hawairish
  1. Thanks Kent! Yeah, it's ridiculous how catastrophic something like that really is, especially when you've pampered a vehicle. It's more ridiculous that Nissan didn't own up to it. As for the IACV/ECU issue, wish I could say I've seen a good, definitive post anywhere. Most of what I've seen is on the NICO Forums...this is probably one of the better starting points: http://forums.nicoclub.com/advice-please-ecm-repair-warranted-t613891.html. Much of the discussions have been chicken-vs-egg discussion...i.e., did the ECU fry the IACV, or did the IACV fry the ECU? The issue wasn't unique to the VQ35, either (I believe it was common on VG30 in some of the cars, like Maxima and I30), but I think the primary reason we didn't see it in the 03-04 is because of the drive-by-wire system. The issue is still rather foreign to me, but my (general) understanding is that a seal or gasket on the IACV body or housing fails and exposes coolant to the solenoid, which shorts it and also eventually takes out the ECU (perhaps an impedance issue, dunno, but doesn't read like it's an immediate failure). If you fix the IACV problem without fixing the ECU, the ECU can then short out the IACV...not sure how plausible that one is, but it's out there. It reads like some guys have lucked out with only IACV failures, but others replace the IACV without knowing the ECU is bad.
  2. Technically speaking, yes, but are you determining the 2" sag using specs from the FSM? I'd be surprised if you weren't bottoming-out on the strut bumpstops over bumps, assuming they're installed.
  3. OME MD springs yield about 1.5". There used to be light-duty ones, but I don't think they're available any more.
  4. I think that if we're talking any amount of lift, I'd advocate springs over spacers any day like TowndawgR50. Static spacers are convenient if you really want to keep stock ride characteristics, but with limited options even available, you have to disassemble the entire strut anyway to install them. If you're going to go that far, springs are the way to go...better handling, better load support. Spacers have their place for us, but springs will make more of a difference for only a little more cost.
  5. No sweat, and I hear ya. I’ve had to drive that pattern more times than I care to admit to resolve an oh-crap-I’m-due-for-emissions situation.
  6. Ha, I can be pretty wordy sometimes... Definitely consider your use for the truck. Even if you only occasionally find yourself on a trail, a moderate amount of lift from spacers or lift springs goes a long way. It's worth noting that one of our members have taken the Rubicon Trail in his with 2" of lift, 32" tires, and lockers (perhaps some more goodies, but that was the core). I've been wheeling with a local Nissan Xterra group for a couple years now, and with 32", 3" of lift, and lockers, I'd outdo them all the time despite having the smallest tires, lowest ground clearance, and basically smallest vehicle among 33"-35" tires, 4"-6" lifted Frontiers and Xterras. A lot of the guys thought my truck was stock. Rolling with them, I've seen bent tie rods, cracked coil spring buckets, busted CVs, busted ball joints...on their trucks. Only issues I've ever had, knock on wood, are two blowouts from some lousy Duratracs. The thing about the LSD is that it's better than an open diff, even when worn. If you can get it, do so. Also, Lokka makes a front lunchbox locker for very reasonable price and is a great option. I ran one in mine for a while before going to air; @TowndawgR50 is carrying its legacy. Lokka + LSD is a great combo. Yes, the RE4R01A AT in the VQ R50s were built to handle the added power from the 3.5L. Details here: Pre-MY05 trucks had the RE4R01A transmission, too, just not all to HD specs. Regarding bellhousings, the pattern on the block I believe is very similar, perhaps identical, but the lower block/pan appears to differs because of the starter location. On FX35 and 350Z/G35 VQs, I think I've seen two openings that resemble starter holes, one on each side of the engine, though I don't know why there are two holes. But for sure, that would suggest different belhousings. It's probably a moot discussion, but even if another VQ 5MT/6MT could match up, you'd not be able to get it mate with any of our t-cases. One issue is RWD cars vs 4WD truck. I'd guess that the bellhousing from a VQ40 truck would be a much closer match than one from a AWD/RWD VQ35 car/SUV, but all the MY05+ trucks have the all-mode transfer cases; part-time cases weren't an option. Performance-wise, damn near nothing. K&N cold air intake, that's about it! No cat-back exhausts, not even an ECU tuner (don't be fooled by the JET V-Force Plus unit...it's a highly glorified OBDII reader, at best). I think I've compared the header bolt pattern at some point, and I think our flange pattern is just mirrored from other VQ35/VQ40 options, but I want to say the block is pre-drilled for the other stud positions. So there's maybe hope there, but downstream from that...all custom. On the bright side, think of all the money you'll save by not trying to soup-up the performance!
