hawairish
  1. I got pulled into a helping a neighbor who's got a 00 Quest 3.3L that's not running...I know, sorry, not a Pathfinder, but hey it's more about the engine. Long story short, a few months ago "something" in the engine bay got glowing hot (presuming front cat), and he had some guy do some work on it months ago. I was told the fuel filter was swapped, a cat was swapped (not the front), and the timing belt was changed (sorta). He asked me to take a look at it over the weekend, so I did. The guy who did the timing belt got exactly that far, not bothering to put the covers, pulleys, belts, or hoses back on, and never came back. I offered to put it back together and see if I could get it started. As far as I could tell, all the alignment marks on the three sprockets aligned with the dimples on the backing plate, but being a transverse-mount engine, a few things prevent getting a good look at the LH alignments. I had the timing pages from the Quest FSM for reference. Got everything reassembled eventually. Battery was drained, so I got it charged up to 13.5V over the past couple nights. I threw the battery in, replaced the crappy terminals, and gave it a go. So, here's where I'm at: 1st attempt, it turned over and started. Couple turn-overs before it caught. Rough idle, low idle around 500rpm. Giving it a little gas almost killed it, but it recovered. 2nd attempt, turned over and started quickly. Same rough and low idle, same reaction to gas. While "idling", I notice some light smoking coming from around the 2-4-6 manifold, but the overhang on the valve cover prevents me from seeing the exact source. But, does look like it could be coming from the gasket. I shut the engine off. For the above, no particular noises. Engine was running pretty quietly, actually. After engine off, no hissing or other noises. Restart attempts at this point fail. Engine turns over endlessly, but doesn't catch with or without the gas pedal. Every now at then, the fuel light would come on briefly during starting, but not always. No engine codes, stored or pending. Fuel pump and ignition fuses good. Full tank. When key in, turned to ON, the fuel system priming is audible prior to starting. I did pull the distributor cap and rotor to check the contacts, they were ok. I saw no indication that the distributor had been removed or adjusted recently. My best guess it that the front cat core has degraded and clogged the exhaust, but would that be a logical reason to explain why it started fine initially but then wouldn't start? Would built-up exhaust pressure do that? For this engine, the 1-3-5 (towards firewall) manifold routes forward and joins the 2-4-6 manifold as it goes into the front cat, which is located between the engine and radiator. I never saw it when it was reported glowing, and my pyrometer during a few minutes idling showed it reaching 350°F. I don't know what's normal. The O2 sensor is conveniently on top and might allow me to peek into the cat, but I didn't try to remove it because everything was still hot. He (neighbor) did say a cat was replaced, but I didn't do a visual inspection underneath...perhaps the issue was farther upstream. The nuts on the 2-4-6 manifold did look like they had been tightened at some point, so I don't know if it was already inspected otherwise. Any ideas?
  2. Seems nice, but not $5K nice, and not excellent condition. It was a luxury vehicle, and Infiniti is a luxury brand, but today it's just another Pathfinder. I paid $5K for my 04 SE in 2012 with 145K, OME lift kit, sliders, skids, and clean exterior and leather interior (untorn seats, too), no issues...from a dealer. That truck, private sale, for that price...I couldn't do it. You could get all those features in a Pathfinder LE for less, too. What I see/think: If having cruise control matters to you, I'd be cautious about that one. The Intelligent Cruise Control system was a step above the normal cruise control system. I'm not even sure it was offered in Pathfinders, only QX4s. Finding any replacement parts might be difficult. However, I've looked at two VIN-specific parts diagrams and neither seem to indicate the sensor referenced in an 03 QX4 Owner's Manual. Hard to tell if there's a sensor present on the front bumper in the pics. The control module for that VIN also cross-ref'd to the module in a normal cruise control system. Perhaps this one doesn't have the ICC system. Perhaps the parts show up in another section I didn't see. Even then, the parts are simple, abundant (except maybe the ICC-specific stuff?), cheap, and easy to replace...gotta wonder why it hasn't been repaired. A Navigation system with probably 16+ year old maps is no longer a selling point...not even sure if you could update the maps if you wanted to. The Nav unit also has the climate controls integrated into it so replacing it is not a viable option (it's been done, and I wouldn't recommend it). Otherwise, it just has a single-DIN radio that would be replaceable. Missing spoiler. That driver's seat. High miles for price.
