320
Hopefully the bushings work. They are actually the same poly bushings for the trailing arms. Dimensions are very similar, and the bushings get us very close but there were some dimensions we debated about without having precise specs and preload values from the bushing manufacturer(s). I'm optimistic it'll work, or that we can get it to work with minimal modification. I just use a floor jack under the diff, too, with a little help to support the passenger tube to keep it level. When installing, I'll put a jack stand under the passenger tube and fine tune the diff height until I can get a bolt through the bracket and into the diff. I don't remove the brackets from the truck when dropping the diff, so if you're planning to swap the bushings, just get the diff out first then the brackets.
Thanks for addressing all the questions! This seems to make the most sense at this point, and it's the "under load" part that's key, when small vibrations are locked to the rest of the truck.
DIY winch bumper 'builder' brackets
hawairish replied to hawairish's topic in 96-2004 R50 Pathfinders
No promises, of course. Buying another bumper is somewhat out of the budget, but I'd also need a 96-00 truck to see if what dimensional differences exist for the grille. Since XJ bumpers will mount higher, the bumper would need to protrude forward for the winch to clear the grille. As mentioned earlier, it'd also have to be for a specific aftermarket bumper. TowndawgR50 is going to get me some dimensions from his setup so can assess what would be necessary. Precisely. Everything fits into a flat-rate USPS box. -
Can't contribute to the battery questions, noting that a dual battery system is also on my mind. I've installed my MV50 both in the rear cubby and under the hood where the cruise control stuff is on yours, all of which doesn't exist on 03-04 models because of the drive-by-wire setup. Mounting it where I've got it required a bit of modification to the compressor and brackets, and it's a tight fit. Surprisingly, I don't seem to have any pics handy of the setup. I would also advocate finding a way to mount under the chassis. Too loud in the cab, too tight under the hood. I've only had it overheat once, and that was after starting inflation on a 7th tire during the stop (did my 32's and then buddy's 33's). Can't say I've tried in a typical AZ summer day, but for sure haven't had a problem going from 15psi to 34psi with hood closed after the engine is warmed up. Once you're able to do the tire carrier install, that'll free up a ton of space underneath. To defend against the elements, see if you can find an appropriately size Rubbermaid or other plastic container that has a snap-able lid. Then just drill some holes to match the mounting pattern, and some more for air input/output.
I'd suspect that a qualified welder could have the brackets and nut strips welded up under 2 hours, if I'm understanding the question correctly. I probably took twice that because I am far from qualified, which is why nothing is coming pre-welded. -
A chance. I've not had a moment to try to rework any files to fix that ghosting problem or make any other adjustments. The steel shop usually has a 3-5 day lead time. That could get them out the door before next weekend if everything goes smoothly. Let me see what I can accomplish this week. -
I'm in west Phx, swing on by! I'm just up the 303 a few miles. Disconnecting the upper panhard mount is easier than the bottom, btw. Also, trick is to support the chassis as high as you can safely go...I used to get by with just my jackstands, but with the amount of lift now, it's gotta be jackstands plus some base. It's gonna be interesting when I swap in LR springs and redo the trailing arms...