  7. The LSDs are clutch-based, but Nissan tapered the numbers as the model years progressed. These are the numbers I compiled from Factory Service Manuals when I was rebuilding them: At least for the rear diff (model H233B), there are no other LSD options, only three lockers. I rebuilt some using new OE parts a few years ago, but I was told I depleted the supply on some of the thicker discs and plates. However, buying a junkyard LSD from any of the above trucks will yield extra pieces to rebuild; although the parts will show some wear, it's the thickness of the pieces that'll matter here. I've been able to build them up to about 160-180 ft-lbs and that has performed well for off-roading, combined with a front mechanical locker. I've still got a spare LSD at 165 ft-lbs; rebuilt it from the parts I had, but never re-installed it because it was replaced by a locker. That's how I'd go with the 5MT: start there, and hold out until you find it. Personally, I've always been a stick guy; this truck is my first AT. I've appreciated it to some degree, but I wouldn't mind an MT again. So, hopefully this won't detract you from looking to buy an R50, but I've always termed the truck as being Nissan's redheaded stepchild, or otherwise bastard truck. I've named it so because it's very different from anything that it should be similar to. Much of the drivetrain is very similar to 89-04 Hardbody, WD21 Pathfinder, Frontier, and Xterra models, but not the same. The front diff (model R200A), for example, is unlike every R200A that ever existed on those trucks—ours is high-pinion/reverse cut, everything else low-pinion/standard cut. As such, we only have OE gearing options (4.363 or 4.636). The rear axle, fortunately, is basically the same as those trucks, and there's a lot of interchangeability (I run disc brakes from a WD21, for example). Transmission is actually of heavier duty than the others, except late Xterra, I believe. Same transfer cases (excluding the all-mode version, which wasn't used elsewhere). Suspension is totally different. VQ never appeared in any other truck until the stroked VQ40 showed up in MY05 Frontier, Xterra, and Pathfinder...and even that is a very different engine. There are some parts overlaps among VQ35's, but Nissan made a lot of subtle changes on them. Kings of the spare parts indeed! Starter placement, oil filter location, even all the intake plenums were basically unique by model. You don't have the overlap that existed for older Nissan car models. But at the same time, I'll acknowledge that I've seen very little in the way of engine performance mods on the R50 done by owners...it would likely be a heavy investment of time and money to research, as no one specifically lists the R50 as an application for performance parts. No headers, no cams, no turbo kits, nada. Fortunately, the data is there via the FSMs as a starting point to at least see if, dimensionally, parts might work. I use RockAuto for a LOT of parts cross-references, and of course Google image searches (I find that eBay listings for engines also have lots of pics). Parts.nissanusa.com and nissanpartsdeal.com also help greatly for parts cross-refs. That all said...the R50 is a great truck if you can get over how different it is from other Nissans, and can deal with basically no aftermarket support. The bastard qualities, in my opinion, are what make it perhaps the best truck Nissan has produced, including 05-18 trucks. Outside of the PV issues, the VQ35 had far more power and torque than any VG that was offered (including the supercharged one found in Frontiers and Xterras), and far less problems than the VQ40. High-pinion front diffs are better for off-road. Heavy duty transmission, standard. 5-link rear suspension. While I hate having McPherson struts up front, let's face it: the truck handles like a car and you'll come to appreciate that. The drivetrain is far more stouter than anything 05-18, including Titans (but maybe excluding the new Titan XD). The unibody has offered no less rigidity or flexibility than a framed truck. Better looking interior. Sorry for the long post, and perhaps my final recommendation: I'd look for 01-02 models. Outside the IACV/ECU issues and PV issues, which can be addressed by preventative maintenance, the other notable is that they were drive-by-cable; 03-04 was drive-by-wire...more sensors, more limp mode, more expensive throttle body. I also think you'll have more hope finding your 5MT in the earlier range.