  3. It's more about braking efficiency, less about safety (not that brakes aren't a safety item). Regardless of the valve proportion, you'll have braking power, but it may contribute to more brake wear up front over the long run. I'd document something, but I don't have any reference since my 04 doesn't have an LSV. Although my Frontier does, it's a slightly different design, and my truck's been lowered and adjusted enough to meet OE specs. Similar concept of course, but I wouldn't be able to account for any differences. I know the FSM has some procedural items, but you're right in that we might need some specialty instructions for lift.
  4. Nay. It's behind the driver's rear spring, on a bracket under the floor pan:
  5. Check out the Factory Services Manual for your truck (https://nicoclub.com/archives/infiniti-qx4-factory-service-manuals.html), then check out the EC chapter; subsections are sorted by P code. Doesn't look like the 97 manuals mention it, but later models do. That particular code deals with a bypass valve, which is a solenoid. The FSM details the full/proper diagnostics, but the gist of it is that you need to inspect the solenoid. Make sure it clicks with 12V applied and that the two ports on it open and close (easiest test is to just blow into a port with and without voltage applied). The solenoids aren't cheap, but the ones on my trucks (04 Pathfinder, and a 98 Frontier where the charcoal canister ruptured and sent charcoal granules into the entire emissions system clogging hoses and valves) can be disassembled and reassembled with pliers and a screwdriver. I've used a pin/needle to extract any tiny debris that's clogged them open/closed, then reassembled. You also need to check for any loose/cracked hoses, cracked plastic, and potentially the cut valve itself (again, see the FSM for full steps). Green thing is the bypass solenoid, white thing is the cut valve.
  6. I'm late to the party, but I'll echo @TowndawgR50's comment in principle, noting that my 04 doesn't have an LSV. But yes, by lifting the truck, the LSV be allowing the minimum rear proportioning available. The valve is meant to increase rear proportion when a load is detected, but the lift basically does the opposite to an extent. To restore the function, you'd likely have to move the spring arm up a few inches like Slart mentioned, but I agree that it might not matter much. I'd just as well suggest disconnecting the spring and calling it a day, or otherwise finding a way to put the lever in a static position that simulates stock-height (or a loaded position if more rear bias is desired).
  7. I'd love to know the end result. I've always seen them on RockAuto, and I'm not particularly fond of the shift patterns on my 04 (mainly 3<-->4 down/upshifts), though I'm not sure what the kit does to improve it, or if it's all sensor/computer driven. Are the kits intended to be a performance aid, or a rebuild option? (Oddly, those kits have application overlap for some 90's Mazda RX-7/MPV/929 according to RA, too.) I think we'd all be interested in hearing more about your engine mods, too! Welcome to the forum!
  8. Yep, every now and then we do need a reminder about the absence of power valves in the MTs. I'm guilty of referencing them when other MTers have engine woes. My impression for swapping engines is that you can use the AT engine, but you need to swap over everything from the lower intake plenum and up. Otherwise, yes, finding an MT engine will be a challenge. The ATs are everywhere.
  9. If you've got stock tires and no complaints about the towing performance, then stick with the stock ratio. Check the axle code per XPLORX4's response. If the backlash is off and the gears are okay, you can adjust the backlash. The rear diff uses side adjusters to move the carrier to adjust backlash. Since you're 2wd, you have the OE options XPLORX4 mentioned, plus 4.90's from the Xterra. The rear diff drops out, and is replaceable with units from any 96-04 Pathfinder, 00-04 Xterra, and 01-04 Frontier; no set-up required but the donor should be inspected. I'd stick with the lower gears, but I've never driven the 3.3L to know how it pulls. Changing from 4.363 to 4.636 was noticeable, but I probably wouldn't recommend lower gears unless they were paired with larger tires.
