4x4white03 Posted November 30, 2010 Share Posted November 30, 2010 Year: 2003 SE Lift: Stock Wheels: Enkei RT6 17 x 8 w/ 0 offset Tires: BF Goodrich Rugged Trail T/A 265/65/17 Minimal trimming of the front bumper and mud flaps. Drilled new mounting holes for the front portion of the front wheel wells which pushed them forward so that the molded curves wouldn't rub when turning. VERY MINIMAL modifications. 1 Link to comment Share on other sites More sharing options...
Rick13 Posted November 30, 2010 Share Posted November 30, 2010 Year: 2001 LE lift : AC 2" coils + 4" SFD (2.5" coil spring spacers in the back) Wheels : ProComp Xtreme Crawlers (16x8 w/3.75" BS) Tires : Goodyear Wrangler DuraTracs - 285/75/16 (32.8") Notes: Front tires just clear strut coil perch, but have rubbing on wheel well plastic on while turning in reverse and when "bouncing" at any turning angle (I need to borrow a heat gun and also do some minor trimming). The rear tires don't rub at all (even with moderate flexing). 1 Link to comment Share on other sites More sharing options...
kidscollegefund Posted December 24, 2010 Share Posted December 24, 2010 (edited) I'm running 31 x 10.5 on stock 15x7 rims on my '98 SE and thinking of getting new rims, do you think these will work? Part No. AX39855883 Size 15" x 8" Offset -19 Backside 3.75 Edited December 24, 2010 by kidscollegefund Link to comment Share on other sites More sharing options...
Igetstabby Posted January 22, 2011 Share Posted January 22, 2011 (edited) I'm running 31 x 10.5 on stock 15x7 rims on my '98 SE and thinking of getting new rims, do you think these will work? Part No. AX39855883 Size 15" x 8" Offset -19 Backside 3.75 These should work, same spacing and offset as my new rims Mine are 98-5883, Year: 1999 Chilkoot Lift : None, tired coils and dead rear shocks. Wheels : ProComp Xtreme Rock Crawlers (15x8", 3.75" BS, -19mm Offset) Tires : 31x10.5r15 Goodyear Wrangler Territory Notes: Slight rubbing of the plastic at full lock, will be easy to fix. Edited January 22, 2011 by Igetstabby Link to comment Share on other sites More sharing options...
dududuckling Posted January 23, 2011 Share Posted January 23, 2011 (edited) Year: 2000 SE Lift : AC 2" coils Wheels : Stock OEM wheels 16x7" (no wheel adapter) Tires : Michelin X-Ice 265/70/16 for winter and BFG KM2 255/75/16 for summer Notes: For both winter and summer setups, there's no rubbing on struts or inner wheel well when turning at full lock or bouncing at any angle. I had the BFGs before I installed the lift and ARB bumper, that's why they were that small and no rubbing either. Edited January 23, 2011 by dududuckling Link to comment Share on other sites More sharing options...
kidscollegefund Posted January 31, 2011 Share Posted January 31, 2011 These should work, same spacing and offset as my new rims Mine are 98-5883, Year: 1999 Chilkoot Lift : None, tired coils and dead rear shocks. Wheels : ProComp Xtreme Rock Crawlers (15x8", 3.75" BS, -19mm Offset) Tires : 31x10.5r15 Goodyear Wrangler Territory Notes: Slight rubbing of the plastic at full lock, will be easy to fix. Yep, got them, rubbed a bit, heat gun fixed that. Haven't had them off road yet to see if they rub under stress. Link to comment Share on other sites More sharing options...
01silvapathy Posted February 13, 2011 Share Posted February 13, 2011 (edited) Year: 2001 LE 3.5 Lift: AC 2inch Wheels: Stock Double Tri Stars 4.25bs Tires: Stock 255 65 16 Michelin Cross Terrain SUV (Terrible Tires) Lift: AC 2inch Wheels: Stock Double Tri Stars 4.25bs Tires: 285 75 16 BFG At (33x11.5) Notes: 1.5in wheel spacers added to front to allow tires to clear strut and some minor trimming up front of bumper plastic. Lift: 6.5in- Front(4in sfd, 4.5in strut spacers, 2in AC Coils) Rear(2in AC coils, 3in spring spacer) Wheels: Stock Double Tri Stars 4.25bs Tires: 285 75 16 BFG At (33x11.5) Notes: 1.5in wheel spacers added to front to allow tires to clear strut Edited February 13, 2011 by 01silvapathy Link to comment Share on other sites More sharing options...