  8. You can get the FSM here: http://nicoclub.com/archives/nissan-pathfinder-factory-service-manuals.html Specifically, check out this table on page EC-40 and the description on EC-41 here: http://www.nicoclub.com/FSM/Pathfinder/1997_Pathfinder/ec.pdf If you look at the bottom of the table, it'll chart the engine state, speed, and duration to satisfy each test, if you were to do them all in one drive. Any time I've needed to 100% set readiness on my truck (particularly in my 98 Frontier, and not so much my Pathfinder), I've followed this full chart using a stopwatch/timer, open freeway, and some side roads (particularly for the 0-35-0mph tests). You'll see that the EVAP and EGR tests appear in Pattern 3, which requires the test I just mentioned. Usually it's addressed by simple stop-go driving, but I follow that one pretty closely (10s stopped, 10s accelerating to 30-35, 20s cruise at 30-35, decelerate to stop, repeat a few times). Also note the 53-60 mph range for Patterns 2 and 4...I've always found this to be the toughest test because I don't have many roads with 55-60 speed limits...65-75 here. I end up doing this at night on the freeway, driving (legally) below the speed limit in the right lane. Again, you can just do the parts you need to, but between the items you mentioned, looks like they could cover all 4 patterns.
  9. Welcome! It's a good truck to look for, and you're asking the right questions. I'll take a stab at them. Check the strut towers for rust, as Astrorami mentioned. This was a recall item on older VG33 models, but not 100% sure it was an issue for VQ trucks. Doesn't hurt to check. The tower area will include where the top of the strut mounts, and the entire wheel well area basically. I'll add that other points I've seen are by the rear subframe mounts (where the tail of the lower control arm bushing is) and also the tail of the fenders, especially is the truck has any fairing or mud flaps there. Mine's a desert truck, but I've cleaned out tons of sand and dirt from the area. The IACV and ECU issues I think were only on 2000-2002 trucks, but don't quote me. Can't attest to any repair questions, though. Orange sticker is usually the best way to tell for LSD. If you've got a VIN, plug it in at nissanpartsdeal.com and check the Power Train > Rear Final Drive parts section. Results are filtered by VIN, so it references the LSD parts diagram, I'd presume it to have one. However, the LSDs were pretty weak. I've rebuilt a few to have much better numbers. I'd plan on inspecting the power valve screws for any year unless you know it's been addressed previously. I'd check the VIN plate on the motor to see if the motor has been replaced, the likely "fix" from a previous failure. I know of two 2002 trucks that have succumbed to it. Can't say I've seen a 5MT swap. The MTs were pretty rare, so that's probably a limiting factor, but they show up every now and then (another new member was just asking about this). I'd say it requires any typical amount of AT-MT swap effort. If starting from the All-Mode truck, yes, you'd likely have some complications because of input signals between the control modules. You'd have to bring over the MT's Part-Time system. That may open a different can of worms. I would assume a Z33 transmission would not work. One notable about the R50, in general, is that it deviates largely from other Nissans that you'd expect it to be more similar to. The VQ35 is one of those things...it's just different enough than the 350Z, FX35, and other RWD/AWD options.
  10. You can do them all in a single trip, actually. Where did you get the manufacturer’s drive cycle, by chance? The Factory Service Manual outlines it in detail, but just checking if what you’ve got is from the FSM. Since you’ve gotten the other monitors ready, you can do the specific tests for those that aren’t ready.
  11. Makes sense. Where does the tube from the water separator connect? Isn't that off the purge solenoid? If stuck open, maybe escaping there? Edit: Answered my own question. It connects directly to the purge valve, but another tube connects to the chassis as a vent. I vaguely recall on my Frontier that it did this, too.
  12. Unfortunately, EVAP systems fly way over my head. I'd presume that since it's all plumbed together, a stuck-open valve/solenoid and failed canister could be a culprit, but I think the only vent area is near the canister, but ultimately near the filler neck. Is that the general area you're smelling it at?
