He is very correct. Remove cluster and drive around and see if the needle spins. What happens to our old pathfinders is over time the plastic pieces become brittle, cracking and braking. The plastic housing that holds the needle cracks so essentially the cable spins but not the needle. You can remove the pieces: plastic needle, plastic housing, and spring. clean the housing for the needle real well and superglue the cracks and let it cure, if it's beyond repairable, you will need to find a replacement cable. Also, be aware that the plastic backing behind the cluster where the needle sits in gets real brittle too and cracks. you can probable glue that together as well. I know I was able to.
