continues... 1 Link to comment Share on other sites More sharing options...
kdj Posted August 8, 2014 Share Posted August 8, 2014 Started the new truck on it's diet this afternoon. So far it lost the weight of two rear seat bottoms, a set off running board/step thingys, a set of stick on convex mirrors and $3.78 in change from under said seats. 1 Link to comment Share on other sites More sharing options...
Slartibartfast Posted August 8, 2014 Share Posted August 8, 2014 Took it out for its first drive after cleaning the TB/doing the vac lines. I'm not sure which one it needed, but something sure made a difference! It's still not the fastest thing on the road, but it pulls harder and what I thought was an exhaust leak is gone too. That made me happy. Then I pulled into a parking lot and the engine forgot to idle and stalled out again. Stupid intermittent issues! Tearing into the IACV and the TPS tonight. Link to comment Share on other sites More sharing options...
xterra Posted August 10, 2014 Share Posted August 10, 2014 Replaced the ignition switch and all the locks with new ones from Nissan. The original ignition switch were so badly warn that you could start the truck without the key being all the way in the lock. I can now say definitively that part number 99810-85P28 (for MY93) will work as a substitute for 99810-41G90 (MY90) - and possibly others, too. The plates on the back of the door locks look different, but still fit and work fine. Plus, it doesn't have the annoying button to release the ignition key (BONUS!) The glove box lock cylinder is NOT a match - but it's still cheaper to get the set than the individual parts and then having to mess with getting them re-keyed to all match. Before starting this morning, I made a quick run to the JY since they just got in an '87. Along with other stuff, I pulled the glove box lock so that I had one to fiddle with (before I found out the new cylinder wouldn't work). It must have been fate, though, because the one I picked up is close enough to the new key that I can lock it! Link to comment Share on other sites More sharing options...
adamzan Posted August 10, 2014 Share Posted August 10, 2014 Took it out for its first drive after cleaning the TB/doing the vac lines. I'm not sure which one it needed, but something sure made a difference! It's still not the fastest thing on the road, but it pulls harder and what I thought was an exhaust leak is gone too. That made me happy. Then I pulled into a parking lot and the engine forgot to idle and stalled out again. Stupid intermittent issues! Tearing into the IACV and the TPS tonight. I'm not sure the IACV would cause it to stall. On mine I've pulled the connector for the iacv a couple times and while it will idle poorly (and at like 350 rpm) it still runs. Doesn't stall. Have you looked into the maf sensor wiring? My old wd21 it would act up, wiggle the wires it was ok for a while. Then eventually it did it all the time and i had to get a new connector. Link to comment Share on other sites More sharing options...
Craig1902 Posted August 10, 2014 Share Posted August 10, 2014 New grill from JY put on, old one was missing a few attachment points, and removed old (not working) thermos that were only still on because of laziness, job was a bit of a PITA as I really didn't want to remove the bull bar but at least it's done now Link to comment Share on other sites More sharing options...
stovanovich Posted August 10, 2014 Share Posted August 10, 2014 Had a Night run trip last night. Not too much mud but enough to justify giving the ol' girl a good wash 2 Link to comment Share on other sites More sharing options...
kdj Posted August 11, 2014 Share Posted August 11, 2014 I brought the new truck home on Tues. and today I drove it through a house. I just can't have anything nice! Luckely it was just a Fisher Price playhouse but when it flew out of the bed of a truck I was about to meet on the hyw. it looked mighty big. Anyway the roof panels got jammed up under the bumper and in the passenger wheel well. Crunched up the bumper cover and peeled a bunch of paint. The owner said he wasn't going far so that's why he hadn't bothered to tie it down. Oh well at least he clean up the mess I scattered down the road. Link to comment Share on other sites More sharing options...
Slartibartfast Posted August 11, 2014 Share Posted August 11, 2014 I'm not sure the IACV would cause it to stall. On mine I've pulled the connector for the iacv a couple times and while it will idle poorly (and at like 350 rpm) it still runs. Doesn't stall. Have you looked into the maf sensor wiring? My old wd21 it would act up, wiggle the wires it was ok for a while. Then eventually it did it all the time and i had to get a new connector. Makes sense, especially because the stalling is when it's warm! MAF plug and wiring look mint inside and out, but the plug does have a little wobble to it. Something to keep in mind at least. It stalled out really badly today (while driving, not even at a light) and I pulled over to investigate. Turned out I'd forgotten to plug the EGRC solenoid back in. That probably wasn't helping matters. My next test will probably be the oxygen sensor, though; a friend followed me over a pass today and said he was smelling dirty exhaust and seeing little puffs of smoke. That can't be helping matters either. Link to comment Share on other sites More sharing options...