  13. I had the canister fail on my 98 Frontier, too. Cleaning the lines was a real crappy job. I flushed the hard lines with water, air, and even copper wire. One particular note is that if any of the charcoal reached the solenoids, I’ve found the solenoids to be repairable...far cheaper than replacements. My issue was a P1444/Evan solenoid clogged by the charcoal granules. Also, if you need a new EVAP canister, I’ll note that I got a 98 Maxima canister to work on my Frontier with minimal modification, and a 98 Pathfinder uses the same as the Frontier for that year...not sure if 97 was different...Maxima canister was like $30 instead of $150 for my truck.
  14. Not sure on range, mostly only used in close group proximity. Though, I've been told I come in very clear.
  15. I have the Midland 75-822 and I like it. Perhaps the only things I'd change would be a longer coiled cord, and for the backlight to be longer or persistent (or at least have the backlight button light up so it's visible in the dark). I particularly like the portability, since you can still put a short antenna (included) on it and use it in another vehicle without a permanent antenna being installed. Would also work fine with a magnetic base antenna. It actually comes with two battery packs: one for disposable batteries, and another for rechargeable batteries (includes the AC recharger, too), but I've not really needed to use the handheld modes. I ran my antenna connector to the center console so that I could use the 12V socket in there. Everything stores in there, too. There's just enough gap between the center console and lid latch to run the cord out (kind of snugs into position), but the length of the cord prevents me from mounting the mic unit somewhere on the dash. It usually just sits around the cup holders, draped over my leg, or clipped onto the seat belt strap across my chest. Maybe I'll make a mount for it it someday. My center console is looking a bit filthy. Antenna is the FireStik FL3-B, and I bought the FireStik MK-204R mounting kit (cable and door jamb mount), but ended up using my upper tire carrier hinge instead of the door jamb mount. Note that the cable required soldering at the connector, but it allows you to snake a 1/4" wire, rather than try to squeeze a 3/4" connector through small gaps. I routed my wire through the taillight grommet, into the interior quartpanel space, along the passenger side, then under the passenger seat. Initially, I put a twist-style Hustler QD-2 quick disconnect, but eventually forgot to remove my antenna before entering a parking garage and snapped it right at the base. I was able to repair it, but also added a Wilson antenna spring. So now it'll flex and can be removed easily: I bought an Astatic PDC1 SWR meter for tuning. Tuning is kind of a pain...the system is very sensitive to changes, and it takes a few iterations to dial it in.
  16. Thanks. Rack is 50 lbs, tailgate is 16 lbs. Add it to the list of things for @TowndawgR50, lol. If he hasn’t built you one by next spring or summer, maybe I’ll bring one up. I was telling him that I’d like to make a trip up that way. I’m also thinking I may make another rack, but one that’s simpler for everyday use. This is great for outdoor excursions, but day-to-day, I need something that has a larger flat surface, and maybe some cubbies to drop stuff into, like groceries and other small purchases, to keep them from sliding around. I also ordered a generic/Chinese 54qt 12v freezer/fridge from Amazon yesterday...$390. Same item that Smittybilt labels as their Artic Cooler for $700. I figure it’s worth a shot, though I find it funny the generic cooler has great reviews, but the Smittybilt version has lousy reviews. Guess we’ll find out why! I’ll get some pics of how it looks on the rack when it comes it. Doubt there will be enough useful clearance to grab anything from the cooler, but for sure* it’ll fit. (*fitment not guaranteed, lol)
  17. Alright, @RainGoat, this post is just for you, buddy! I was long overdue for some dimensions for you. I still need to put them together for the tailgate and mounting feet, but here you go...now get cracking! There are a few repetitive dimensions and concepts, at minimum from the visual learners like myself, but also to summarize the little aspects of the build. Material sizes are 1" sq. tube for the main framework, 1" x 1-1/2" tube for the back and bottom, and 1/2" sq. tube for the shelf supports. I think everything was 16ga (1/16") wall. Everything was kept to 1/4" increments and simple angles (45° and 22.5° cuts). If I had to do it again, I might use wooden panels for the shelves, like I did for the tailgate, instead of all the 1/2" tube...took too much time to cut pieces and weld together. But then again, it adds various tie-down points. Space conceptualization. There are about 4"-6" available above the tops, and about 3" more on the passenger side, but these values just represent the dimensions up to those of the rack. Top view by levels, and the diagonal dimension that allows it to clear the liftgate opening. Recall that the angles of the 2nd (green) and 3rd (cyan) level shelves are so that it can clear the D-pillars. The height of the rack is also the max allowable, assuming you use 1" mounting spacers like I did (details to follow).
