320
I bought these from this guy: http://www.ebay.com/itm/161990333202. I even paid $9 more than what he's asking now ($20.48). Fits 21mm socket, too, same as stock.
I also know firsthand that you can drive this FJ Cruiser wheel 80 miles, with acorns lugs, on a Saturday evening, in the middle of the desert, to the only tire installer in a 150-mile radius that is still open, has 4 tires in the same size, and that size is >31", after completely destroying two Duratracs within 20 minutes of each other. The offset was about perfect, I might add.
I have current-gen 4Runner 17" on my 98 Frontier 2wd. Same bolt 6x5.5 bolt pattern and 100mm wheel bore as the Pathfinder. Bought 100-106mm hub centric rings, M12x1.25 mag-style lugs, and wheel locks on eBay to make it all work. Backspacing comparisons will vary based on the rim of choice. These ones (17x7) have less backspacing than my stock 16x7, so they stick out a little further. I have a spare wheel in this style if you want any dimensions or comparisons. I plan to put these on the Pathfinder, too, when it's time to replace the tires. TowndawgR50 put a set of Tacoma wheels on his before, I think, but maybe only for mocking up?
Funny you ask...although I'm not a coffee drinker, my wife is, and I've been meaning to find a portable or single serving unit for her. But the wattages are just too high (or rather, I don't want to buy an inverter large enough to support it). For now, she'll have to settle for the Starbucks Via packs.
Thanks man, appreciate it! Yeah, there were definitely compromises to be made, and I think this was the best of all worlds for my needs. Biggest function for me is actually the cargo barrier...Ive always found the placement of the tie-down points to be poor, and with two young kids, everything needs to be secured. Itll be put to the test Thursday night when I pack it up, and more so on Friday when we do a trail run before setting up camp. I have two of those black/yellow bins with kitchen and misc camp gear. My goal is to not bring one of them, instead filling the crates (which I hurried to make basic lids for them on Sunday before leaving town) with the misc gear, recovery gear, and tools...each which tend to have their own containers that kill space. Having access to the floor bin was a must for me, since its valuable space for storing seldom-needed spare parts that I dont want cluttering crate space. The other thing is that this is really only phase 1 for the rack. My phase 2 plan is to mount up some other components, like a water pump with DIY on-demand hot water, power inverter, and dual battery. Space permitting, maybe even a little 8 sub box in the cavity above the LH wheel well, since its an awkward space. Its all been in my head for a while now, just need to make it happen.
Good, and yes, it is critical. My buddy's truck, without link, recently failed. It weakened the subframe at the right rear, ripping the mounting pad from the subframe, and the block from the chassis. It's had me thinking about a reinforcement setup as you described. If the blocks you have are the simple tube, I have general concerns about that. For those bushings, you're talking about the hangers/brackets on the axle housing?
Agree with XPLORx4 on the motor mounts...best time to change those. @XPLORx4: do you have, or are you adding, a missing link?
