ahardb0dy Posted May 30, 2010 Share Posted May 30, 2010 Just noticed yesterday that the rear seat had one ratcheting head rest and one fixed one, than checked the front seats and same thing, so I assume the ratcheting ones were supposed to be for the front seats, so I switched the 2 around, did the Pf's come with 2 ratcheting headrests? Link to comment Share on other sites More sharing options...
Cuong Nguyen Posted May 30, 2010 Share Posted May 30, 2010 ratcheting? I can only adjust height on all of mine. Link to comment Share on other sites More sharing options...
ahardb0dy Posted May 30, 2010 Author Share Posted May 30, 2010 yes 2 of them will ratchet forward about 6 clicks, I swapped a pair into my 90 sentra from a sport coupe also, but just noticed a a pair of them in the PF do it also Link to comment Share on other sites More sharing options...
silverton Posted May 30, 2010 Share Posted May 30, 2010 Mine are also just height adjusting... Link to comment Share on other sites More sharing options...
tmoore4512 Posted June 7, 2010 Share Posted June 7, 2010 Mine are height adjusting as well...ratcheting would be cool... Link to comment Share on other sites More sharing options...
ahardb0dy Posted June 7, 2010 Author Share Posted June 7, 2010 have any of you ever tried to see if they adjust forward as well? I didn't know mine did it until I tried it. Mine have 4 clicks from vertical to forward leaning Link to comment Share on other sites More sharing options...
adamzan Posted June 7, 2010 Share Posted June 7, 2010 The SE cloth and leather have the ratcheting head rests the XE seats don't Link to comment Share on other sites More sharing options...
beastpath Posted June 7, 2010 Share Posted June 7, 2010 The SE cloth and leather have the ratcheting head rests the XE seats don't My SE head rests are definitely not ratcheting. Link to comment Share on other sites More sharing options...
GrimGreg Posted June 7, 2010 Share Posted June 7, 2010 The SE cloth and leather have the ratcheting head rests the XE seats don't Pretty sure my XE seats have them. Link to comment Share on other sites More sharing options...
RedPath88 Posted June 7, 2010 Share Posted June 7, 2010 Pretty sure my SE seats don't have them Adam, you should know better than to generalize trim level specs like that Link to comment Share on other sites More sharing options...
Kingman Posted June 7, 2010 Share Posted June 7, 2010 I'll have to look tomorrow, but I'm pretty sure those suckers don't move forward. Link to comment Share on other sites More sharing options...
TerranoNZ Posted June 7, 2010 Share Posted June 7, 2010 Both mine do Link to comment Share on other sites More sharing options...
Simon Posted June 7, 2010 Share Posted June 7, 2010 With the hole, from what I've found, they ratchet. The "solid block" headrests do not. Link to comment Share on other sites More sharing options...
headpeace Posted June 7, 2010 Share Posted June 7, 2010 Holy Shiite Simon, I quess I'm outta the loop, don't visit poho anymore, I just noticed you are rollin an X now, what happened to your pathy? BTW i have found the same thing with the hole vs solid headrests as Simon Link to comment Share on other sites More sharing options...
Simon Posted June 7, 2010 Share Posted June 7, 2010 About a month ago, the X became available, and I knew the truck and owner. The price was right, and given the mods on it, there wasn't too much that needed to be done. Not to mention, even though it was modified, it was barely wheeled. So I sold the Pathy to Nismojunky,and he's stripped it to use for parts for his and a few others rigs. Link to comment Share on other sites More sharing options...
Tungsten Posted June 7, 2010 Share Posted June 7, 2010 With the hole, from what I've found, they ratchet. The "solid block" headrests do not. Let me go try right now I have the ones with the holes... Link to comment Share on other sites More sharing options...
Simon Posted June 7, 2010 Share Posted June 7, 2010 Yeah, let us know. 2 of them should have a tilt function that ratchets. Link to comment Share on other sites More sharing options...
ahardb0dy Posted June 7, 2010 Author Share Posted June 7, 2010 are the 4 door PF's supposed to have 4 hole type headrests? or 2 hole 2 no hole? Link to comment Share on other sites More sharing options...
Simon Posted June 7, 2010 Share Posted June 7, 2010 No, typically (though, this is not a hard and fast rule) the XE seats have no hole, and the SE/LE seats have the hole. Though, Nissan wasn't great at sticking with trim levels, so you'll find them in either trim line. If it's got the holes in the front, it should have them in the back. Link to comment Share on other sites More sharing options...
ahardb0dy Posted June 7, 2010 Author Share Posted June 7, 2010 Ok, my 94 is an SE, as I said I didn't even know I had them as previous owner had them mixed 1 front 1 rear. Link to comment Share on other sites More sharing options...