  18. Today I picked up 600 lbs of steel plate...enough to make the initial 6 bracket sets...and some skids plates. I'm still debating whether that means front or mid skids. For sure, I plan to make a mid skid to match my front skid. There might be some other revelations along the way. For now, still focusing on the remaining V2 tweaks. I'm still dividing my time across several projects to build up some confidence using the plasma table. I've not fired it up for a few days, but this week I will be cutting out the brackets and other items for my rear(!) bumper, which I (finally!) started last week. The truck has been without a rear bumper for months now, and the goal is to have it done before CANVAZ. Lots of work left to do!
  19. Where da pics?! @Astrorami at that price, it's unbeatable.
  20. That Mictuning relay box is slick. Haven't seen it before. You'll still need to distribute power in one way or another before the box since there's not a common rail. But still, get some proper crimpers and wire, and that's clean setup.
  21. There shouldn't be any significant side-to-side wiggle for any position, but it seems possible you've got a rather smooth transition through neutral and that you're in the 4H position. In fact, if the lever were in N, and you put the transmission in park, you'd get a red ATP light on your dash. If you don't see that, you're probably in good shape. You could also crawl under the truck and inspect the shift linkage.
  22. But if you can feel it going between 2wd and Auto, wouldn't that suggest that the lever is the 4H position? I think the system would fault on Auto mode if it wasn't (there's a N/4Lo sensor). Still, no dash lights? Also, I don't think your shifter requires depressing the lever...is it possible that it's just passing through neutral without providing any feedback through the lever? On the part-time system, it's pronounced, but I'm not familiar with the QX4 lever or switch (uh, well, aside from having a shift knob in my parts bin, and a newer selector switch controlling my air compressor and locks) Could you also recap your shift procedure? I presume you're stopped, engine running, and shifting from 4L to 4H? Is the 4wd dash light lit when the lever is all the way forward and switch set to Lock?
  23. That Expedition Portal link...it's an okay read, but I wouldn't go past the first few pages unless you want to be suffocated by electrical theory and conversations rendered useless after people deleted their posts. I've seen some better links. I found this one especially useful for the basics: http://www.outbackcrossing.com.au/FourWheelDrive/Basic_Dual_Battery_System.shtml This post had a lot of pics: I dig @XPLORx4's setup, too. That's probably the route I'll probably take eventually, though I may run my camping accessories off it instead of having it solely for jumpstarts (but I would have a switch for that purpose, too).
  24. Not a problem. We've had a few threads about shifting that have gotten interesting, to say the least, but we've had some spot topics come up. Your 97 QX4 is a little different than other R50/QX4 trucks since you have both a mechanical lever (positions H, N, and 4LO) plus an electronic switch (2wd, Auto, and Lock). 4H for you is H+Lock. When the shifter is in 4LO, though, the switch is disabled/bypassed. So if 4L works, I might suggest probing or cleaning the switch and seeing if that helps. Keep in mind the transfer case in yours has a motor to engage things, instead of a physical linkage, so it also relies on input from other sensors (and comm with the AT computer) before it'll act on drivetrain requests. Are you also basing engagement on the 4wd dash light(s), or are those lights indicating any issues? Also, may want to look at the Owner's Manual, or the Transfer Case chapter of the Factory Service Manual (FSM) (specific links for 97 QX4 embedded into this sentence) for some additional info or guidance.
  25. If you can't depress the shifter any further, or don't feel the shifter pop back up/out, then it's probably still in neutral. Transmission out of gear when trying to engage 4L?
