hawairish
  1. And maybe with your busted engine, spare transmission and t-case...I'll VQ swap and SAS my 2WD Frontier! I would love to do a 5MT swap on the R50, too, though...hmmm.....
  2. So are the 1988 ones different from the disc brake cables from trucks up to 95? Maybe I misread a post above.
  3. Probably too late to use "Nis10" as a discount for Courtesy parts?
  4. Well, I found a few JDM Pathfinder engines on eBay that have that different passenger motor mount plate. This one seemed to have some good pics: https://www.ebay.com/itm/253387604846
  5. Excellent! Yes, looks like it was found.
  6. Kent, I really hate to mention this, but I'm a bit curious about that engine. For one, it's got the aluminum valve covers...looks like a 2001 engine. Two, those motor mounts...I don't recognize that. Ours are taller, the two studs are oriented 90° from shown, and that plate would prevent it from mounting to the subframe. However...I would be fairly confident that the upper motor mount bracket from your engine would carry over to the block and your motor mounts re-used. The upper oil pan looks the same, at least. And man, your upper pan is pristine compared to the donor!
  7. Works for me! I get the sentimental value part. While I don't care for my car from high school (86 Mazda 323 sedan), my 98 Frontier from college is still around. Well, be mindful that converting to 4wd will require far more than just the drivetrain, and for everything you'll have to remove, you'll have to do it twice. Center console, gauge cluster possibly for the 4wd lights (they might only need bulbs, not sure...but consider any issues with the differences in miles on the gauge if you have to swap them), TCU, ECU possibly, all wiring harnesses, etc. The drivetrain stuff is probably the easiest, it'll be all the little things that might wear someone down.
  8. Just curious, by why swap vs. buying a used 4WD? Seems like a massive undertaking, even with a full donor. I'm inclined to think everything up to 04 will suffice.
  9. Wait...I was pretty sure the plastic covers (02-04) all used the same coil packs for all positions. Also, I should add that my buddy has an 02 and there's an 03 engine in his truck. Casualty of the power valve screw. His swap was done by a shop, and I know with certainty it's drive-by-cable. I'll check with him if he remembers anything extra about the swap, but I really don't think there was anything special.
  10. Yes, and then there were the valve covers...if I'm not mistaken, the coil packs in the 03-04 models are the same as the 02 models with the plastic valve covers. It's the 01 that had the aluminums where the #1 coil was different from coils #2-6 because of a boss on the cover. I want to say later 01 models had plastic valve covers, too. RockAuto shows a split at 7/01...might have classified as 02 models.
  11. I agree there are some subtle differences, but is there certainty that they are what differentiate the newer from older engines, instead of just being part improvements that coincide with the model change? For instance, the cam sprockets have different p/ns, but the cams, camshaft sensors, and timing chains are unchanged...so would any cam sprocket variances be significant? Why would O2 sensors matter? You're reusing yours, plus the exhaust manifolds. Upper oil pan? That should only matter if the 03-04 transmissions changed mounting style. But, let's put it this way: if the shop has concern about differences, just go with it. Bottom line is they are different, but perhaps not enough to matter if you were to DIY. If you force them to pursue work based the interwebs, it's going to blow up in your face. There are surely plenty of 01-02 donors that will eliminate any guesswork, so I'd go that route.
  12. If you're in the Corona or SoCal region, keep an eye out. Steven Lutz, of Rugged Rocks, had his truck stolen. https://www.facebook.com/steeevo85/posts/10159965155375471 Hope it's found, Steven!
  13. There's another similar post the other day (http://www.nissanpathfinders.net/forum/topic/43916-some-quick-help-needed/). Most notable difference is 03-04 are drive-by-wire, everything prior drive-by-cable. So just bring over the throttle body and check for any coolant plumbing differences. Beyond that, they were pretty much identical. If anything else appears different, should be able to bring over from your engine. Bummer about the engine, though. What did it in?
  14. We're talking the cable that connects to the parking brake shoes? If so, I have a set from a 94 I think. They don't have the springs at the ends (re-used for my disc swap), but you can re-use your spring. I can get some pics up if that'll help.
  15. Check out the post about Land Rover springs for the rear, if you haven't already. Bummer about the engine being sold.
  16. Worth every penny. I'd lock the front diff first, though.
  17. I've got OME MD springs up front right now. It's time to overhaul my suspension, so I will be switching to OME HDs, among several other modifications front and rear. Having the engine in isn't terrible, though. I've run a few SFD sizes on my truck and installed on another. Nothing complicated, just time consuming. I'd say get it back on the road first. With a looming engine swap, that's already plenty of work to handle in one shot.