If you've got a particular cut-off point, I'd love to hear it. Right now, I am decently under the $200 mark, shipped (US only for now). Still crunching the numbers, but price is also dependent on how many I can get in the batch. Thanks man! I plan to have some extras made during the 1st batch, mainly because it drives down the prices for everyone if I can bump up quantities. I'll hold one for ya, just getting a general headcount for now. But yes, I am still building a bumper off these. Gotta demonstrate proof of concept! Meant to start cutting the tubes tonight, but opted to go fly kites with my kids. Priorities, right? One thing I was originally planning to do (I don't think I mentioned it earlier) was to add a 2" receiver tube. Harbor freight sells "step bumper receivers" that I was considering to bolt or weld (or both) to the bottom of the winch channel. These guys...p/n 69673: 3,500lb @ $19 and p/n 69670: 5000lb @ $22: The only catch is that if you use a roller fairlead like I'm using, you'll need some sort of 3/4" spacers between channel bottom and receiver plate to clear the bottom of the fairlead. If using a hawse fairlead...just figure out how you want to attach it and you're good to go! I opted to not go that route because I don't think I'll use it that much (for sure not for recovery since I'll already have 4 attachment points). If I ever get/build a trailer, I'll reconsider it since it would surely simplify maneuvering through my side gate. Yes, the inherent problems from probably worst to "less" worse in my opinion are 1) tight angles, 2) piercing, 3) cutting stops where the plasma cutter is turning off while stationary over a position, 4) small geometries, and 5) redirections, like changing 90° as you can see in the letters. #1 was particularly bad in one of those images, and it's clear the pathing software doesn't account for kerf width (cut diameter) to create a path that won't overlap...but, I only have 3 spots that meet that criteria and I can fix those. The pathing software does, however, start all cuts off the path unless it's just a line. I have an application that can generate tool paths, but it's for my CNC router, which can be set to run inside, outside, or "on" a given path, and the 3-axis that plunges into a path to start. I think with 2-axis CNC processes like plasma cutting, it's just "on" a path. But in regards to that, ti worked out fine. Only thing is that it adds half-kerf to the line...and basically kerf-width to some shapes. The width is relatively small, but not negligible. And the thicker the metal, the larger it'll get. #4 is a tough one. Most of the holes are 9/16" to give reasonable tolerance for a 1/2" bolt. Well, holes were probably closer to 5/8" than 11/16", and also not "perfectly" round, but close. I may put a 1/2" circle on my drawings and let the process add tolerance. There are some 1/4"-diameter semicircles/notches that didn't come out that too nice...but, I don't need them to be as they're just aid with assembly. There's a very good possibility I pick up a CNC plasma cutter in the coming months to save myself a LOT of hassle I've experienced with the industry here, in general. I have way too many pending projects that will rely on a process that's still far from smooth, and I think I can cut out the middleman in that regard. -
I feel like I've read this post a dozen times and I'm still totally baffled. But, I'll throw some ideas and other questions out there anyway... You changed the t-case fluid...what fluid did you use, and presumably it got filled to the bottom of the fill hole? How are your motor mounts, or transmission mount? Are the motor mount spacers secured properly? Do you have a missing link? If not, entertain me by carefully inspecting the subframe just above the rear LCA bushings. How are the bushings on the front differential brackets? Might be hard to see all of them, but give them a look. I had similar thoughts about the front diff as onespiritbrain. His procedure would check for broken teeth on gears, but you probably would have found bits when changing the fluids. But, still worth checking. It's easier to just lock the hub, leave in 2wd, and lift the wheel off the ground. Spin the tire very slowly and watch the front driveshaft. Could also try locking the hubs, engaging 4H, unlocking the hubs, then take it for a spin. Can also engage one hub at time (i.e., 3wd) and see if anything changes. As for the t-case not disengaging, that seems independent of the shakes, and more likely to be fluid dependent. System won't know if the truck is turning left or right, just needs a moment to de-couple. You can test the disengagement sensitivity by leaving the truck in 4H when the lever is in 2H and then rotating a tire (hubs locked) or the front driveshaft (hubs unlocked) and seeing how little rotation in one direction will disengage the coupling sleeve in the t-case. Couple ways to get there, but basically, put it in 4H, drive straight forward until 4wd dash light is on, come to stop, then shift into 2H (yes, normally you wouldn't do this, but make an exception). At that point, the lever is in 2H, but truck is 4H...you can shut off the truck and return to the ON position, not-started. Don't forget there's also a switch that controls that light, so might be worth checking its signal (i.e., remove and check continuity).