  10. It's doable, but 2" W material would be better. For reference, this is what my current spacers look like: It's constructed of a piece of 2.5" sq. tube x 2.5" H x .250" wall, with 5.5" L x 2.5" W x .25" pads to make a 3" spacer (the height is irrelevant for this discussion, though; the 2.5" W base is what matters here). You could easily just use a 2.5" x 2.5" x 5.5" tube to replicate this like other spacers, normally 2" W x 4" H x 6" L for some of the traditional spacers. I did 5.5" L spacers to avoid having to notch anything for the passenger side where the brake lines come down (the metal guard shown in the pic). Here are the gotchas: 1. A 2.5" wide spacer is just a tad too wide. On the rear subframe, the width is perfect relative to the chassis. But, the unseen lower edge of the spacer actually sits atop a weld on the subframe, like so: For the rear spacers, you could obviously offset the holes on the spacer to get around that, but the spacer wouldn't sit flush. Also, if you do a simple tube approach, you have the radius edges to your advantage to some degree, but it may still be wide. 2. The front spacer is a little similar, but you can't offset the holes because of the lip on the chassis: Although this fits flat, it does barely contact similar weld on the subframe, it doesn't give much wiggle room for installation. The radius edge of the tube would help here. 3. A 2.5" sq. tube, presumably .250" if hitch steel, only leaves 2" of tool space inside the tube for tightening hardware. It's doable, but just be prepared to make a lot of small motions to get the upper hardware tightened. And if you orient the lower bolts tip-down (which you should), be sure to put those bolts in sometime before sandwiching things together, otherwise you might not have the clearance to insert the bolt or upper nut. That all said, eventually I will go to spacers with a 2"W base to get around those issues, or possibly convert these by welding on a 2"W x .25"H plate to the bottom of each spacer to clear the subframe welds (resulting in a 3.25" spacer).
  11. Haha, you know it. Yours is also the only one with TPMS. I’m just jelly.
  12. A little more lift over SFD height is fine, and in fact what I recommend. It's a trade-off for ground clearance over OE geometry. As for bumpers, I'd like to. It's a long term plan @TowndawgR50 and I have discussed. This may delay getting some of the bumper brackets out from my other thread; seems more convenient to have built, DIY, and builder parts options. The near term focus is SFDs, though.
  13. All great points! Yes, those numbers are bench-test specs, and the value can increase under load due to the spider gear push-out. Yeah, I don't get why the numbers were so diluted for the 03-04. Stability controls would be a good guess, but I'm not even sure many of the vehicle had anything beyond ABS. Of the R50s I've seen with VDC (literally one), it didn't even have the LSD. I think Nissan just got a good deal on those spacers in the units, which consumed the space of 4 pieces in the clutch pack, and still allowed them to market the option. Good point about the fluid. Yes, an additive or LSD-safe gear oil is required. Just realizing I omitted specs from the 99-00.5 Frontier for some reason. MY99-00.0 trucks were 144-178 ft-lbs, then 00.5 went to 138-180 ft-lbs. But yes, both 00.5-02 Frontier and 00-02 Xterra LSD diffs make great swap options because they had the better numbers and because they used the same gear ratios, specifically 4.363 (48:11) and 4.636 (51:11) options, not the 4.375 (35:8) and 4.625 (67:8) options found on older Nissans. You can swap the entire 3rd member; completely bolt on. I've actually been sitting on my re-packed LSD for a while now, and re-acquired the other re-packed unit just the other week. Both eventually replaced by lockers, but I really enjoyed having it. Lokka + LSD made for a great combo. I suppose it's time to find those units new homes...
  14. I've done a 2.5" SFD, with 1.5" strut spacers and OME MD springs and a set of camber bolts. Shouldn't have any issues with your setup. The 2" strut spacers give a little north of 2" lift because of the geometry of the suspension. Not sure it's 2.5", though, but perhaps somewhere in between. As long as you can weld, you can make the Accord link work. Just keep in mind that's a very custom approach. I'd still pony up for a Woodward link. If you ever increase to a larger SFD, you can just re-use the joints and swap in a longer shaft. Notably, if you're not in any rush to do the SFD, perhaps hold out a little longer? An SFD kit is in the works.
  15. I'm curious about the noise. The LSD doesn't quite "engage" per se...whether straight-ahead or turning, the clutch pack is always under compression, but there is a change from no-friction to friction when making turns. Because there are also spider gears in the diff, any engagement sounds are might be attributed to those, and not so much the clutch pack (i.e., the "limited slip" part of LSD). I assembled this chart from FSM data when I repacked some LSDs a while ago: Pretty clear the R50 never got what other trucks got, and then Nissan dumbed everything down 03-04. Re-packing does require some work...and homework. Not so much adding shims but just increasing the friction for the clutch packs. This can be done by thickening the stack (replacing thinner pieces with thicker ones, or shims), by replacing pieces of one type with another, particularly in the case where similar parts are next to each other. For example, on 01-02 R50, a 2:9 ratio means that, those 2 friction discs are only in contact with 3 friction plates, at max, and the rest are just used for spacing (FP-FD-FP-FD-FP-FP-FP-FP-FP-FP-FP); all of the breakaway torque comes from the friction on those 10 pieces (5 per side). The 5:6 models had more than double the friction area, and consequently higher breakaway torques. However, you'd expect the 6:6 to have higher numbers, too, but the breakaway torque is also controlled by the nominal thickness of the pieces, plus any compression added by spring plates. That is to say the R50 LSDs used more thinner pieces, which would reduce stack compression and ultimately friction. In your real-world scenario, if you have an LSD and the tire is still spinning, that means the ground resistance on the tire that has traction is higher than the breakaway torque of the LSD. In that case, it behaves like an open diff because it's defeating the clutch pack and the spider gears (the "differential" of LSD) are allowing the excess torque to rotate the wheel with less traction.