  18. Thanks for the encouragement, fellas! As an update, I've requested quotes from local shops for the cutting services. The current quote from my steel supply shop is reasonable, but is only for two bracket sets plus some new front skids. I'm waiting for quotes for a batch of five sets before trying to determine a price, but I'm optimistically looking at a retail of under $200 for the brackets (unwelded), all hardware, and US shipping. Ideally, it would be best if I could mimic mounting points on the XJ (I believe that's what you meant), since there's no assurance that all aftermarket bumpers for the same vehicle use the same mounting points. But, I think eventually if the community can settle on specific bumpers (or vehicles) to use, then this is a possibility. The bracket would need a minor redesign to omit using a winch channel and shackle mounts. If anyone in my region wants to explore that as an option, it'd be helpful to have that bumper in hand to mock things up. It'll still be a several days until I can get brackets made, but in the meantime, I've been mocking up my bumper. Getting ideal angles was more annoying than I thought it would be. The overflow coolant tank limits the angle a little, but it's that stupid pre-airbox tank that makes you want to slap a Nissan engineer. Short of a plate bumper, there's no good looking way to protect it. Aside from sticking out in every direction, I also haven't figured out a simple way to re-work the bracket that supports it either, short of just drilling new holes. It will eventually be removed...thinking about a hidden snorkel. It'll probably get ripped off by a rock before that, though. Here's the full concept... Construction will be 1.5" x .120 sq. tube, and some same-sized angle steel on the top under the headlights and above the winch. The only modification to the bumper brackets is cutting the green pieces. (Though, I'm gonna cheat a little and just have those pieces cut to size when everything is made.) And in case you're wondering how the skids will turn out... Plates will be 3/16" this time around. The Pathfinder piece is a separate mini-skid for shielding the exposed power steering line on the VQ trucks. The material from the port openings is repurposed to create ribs on the skid—they'll be plug welded on the front, and stitch welded on that back. Both plates are notched so that I can just loosen the bolts a little and slide the plates off or on. My mid skid and missing link will eventually get reworked, but for now are in good shape.
  19. My strut spacers are just two stacked 1.5" spacers, no angles involved. I've got a single set of camber bolts to align it.
  20. This is correct. The cruise control unit is also cable driven, but I think the brackets and cable guides are shared with the cable for the TB. Either way, those brackets should already be on the 03 engine (they are on my 04). And definitely, not having a motor in the way would lighten things up and give super easy access to the motor mounts if installing an SFD.
  21. Yes. The upper manifold is the same; the lower manifold is AT/MT specific. The blocks are the same, so I can't think of anything else that would be of concern.
  22. Holy rust work! So glad I don't live in rust-prone environments! Though, I have to say that for a $400 USD panel available from Nissan, that's a very nice option. I didn't realize that was still available.
  23. It should never be necessary to remove the steering wheel to address that issue. But in doing that, are you certain all wiring harnesses were reconnected? I presume the vehicle had the tires on the ground, preventing you from over-rotating the steering shaft and potentially damaging the clock spring. There isn't a correlation between changing ball joints and the steering wheel alignment. Even if you completely removed the spindle from the truck, having freed the outer tie rod from the knuckle, the length of the tie rods doesn't change unless you change it deliberately. Correcting the steering wheel position should have been done by adjusting the tie rod length on both sides; basically an alignment. If those were of equal length already, then you could have clocked the steering linkage between the steering rack and pivot box. If the steering wheel alignment was fine before starting work on the truck, then you'll need to think about other steps that would have affected alignment...there really aren't any when changing the ball joints. I find that my truck's steering wheel position is fairly sensitive to tire pressure, so an under-inflated tire appears to create pull on the vehicle. When you're in diagnostic mode, it either blinks the error code(s) or the no-error code. It's a very simple procedure, literally: open the door, turn the key to ON (engine not started), press the door jamb switch 5 times within 7s. The door switch needs to be functional, of course. If you're not sure, you can ground the terminal to the chassis. From the same link I provided, also see page RS-36 for the diagnostic codes. What is the blinking pattern you are seeing? Unless your OBD-II scanner has more diagnostic features, it can't read the SRS codes. I have diagnostic scanner that can read SRS codes, but neither my 98 Frontier or 04 R50 could be read by it. It's a separate module and system.
  24. Dude! Glad you've found the next happy place in off-roading, and glad it was the R50 that got you there. Being a former JK owner myself, I totally get it...of course, there are still some Jeep things I don't want to understand. Thanks for the shoutout. Glad to have been of assistance. Pop in every now and then with some pics! Take care!
  25. This didn't work? http://www.nissanpathfinders.net/forum/topic/43728-how-to-reset-airbag-light-98-pathfinder/?p=794309 What code is it throwing? If you're not getting one, then you're not in diagnostic mode; even "no code" has a code. But when if resetting it, if an issue still persists, it'll just throw that code again during the next self-test. What do you mean by "aligned my steering wheel"? Was it aligned before, and if so, how did that change during a ball joint change?