Alright, went a very different direction on the hinges. The ones I got just took too much pulling power to open and unlock, the bodies weren't square enough. I was hoping to find at least a softer spring and get some better steel tube, but that ended up being a waste of time. Instead, McMaster Carr has a good supply of weld-on pull handles. Don't look too closely at the welds...you'll go blind. My first pass at this was a bit better...and then I realized I didn't check another dimension and had to completely cut, grind, and do it all over. Lesson learned: check fitment after tacking, before finishing welds. Opposite of that is just a peg acting as the other hinge: With this setup, I just have to pull the T-handle and tilt the tailgate off...well...one other thing, too, but still super easy! The upper thing on the hinge bracket is a ball stud for a miniature strut. I struggled to find a conventional way to keep the tailgate up, so instead came up with a clever way to keep it up and also add extension support... Got the strut from McMaster Carr for $11. This one is from their "add-a-fitting" line, which comes with threaded ends for customizing the fittings. Got one end to have a standard fitting, and the other with a quick-release. When the tailgate is down, pressure is off the spring and it can disconnected easily. Went with a 40# strut, which ends up being a pretty good option, not to hard or soft to pull. I bought some snap-in nylon bushings that give just the right amount of tolerance without metal-metal contact. Still need to put them on the bottom, but they're installed on the upper mount. I was hoping to swap the hinge brackets so that the larger one wasn't in the shelf space, but it was unavoidable. If the strut were on the LH side of the rack, it'd interfere with the lower shelf...I could have put the strut on the outside, but then it would've gone into useful floor space. Oh well. Got the floor mounts in... Relocated the jack, cut up the carpet to clear the mounts and also make the floor bin accessible... And it's in! Still have a few more things to do, though. Need to add some tie-down points (will be re-using the floor tie downs I have from Harbor Freight...in case you don't know, these are a direct fit: https://www.harborfreight.com/2-pc-14-in-cargo-d-ring-anchor-60319.html) and attach the wood inserts for the tailgate. Not going to be able to paint it before heading out of town for work, and before next weekend's CANVAZ run, but that's ok.
Did you post up some pics of other brake backing plates, and if so, which did yours look like? If it's for the 87 SE in your profile, based on a quick search of the RH adjuster, p/n 44200-31G10, it looks like any 86-89 D21 4WD (2.4L or 3.0L) and 87-89 WD21 will work. Even if it has the C200 axle, they are very similar axles. The axle shafts are practically identical, and otherwise dimensionally the same with exception of the differential and gears.
Thanks Kyle! Little bit of an update...didn't make much traction during another lousy work week, but made it a point to unwind and move this project forward. I decided to use these as the tailgate's hinge pins, which will also allow the gate to be removable. 5/8" pins, weldable bodies, $11/ea on Amazon. I started welding up the tailgate today. I made a bit more progress than shown below, but this is the idea: The tailgate is 14" x 45", almost 4.4 sqft. It'll have ribbing for support, and 1/2"-thick birch plywood panels for the surface. I don't plan to have support cables, but am still throwing around ideas on how to keep it upright and/or latched. I don't want to undo more than the hinge pins to remove it. Right now, I have an idea to make it spring loaded. I struggled figuring out how to secure the rack to the truck. Bunchie's suggestions to use either the bicycle-style cam locks ("quick positioning cam handles" at McMaster) or threaded knobs looked promising, but hardware costs and security became factors. The cams seem great, but are a pricey solution to satisfy 4 mounting points. The sizes on the threaded knobs are a little too big for how I had begun setting up the mounting points, and I didn't feel like redoing that work. Plus, the only affordable ones were plastic, and I couldn't trust that. The metal ones were too pricey. My original idea, just required too much in parts and precision to justify making it tool-less. It hindsight, I would have been better off making some sort of hook bracket for the rear of the rack that it just slides into, and then would only need two fasteners at the front (rear of the vehicle) to secure it. I decided to take the KISS approach and just buy socket bolts, fender washers, and an 8mm Allen key for <$10. Minimal tool use and a more secure approach. The rack will sit atop metal blocks that bolt where the tie-down points are, with the socket bolts threading into a rivet nut. All the cargo rack weight will rest on the blocks and not the carpet. I'll get some better pics of the mounting solution once the blocks are all finished. Once the tailgate and mounting system are sorted, the rack can be pulled from the truck and set up like this: The top of the rack will have the same hinge pin holes. Surface height ends up being 29", which works out well. The reason I wanted to keep the mounting feet on the rack like shown is so that I can just drive a tent stake into the front feet to prevent it from falling backwards (of course, my kitchen gear and cooler would also be sitting on the rack for additional weight). Anyway, still a work in progress. I decided that I'm just going to paint it with a gray enamel, since I have some rattle cans leftover in that flavor. I'll also be painting that old Coleman cooler, but instead in a hunter or olive green. Didn't post these up before, but here's how the milk crates fit in:
R50 Tire Carrier Mod: Let's settle this!