  16. Excellent description and analogy. I totally agree with Slart about the LSD. Even a weak LSD is going to be better than an open diff.
  17. Maybe we just trade trucks and I start over.
  18. Judging by the angle of the pic and wheel well gap front vs. rear, that seems normal operation to me. The hill seems more gradual on the passenger side, so it shifted the truck's weight over to the driver's side, mostly towards the rear. The passenger rear tire would have the least amount of traction, and a rear open diff would allow that tire to spin freely. Since both front tires would have traction, they would also spin.
  19. Well, it's one of those dense composite plastics. The only reason it was of concern is because in my older ARB, the plastic cradle has a crack on it and appeared to interfere lightly with a spider gear. The crack doesn't compromise anything, as it's not in a critical location, but it's just one of those things that shouldn't occur (may have been from a prior disassembly by a previous owner?). The TJM engages the locking gear in the same manner as the old ARBs, but the TJM cradle is comprised entirely of steel parts. The new style omits the cradle all together, as all the moving parts have moved to the opposite side of the locker; it's a major improvement over the older style, in my opinion. New bearings are required and are not included with the ARB. The TJM also requires new bearings, but they are included. OEM bearings will not fit either locker. In the ARB Application Guide, lockers RD134, RD135, and RD136 (all H233B lockers, 31 or 33 spline) have a design note indicating the requirement and bearing part numbers: Timken 32010X and ARB 160116 (I think the ARB part is the Timken...yet 2x the cost). That bearing is also apparently used on ARB lockers for some Toyotas. Also, it appears that the Nachi E32010J bearings that came with my TJM have the same specs as the Timken: 50mm ID x 80mm OD x 20mm width (20mm cone width x 15.5mm cup width). The Timken's appear to be the cheapest and most-available option of the three.
  20. I was pleased with quality of the ARB unit and accessories. I'll always have my concerns about the ARB actuation method, but I do still regard it as reliable. The new units are very stout, and similar in quality internally to the TJM. I chuckled at the cable ties, too, but then again, it's a useful accessory that no one provides (it would be better if they included the required bearings, though). My initial concerns when we were talking about TJM vs ARB was whether ARB was still using a plastic internal cradle from their previous design, which was used to push the locking gear over the side gear. No plastic on the newer design. Once he's got more details, I'll share some of my pros/cons/notes about it and the install. I may even do a separate review/install thread to mirror the TJM review I've got out there.
  21. Not sure where I've posted it, but my recommendation for bumpstop extension is somewhere around half of whatever lift or tire amount size change being made. For example, if you went from a 29" stock tire to a 31" tire, a 1" extension would be suitable because your new tire will be able to reach 1" higher than before. It's a little different when factoring in lift, particularly if you changed to longer shocks, which would have longer compression amounts. You'd need enough extension to reduce/prevent the shock from bottoming out. If the goal is more articulation, the extensions can be omitted, but it'll likely just lead to unnecessary rubbing. Since you're using OE springs and likely OE shocks, you may only need to base the extension length on any tire size increase you've done. But, in your case, a 1" or no extension would be fine I think.
  22. And we just changed out the springs on that truck the other month... I didn't take a look at the gap to see if there was change over the years, but I'd be pretty sure we were able to get a gap when they were installed. @Jax99 do you recall anything the other month...aside from the fact that we forgot to put them back in (lol)? With the coil spacers at the bottom, it's hard to tell what gap exists between the bag and lower spring perch. You might consider flipping the coil spacers to the top, as this would at least position the bag near the center of the spring, and give you an idea of what upper and lower gaps exist. As it sits right now, the lower portion of the bag might be expanding into the tighter wraps of the pigtail area of the spring or further into the coil spacers, which might cause unequal expansion and ballooning towards the top of the bag. Otherwise, if the lower gap seems adequate, perhaps removal of the bumpstop extension would be fine...but to ensure we're apples-to-apples here, are those OME or OE springs?
  23. Yes, that, but also with some useful part numbers!