Custom Spare Tire & Jerry Can Carrier Drawings
hawairish replied to SYNCHROMASH's topic in 96-2004 R50 Pathfinders
Yes, he did have a hitch-mount carrier at one point, then eventually did the tire carrier mod. This particular carrier Ive always been a fan of. Its the reason I had he link handy. Just used it the other week, actually, to reference some dimensions on his skid plate (though, we seem to have different dimensions). His bumper wouldnt suit me due to the departure angle losses, but its an excellent solution nonetheless. Move everything up to replace the OE bumper and itd be killer. -
All good! You can pay the community back by posting up your version of the project. The owner's email is at the bottom of the main page. -
Free$: https://sites.google.com/site/r50projects4free/home Specifically for your request: https://sites.google.com/site/r50projects4free/EDDMS_REAR_WHEEL_CARRIER.pdf -
Oh...and can I get show of virtual hands of those with interest in these? I have a quote for a small batch (5) and hope to start talking prices soon. -
Parts are finally real... They turned out well, but admittedly, I'm not over the moon about them. Not at all bad for a first pass, but I expected some parts to come out a little more precise. However...I think part of it is inherent and unavoidable due to the plasma cutting process, but the shop also had some issues with my files. Basically some weird ghosting where all vectors were being overlaid by some crappy segmented version of the shape, and it was confusing their pathing application. They didn't catch it until after the first cuts, and said rounded corners basically came out looking like saw blades. Yikes! For whatever reason I couldn't detect the lines in 3 different CAD applications, but after chatting with TowndawgR50 a bit (he knows how frustrating this really was!), he gave me a suggestion to try. The shop corrected parts where necessary, but probably didn't give as much detail to all parts as I would have if I could see the problem. But, I'm not complaining because they were willing to fix the files for free this time around. Some close ups... Everything is totally usable though. I can fix some things, but I feel like the only true workaround is waterjet, and you don't want to know what I was quoted for that! Tacked up...fit as expected. Look ma, no jack stands! Haven't done anything with the front skid yet. I got two of the Pathfinder plates cut, bent this one to 90° and might see what 75° looks like, but haven't welded up the slit. Thinking I will paint the PS line and area black, but paint the plate silver or something vivid. Since I'm losing my sleeper status with this project, might as well make it known I proudly use this thing. Side story about my local club's kick-off run the other week...buddy of mine (the guy with the red Frontier) was standing amongst the crowd as I was picking my obstacle path. I opted for a tougher route than what everyone else had taken (I've taken this route before without issue...well, except bending my trailing arms...and bent them even more on this particular pass...I bought the steel to make new ones). Some guys I hadn't met yet were asking him, "That guy thinks his stock Pathfinder will make that?" and I'm told there was even a "I'll get my winch ready." He was like, "Yeah, stock Pathfinder. He'll be fine." I surprised a lot of people that day. Really hope some videos or pics surface. Anway, was only able to get the LH bracket welded up. RH tomorrow, and maybe skids. Bumper next weekend hopefully. -
Ooops, sorry, I missed that.
Ok, so I can't attest to any of the Spicer p/ns. BTW, have you seen this post before? http://www.nissanpathfinders.net/forum/topic/25609-spicer-u-joints-vs-oem-nissan/. Per Fleurys' note, the FSM does indicate the clip type. Just checked the 2002 FSM, and 4WD MTs are outer for rear driveshaft, everything else inners. The PDQ 1-0029 joints I referenced in that post, and the GMB 215-0029 I carry as spares won't help you. But for reference for anyone else, the GMBs are listed as the Brute Force series, made in Japan, use inner clips, and have a long zerk fitting on the cross between the caps. Neapco specs the 1-0029 at 1.103" cap diameter and 2.205" lock-up (max gap on the yoke for the clips). For the fronts, Neapco 1-0449 are made in US, use inner clips, and have a short zerk on a cap end. Neapco specs at 1.063" cap and 1.93" lock-up.
I keep spares, so I can get you some dimensions later. I want to say I tried one of those rear p/ns and it wasnt a proper fit. Was off maybe 1-2mm in a dimension and made it difficult to get the snap rings on.
Agreed. I like the handling as-is, too. I only removed it this time around because of the trail I was running, but in reality, didn't seem any profound effect.