hawairish replied to hawairish's topic in 96-2004 R50 Pathfinders
Good idea. Funny you mention them...I've been parked at their website for the past few days trying to figure out some ideas for the cargo rack project. -
Nice, jjonez! I'm really glad this approach has become viable for others. I tried something similar with the foam pads, instead using a neoprene sheet, but yeah, it needs to be thin and compressed like 1/16" rubber sheet (which, btw, is what was originally used...I tried to get the OE pieces but they are NLA). I ended up not using anything, but may revisit it at some point. Glad the fender washers approach worked. And yes, if there's any concern for damage, it's if the carrier opens too quickly. Be very mindful of this. There's not really a good solution for this. In my case, since I'm using bolts and not the OE pins, I can tighten them up to slow down movement. I may reconsider the placement of the liftgate strut I also use to control opening. -
97 Pathy R50 Dead rear axle. Advise!
hawairish replied to Mattmill91's topic in 96-2004 R50 Pathfinders
Not the case here. There's an inner oil seal that seats near the end of axle tube, and it seals against the axle shaft to keep gear oil out of the bearing cup. There's also a large o-ring on the outside of the end of the axle tube to keep the elements out. Lastly, the grease seal that's sandwiched between the axle shaft hub and the bearing cup is what keeps the grease in bearing. I'm planning to reassemble all the loose parts I have sitting to make complete axle shaft assemblies. If I get a free hand, I'll try to capture some pics of the process. (Mattmill91: if you think you could use the finished assemblies, let me know.) -
And btw, there are bearings on clearance at RockAuto right now, $9/ea. -
That's the thing...you can't really do any PM on them. You can inspect them, if you're willing to undo all the brakes lines and pull the assemblies out, but that's about it. One bearing is completely obstructed, and the other barely accessible...you need some pretty hefty syringe to inject grease into the bearings. At least with the assembly out you could try to sense any bearing issues, but for that trouble, may as well consider redoing the bearings anyway. -
Surprisingly, this actually isn't an unexpected result for this sort of failure. It's inherent to the semi-float axle design we have. The only thing that keeps the axle shaft attached to the truck is the wheel bearing. It's highly improbable that the shaft will actually slide out of the bearing (they require several tons of force to press together), but it only takes a couple dislodged or damaged rollers to allow the cone to slip from the race. In his 2nd to last pic, you can see that the inner cone has this massive score halfway up the cone, and a lip on the cone—where the outside of the rollers would rest against—is completely gone. The weakest link, then, is the bearing. Although there's a plastic retainer that seems flimsy, it's function is pretty low-duty. But like any bearing, debris, poor/deteriorated lubrication (i.e., water, gear oil contamination), and heat will be the death of it. Once a roller binds, it becomes a chain reaction, imminent doom. -
0.17° is correct, with a min of -0.58° and max 0.92°. Difference between the L and R side should be less than 0.75°. Values are in the FSM, in SUspension chapter. Check the SDS section at the end of Front Suspension.