180sx Posted February 13, 2011 Share Posted February 13, 2011 (edited) Compare the 33's with 2" lift and 6.5" lift, and looks like you need some 34's now! Maybe even 35's on some 10" wide wheels, my friend. And conforming with post guidelines, here is my update: Year: 1996 Lift: Negative (it sags) Wheels: Stock SE 15x7 with 4.25BS (I believe, maybe 4.5?) Tires: 265/75R15 Bridgestone Dueler AT (30.60"x10.43") Notes: No rubbing at all and has plenty of room to clear the strut. Jose Edited February 13, 2011 by 180sx Link to comment Share on other sites More sharing options...
01silvapathy Posted February 13, 2011 Share Posted February 13, 2011 Compare the 33's with 2" lift and 6.5" lift, and looks like you need some 34's now! Maybe even 35's on some 10" wide wheels, my friend. As soon as I get my extended rear links from rugged rocks and new coils out back with some wider rims 35's will be next. Link to comment Share on other sites More sharing options...
clkindred Posted February 22, 2011 Share Posted February 22, 2011 Year: 1998 Model: SE NO LIFT Wheels: Pro Comp 15x7 BS: 3.75 Tires: Goodyear Wrangler Authority in 31 1050 15 Minor rubbing on fender plastic on front. The part behind the bumper. Some minor relocating of the plastic mounting to move it out of the way, now no rubbing ever. Link to comment Share on other sites More sharing options...
Boosted Posted August 24, 2011 Share Posted August 24, 2011 Year: 1996 XE Lift : Stock Suspension Wheels : Cragar Soft 8's 15X8" (4" offset) Tires : Michelin X Radial LT - 31X10.5X15 Notes: Very little rubbing on plastic lining at full-turn in front (not an issue). Link to comment Share on other sites More sharing options...
esy Posted August 25, 2011 Share Posted August 25, 2011 (edited) updated.... Year: 2002 Lift: OME HD 928 front with KYB GR2/Excel G (i have one of each and they are exactly the same) and OME MD 922 rear with KYB Gas a Just Wheels: stock 16" tri-stake Tires : Michelin X Radial LT2 - 255/70/16 obviously no rub. didn't rub before, doesn't rub now. still have a ton of tire left, but am still considering if i should go with 265/70/16 when i get new tires again down the road. not sure since i don't think i can stuff a 265/70/16 into the spare wheel spot without it rubbing on the panhard or my tow hitch. one day i'll grab a tire and see if i can or not or if i can deal with not having a true, full-size spare if i go with the bigger size. no pictures because i'm lazy about taking pictures. sorry. maybe one of these days. haha. iPhone pic. not that great, but it does the job well enough for now. am probably going to be getting some ProComp black steelies in 16x8 with a 3.75" BS sometime in the near future. who knows when exactly, but sometime soon, i'm hoping. Edited October 2, 2011 by esy Link to comment Share on other sites More sharing options...
OBDIII Posted October 18, 2011 Share Posted October 18, 2011 (edited) I'd like to contribute my current setup, the Craigs-Junkyard-List Special! TRUCK: 1997 SE 4x4 5spd LIFT: NO LIFT TIRES:El-Dorado MTZ Sport 265/75/R16 RIMS: 1995 Honda Passport 12 slot Alloys 16x7.5 w/ 4"ish Backspacing VERDICT: No rub in the rear, flexed as far as stock can go(sway bar still connected) Front fender wells I hit with a heat gun and while still gooey I formed them away from the areas where they contacted the bigger tires. There is now at least 1" of clearance at any point all around the tires in the front wheel wells. Cleared the strut no problems. The only rubbing occurs while going in reverse with the steering wheel locked to the right. -Mario Edit: Pics added Edited October 24, 2011 by OBDIII Link to comment Share on other sites More sharing options...
01burgundyQX4 Posted December 22, 2011 Share Posted December 22, 2011 (edited) Year: 2001 QX4 Lift: Stock suspension Wheels: Stock 17" Wheels Tires: 265-70-17 Nitto Terra Grapplers Notes: Had to heat up the front fender liners and re-form the plastic several times. Added new bolts and fender washers between the bumper cover and the bottom of the steel bumper backup to lift the bumper cover and gain front fender clearance. I took out the turn signals/fog lights to heat one side of the fender liners while pushing out on the fender liners with my hand between the tire and the liner. I used leather work gloves and the heat from the heat gun is practically unnoticeable. I think I notice a little rubbing in reverse at times, it's really minor. No problems with the strut, but it is really close. On some severe dips it will bottom out and rub on the front fender flair connections at the top. I think the stock springs are sagging some, and I could add strut spacers and probably fix the bottom out issue, but I think I will raise it 2". I have removed my running boards, the steel frames were pretty rusty. Edited December 22, 2011 by 01burgundyQX4 Link to comment Share on other sites More sharing options...
