Roost Posted October 18, 2007 Share Posted October 18, 2007 What have you used, that you would say, is the best P oil that you have used I am using PB Blaster and this stuff seems to kick some serious rusted arse. Semper Fi Link to comment Share on other sites More sharing options...
HitTheTrails Posted October 18, 2007 Share Posted October 18, 2007 I agree with you on PB Blaster, it's works great, I love it. I was using Liquid Wrench for years till I discovered PB Blaster. Link to comment Share on other sites More sharing options...
94extreme Posted October 18, 2007 Share Posted October 18, 2007 What have you used, that you would say, is the best P oil that you have used I am using PB Blaster and this stuff seems to kick some serious rusted arse. Semper Fi that's really the only one that's worth anything.. the liquid wrench is decent.. you know.. you still got wd40 but neither come even close to PBlaster Link to comment Share on other sites More sharing options...
88pathoffroad Posted October 18, 2007 Share Posted October 18, 2007 yeah, PB is greeeeeeeeeaaaaaaaaaaaaaat! Link to comment Share on other sites More sharing options...
yozsi Posted October 19, 2007 Share Posted October 19, 2007 jb80, kicks everythings arse. Link to comment Share on other sites More sharing options...
nige Posted October 19, 2007 Share Posted October 19, 2007 deep creep by seafoam works well. It was able to loosen up an old oxygen sensor so i could remove and replace it. Link to comment Share on other sites More sharing options...
k9sar Posted October 19, 2007 Share Posted October 19, 2007 I swore by silikroil but it's gotten too difficult to find locally. I can pickup PB at the local parts store but I'm not a fan of it being aerosol Link to comment Share on other sites More sharing options...
Roost Posted October 20, 2007 Author Share Posted October 20, 2007 deep creep by seafoam works well. It was able to loosen up an old oxygen sensor so i could remove and replace it. I was able to get my O2 sensor off with the "Blue Wrench". Didn't come out well, though. Link to comment Share on other sites More sharing options...
02silverpathy Posted October 20, 2007 Share Posted October 20, 2007 Yes! Bless the makers of PB blaster! Many knuckles save, though many of my friends use the "soak" time as a chance to smoke an extra cig! Oh, well PB can't save the world ...can it?? Link to comment Share on other sites More sharing options...
unccpathfinder Posted October 21, 2007 Share Posted October 21, 2007 PB is good...it burns the eyes though...WD works good for lubricating things and taking sticky stuff off...I mainly use PB and it helps...sometimes things just need some heat added to get them out.. Link to comment Share on other sites More sharing options...
M in KC Posted October 21, 2007 Share Posted October 21, 2007 PB Blaster, Kroil works well but is hard to find and SeaFoam's Dep Creep. When all that fails a small shape charge. k9sar, I think you can buy Blaster by the gallon or half-gallon and put it in a mister bottle if you don't like aersols. Link to comment Share on other sites More sharing options...
thethirdjq Posted October 22, 2007 Share Posted October 22, 2007 this @!*% gets really helps out in the penetrating heats up too! Link to comment Share on other sites More sharing options...
ardavis78 Posted October 23, 2007 Share Posted October 23, 2007 PB...Fo' Sho'.......KY...PB...Same thing? Link to comment Share on other sites More sharing options...
MikeV Posted October 23, 2007 Share Posted October 23, 2007 PB fo sho! can get the gallon non-aerosol & it comes with a pump... Link to comment Share on other sites More sharing options...
FUELER Posted October 23, 2007 Share Posted October 23, 2007 I've had the best luck with KY jelly. Wait, what are you guys talking about Link to comment Share on other sites More sharing options...
Roost Posted November 10, 2007 Author Share Posted November 10, 2007 A new trick I just used and it worked. Heated up the metal around the bolt with a propane torch. Then hit it with the PB blaster, reheated and then turned the bolt out with vise grips. It was on the exhaust system that had not be touched in over 12 years. Link to comment Share on other sites More sharing options...
yozsi Posted November 11, 2007 Share Posted November 11, 2007 wd works great as a starter fluid, been using it to start diesels for a long time. Link to comment Share on other sites More sharing options...
GrimGreg Posted November 11, 2007 Share Posted November 11, 2007 A new trick I just used and it worked. Heated up the metal around the bolt with a propane torch. Then hit it with the PB blaster, reheated and then turned the bolt out with vise grips. It was on the exhaust system that had not be touched in over 12 years. Another good trick, hit the bolt with some candle wax while it is hot. The wax will melt into the threads making it nice and smooth. For cold work I've used Thrust and PB, both work great. Link to comment Share on other sites More sharing options...
daftpup Posted November 11, 2007 Share Posted November 11, 2007 Peanut Butter? Link to comment Share on other sites More sharing options...
Mr. Pickles Posted November 12, 2007 Share Posted November 12, 2007 PB is awesome, especially with repeated soakings over a few hours/days. That, a BFH, and an 18" long 1/2" breaker bar with a 3' cheater pipe, seems to be enough manipulation for most things... Link to comment Share on other sites More sharing options...