Bunchie, that's excellent idea! My original plan had it 32", but ended up being 30.5". Pretty close, but it was a trade-off height to clear the rear opening when removing. Going off that suggestion, a fold-up platform on the backside of the rack would be great. That would keep all the gear accessible, and give me space. I bought a pair of folding/locking shelf brackets (https://www.amazon.com/gp/product/B00F9O4YPY/) for a project but haven't used them yet. Only problem with this approach is that it consumes space between rack and seats. I have a little space to work with, but was reserving the space for some other stuff. Since I intend to make a tailgate, and it'll be detachable, I could make it attachable to the top of the rack. The tailgate wouldn't be useful near the ground, and for the size I want, it needs to be detachable for removing the rack anyway. I think that's the best approach, and doesn't add any more weight. I'll have to rethink the mounting now. I made a decision yesterday and welded on mounting feet, taking a bolt-down approach. Didn't take a picture,and can't upload a sketch of it right now, but I took 1.5" x 2.5" x .125" wall tube steel, cut pieces to length, each with 90° cut on one side and 45° on the other, and welded them to the base. The 45° cut allows overhead socket access, and holes at the bottom will allow bolting to all 8 bolt holes for the anchors. I could keep that approach, but drill a single hole in each mount instead of 2 holes. Then, I can make a tee-like bracket with a clevis pin or bolt welded to it as a post. The mounts would just lift over the post and then hitch pin or nut/wingnut secures it. That would make it tool-less, and also solves another problem, where I need some sort of spacer to account for the carpet thickness. Despite all that, you've now got me thinking about cutting those mounts off and going yet another approach. Something where I can just slide the rack into place. Thanks for the suggestion! Back to the drawing board!
Hey fellas, I presume you're talking about the cables that connect to the backing plates and not the central cable coming from the lever? If so, I have two sets of brake cables for disc brake WD21s in my stash. One set doesn't have the springs on the very end of them because I used them for my disc brake swap...surely you could re-use yours (they can be twisted on/off by opening the springs ends a little). Haven't looked at them for a while, but I believe them to be in good shape...I'll have to take a look at them when I get home later today. Lemme know if I can help.
Yeah, the handles are solid. I usually do loop through them. I just don't want to have to loop through the back handle. I also decided it's time for that cooler to get re-painted...I have some leftover Obsidian Black Pearl spray from my WRX days. The red on there is probably lead-based, with a layer of asbestos inside that makes it keep cool better than anything else I've used. Thanks!
You'll probably need to tap it on all sides with a rubber mallet...at some point you might get enough clearance to wedge a prybar or flat screwdriver near the bolt holes. The part you see coming outside the cup isn't the race, it's part of the casting. You can also try twisting the cup clockwise or counter-clockwise. That might break any rust buildup and give you a flat surface to tap against. A punch on one of the bolt hole ears ought to get it started. -
I plan to use ratchet straps. I have enough spare straps to cut them down to specific lengths on the rack. There are a few points where I will add a loop, or some other form of adjustable attachment point. But yes, I liked the lattice approach since it makes the attachment points variable for whatever I might have on the rack. The cooler strapping is something I'm still figuring out. I could easily strap over the top and body, but I want to keep it accessible by just opening the liftgate glass. A strap around the body alone will keep it pinned against the rack, but if the cooler lifts for any reason, it may create slack. I'm thinking I might modify the cooler with some sort of cleat that seats into the rack and would simplify the attachment process.
Thanks! Yeah, I've been sitting on this welder for several months now...hadn't even opened the box until the other week...very nervous about starting, figuring something (me) would catch fire. I wish I hadn't waited so long, but it became a must-try recently, and I'm definitely enjoying it. This opens a major door for me. Doubt I'll be welding up bumpers with this little thing, but it'll help me get the ball rolling on several truck projects that I've been needing to start. I'll definitely keep this updated with progress. I'd like to get the tailgate in place if I can before my trip. Stay tuned.
Lol, yeah, drilling that first hole into metal is tough one! Good deal. Yeah, worth a shot taking the bolt approach. Toughest thing might be having full tool access to work both inside and outside the truck to get the hardware tightened. Get whatever assistance you can ensuring that the carrier's weight isn't resting on too few rivnuts/bolts, otherwise it will distort the body metal. I found it easiest to work with the gate closed, some wood that supports the carrier gate at the same level it will be when closed. Also be mindful if using larger washers inside the panel that the edge of the washer might press the body steel outward on some curves. May want to use a ball peen hammer to cup the washers maybe? -
Got more things tacked up for my cargo rack and fitment checks. Work in progress! http://www.nissanpathfinders.net/forum/topic/43634-cargo-rack/