You and I are in the same boat. I've got two young kids and there's no shortage of gear to haul (both of which were factors for my cargo rack...I still owe you some dimensions). I mentioned my pucker moment earlier in the post...I put it back on today. I don't think there are gobs of articulation to be had by removing the sway bar...or at least not enough to really warrant removal for me personally, all things considered. I think at this point, it's more important to get the panhard bar down to the right level to maximize articulation when I get the LR springs (hint: I'm making a bracket...in fact, I just glued together a wooden version 15 minutes ago.) I think you mean just end links and not disconnects, but yeah, it would be great if those work. I was planning to cut up some OE ones and extend them, but this seems like a much easier option if it's the right length. I kept hoping to find some 4Runners versions that were longer, since they have pretty much the exact same design as ours.
Funny you should ask. I removed the sway bar and links for an off-road trip just last week, and that might have been the only time since my last post. The hang-up for me was just not coming up with a good way to pin the sway bar up. I liked the idea of some sort of secondary bungee or spring that allowed the ends of the sway to 'float' when the links were disconnected. A bracket on the axle side would be annoying to reach with the tires in the way. It was also evident that over time, dirt got into the joints I used, which made it a little difficult to remove. Add to the fact my complaints about the spring density making one side tougher to compress. I will note that the joints have otherwise held up well over the years without any maintenance, but there was always some chatter to them. Lastly, street driving to and from the trail without the sway bar was just too noticeable for me...and not having it while on the trail was not noticeable enough (except when I was bombing through the trail and kind of wished it was still attached). My springs are worn, so that's probably a factor. I'll be going the LR spring route soon, and will probably put the bar back on today actually (have some highway driving tomorrow). I'm also going to see about using these front sway bar end links for a 05-09 LR3 to replace the disconnects: They look longer than the stock links, and instead of a fixed shaft at the top (RH side in the pic), there's a joint on them. Not sure the stud sizes, but I'll make it work. No plans to do the fronts, pretty much for the same reasons. Because of the angle of the bar ends, there's no good place to pin them up without contact from some other component.
You can find them a couple bucks cheaper as "14mm camber bolts". I use these: https://www.amazon.com/dp/B00MJFOVR2 As for tires, I've been running the Cooper Adventurer AT, which are the Pep Boys clone of the Discoverer AT3, for maybe 2.5 years and 12K miles (yes, I don't drive it much) over 5 tires. They've been a superb highway tire, and have done very well off-road. I'll usually take them down to 15 psi. Tread life seems fine, some tiny concerns about some cuts to the sidewall and lugs chunking at the edge of the tread, but I feel this is to be expected because my off-road usage. I've been pleased with them.
I have those ones. They were on the truck when I bought it used a few years ago. I know that the previous owner and I have put them to work. No issues whatsoever.
Minor update on this... So the past two weeks have been pretty lame. I found a few shops around with cutting services and requested quotes for my initial parts, and for a larger follow-up order. It's pretty discouraging that these "no job too small" companies couldn't even reply in a remotely timely fashion. Very disappointing, to say the least. On the bright side, the company that gave me the most attention—my local steel supply—has also produced the best quotes. And after waiting as long as I could for other companies to reply, I finally put in an order today. So, I'm pretty stoked this finally moving forward. First pass at parts should be ready in a week. More details to follow... -
That RPM sounds about right. But, the AT RPM range has always been a bit high in my opinion...really wish we had at least one more gear. Not sure it has much of an impact on mileage though...while the gearing makes it easier to turn the tires, it also requires more revs to do so. My mileage has never been that great (14-15), even on freeway.
It's been a long time since I really dug into an engine, or a conversion, for that matter. It involved a 91 240SX coupe and an RB20DET. There was also a 96 240SX that went from AT to MT along the way. The 98 Frontier might become KA24DET this year... As for gearing, I'm an advocate of it. In fact, when I swapped in the gears, that was perhaps the most notable difference on the first test drive. It was just more responsive. The VQ can surely support larger tires without a gear change, but anything that you can recoup after increasing tire size is worth it, particularly if you plan to wheel it. Improves crawl ratio, easier on drivetrain, more efficient, recovers torque, among other things. I mean, I probably wouldn't have gone out of my way to change gears if I wasn't installing lockers, but used differentials are relatively inexpensive (I paid $300 for front and rear diffs).