dynomax Posted January 30, 2012 Share Posted January 30, 2012 Year: 2001 Lift: AC Coils , GR2 Struts, Rancho 9000xl shocks Wheels: stock 16" OEM SE Offset +20 Tires: Firestone Destination MT 265/75R16 Notes: Eventhough the Tire WAS fitting under the strut, there was about 1/16th" of space. fearing that the tire was going to eventually hit the strut at highway speed (expansion), I decided to fit Wheels Spacers 1.25". Had to trim part of the lower front bumper and to recess part of the plastic inner fender. Total about an inch of trimming. Well, first of all, your truck looks great. Problem I'm having is I can't see how even a 265/70/16 will fit let alone a 265/75/16 (Looking at a Duratrac). I don't see a lot of wheels like your saround (these are exactly what I have). I have 245/75/16 right now, and it looks like about 3/4" more room! and my Baja ATZ are wore! Anyway, if you think it'll fit, I am going to try! I am thinking of going w/ the 2" strut spacers up front, and new coils for the rear. I think your truck looks just like what I want. Thanks fro your help. I'm in New Brunswick by the way! Link to comment Share on other sites More sharing options...
fleurys Posted January 30, 2012 Author Share Posted January 30, 2012 answered by pm to keep thread clean Link to comment Share on other sites More sharing options...
Sodero Posted February 7, 2012 Share Posted February 7, 2012 Finally added my lift. Year:1999 Lift: AC 2" with KYB struts,Blistien shocks and NX4 1" spacer in front. wheels/tires stock for now. Won't be for long. Link to comment Share on other sites More sharing options...
shift_love Posted February 10, 2012 Share Posted February 10, 2012 (edited) Year 2001 LE AC 2 inch lift on all four corners kyb excel g on all four corners NX4 1 inch spacer up front cragar soft 8 16x8 4" backspace bfg ta a/t ko 265/75r16 in the rear goodyear wrangler prograde 265/75r16 in the front very little rubbing, only in the bottom inner corner of the bumper when backing out of a parking space at full lock, also removed front splash guards because those were rubbing while turning at lock going forwards Edited February 10, 2012 by shift_love Link to comment Share on other sites More sharing options...
erathge Posted March 5, 2012 Share Posted March 5, 2012 (edited) Year: 2000 SE lift : Stock front, OME 922 rear Wheels : Stock Tires : BFG AT 265/70/16 (30.7") Notes: Used to rub a little at full lock in reverse when new, now they don't at about 50% tread. Old pic, but suspension or wheels/tires haven't changed. Edited March 5, 2012 by erathge 1 Link to comment Share on other sites More sharing options...
accurrate1 Posted March 10, 2012 Share Posted March 10, 2012 Hi Bruce, what part of Taiwan you at? I'm from Taipei, now located in New York! Good to see you!!! Link to comment Share on other sites More sharing options...
Adventure51 Posted March 10, 2012 Share Posted March 10, 2012 Is it possible to go with 4" back spacing with a 305/70x16 or do I need 3.75 back spacing to clear the strut? The wheels I want only come in 4" bs. I have 2" AC coils with 4" SFD. Thanks in advance. Link to comment Share on other sites More sharing options...
02psychopathy Posted September 29, 2012 Share Posted September 29, 2012 Year: 2002 LE lift : Stock (until next week) Wheels: Stock 6 spoke 17" Tires : 245/70/17 General Grabber AT2 NOTE: hahah 255/70/17 will not fit with stock rims 1 Link to comment Share on other sites More sharing options...
ferrariowner123 Posted October 15, 2012 Share Posted October 15, 2012 Year: 1996 SE Lift : Stock Height Wheels : Pro Comp Xtreme Rock Crawler Series 52 Tires : 31" X 10.5" X 15LT Goodyear Wrangler Duratrac's Notes: Trimming Needed to run these at stock height, see pictures. Photo: 2 Link to comment Share on other sites More sharing options...
janseman Posted November 4, 2012 Share Posted November 4, 2012 (edited) Year: 1999 Chilkoot Lift:OME 0.5" springs and OME shocks and struts Wheels:Black Steelies Tires:31x10.5x15 Goodyear Wrangler duratrac Notes:Slight Rubbing in reverse at full lock Here is my pathfinder when I got it, stock steel wheels, and stock suspension, crappy 265/70/15 michelin cross terrain tires This is with OME 0.5" lift springs, OME shocks and struts, stock SE Alloys, 265/70/15 Nokian Vattiva tires and now with the OME suspension and black steel wheels with 31x10.5x15 duratracs Edited November 4, 2012 by janseman Link to comment Share on other sites More sharing options...
projekz Posted November 5, 2012 Share Posted November 5, 2012 Did you got with light duty front springs? Glad you made your made way over here! We should go out wheeling some time. Link to comment Share on other sites More sharing options...
