10
Everything posted by Terranovation
If the headlights are staying on when you have flicked the switch to the off position, then one of those brass fingers must be still making contact with the magnet inside the switch. This happened to me because I bent the fingers too much when I did the contact clean out. Did you watch the brass fingers move as you moved the switch to on and off? Could be a long shot, but it could be a faulty headlight bulb too.
How to - Removing the hood decorative vents
Terranovation replied to Terranovation's topic in 90-95 WD21 Pathfinders
I think the idea was the smaller the gap, the air is compressed into a fine stream of air for better cooling of the top radiator tank. Think of a garden spray nozzle, the finer the spray, the water droplets are either a blast of water or a fine mist. -
You know those three plastic things on the front of the bonnet, I'm not really sure what they do as they aren't really offering much ventilation for the radiator, but anyway, this is how you can remove them if you are interested, for painting or whatever. Open the hood and look on the inside where you will see where the other side of the plastic is. There is three nubs of plastic on this side with little fin structures. Use a flat head screwdriver or a fork to push these in and you'll feel it pop out, then remove. Very handy to remove them for painting instead of trying to do it while they are still on the hood. I even thought about cutting a larger slit down the middle of each one to get more air through them. Another idea I had was installing led strips into each of them but was unsure how to hide the wiring because when you open and close the hood the wiring might catch on stuff.
That's good to know, I don't use the 4wd gears that much anyway. I will drain whatever is in there, degrease it then put some sealant on the seam then refill it. Luckily I have one of those bottles with a plastic tube as part of the lid. You pull the top up and the tube unravels from inside the bottle. I will probably get one of those hand pumps though for the bigger gallon containers.
When I had all my battery problems I first thought it was the battery so I got a new battery and it was only charging at 13.8 volts so I drove around like that for a year then suddenly I had a flat battery again after it was very hard to start the engine. Then I knew it was the alternator. Tried at a few electrical places to see if I could get it rebuilt but they all said a rebuild would cost as much as a new alternator so it wasn't worth it so I ended up buying a new alternator which I luckily found on ebay for $400 cheaper than what I was originally told. Now it charges initially at 14.5 volts maximum, 14.3-14.4 normal driving. Lights on: 14.2-14.1. Lights on and aircon/fan on: 13.8 volts. Battery at rest: 12.6 volts.
Plug missing? Some sort of fluid leak?
Terranovation replied to Procrastinational's topic in The Garage
I would drain it, degrease everything around that area then put some plumbing tape on the threads of the bolt, not too much just a couple of wraps, screw it back in then refill. I think that drain nut is leaking and needs some thread tape. -
I have a question, is the transfer case connected to the transmission in anyway because I noticed a small leak on my transfer case seal and I never changed my transfer case fluid at all. So should I change it? Fluid looks red and not brown or burnt looking.
Terranovation replied to RedRider3141's topic in The Garage
My truck has passed 300,000 kms I was annoyed I missed when it rolled past 299999 but anyway, she got an oil change and fresh trans fluid change as a reward lol. Next I have to tackle the water pump on a free weekend. I think the water pump that's on there is the original too. Not bad for lasting 300,000 kms (187,500 miles) -
Sounds like a great solution "hey lets just jam some wire in there and use 3 ft of tape on it, there, that'll hold it!" hyuck hyuck
Advice on coolant flush/heater hose inlet hose? 92SE
Terranovation replied to 92SEPathFindr's topic in 90-95 WD21 Pathfinders
When I did my flush I drained the old coolant out, remove and scrub out overflow reservoir, then with the rad cap off I stuck the garden hose into the bottom drain **** of the radiator to reverse flush it. I could see little bits of green coolant still mixed with plain water. Then with the hose still running, start the engine and put the heater on hot with fan speed on high. This was to open the valves on the heater core. I ran it for five mins, then turned the hose off and removed it from the drain hole. Lots more brown colored water came out. I did this a few times until the water was clean. I didn't use any radiator flush either. -
Could be water pump flinging coolant onto the hoses but I don't know. I know water pumps have a weep hole which is really hard to see.
Transmission cold limp mode.
Terranovation replied to vf24renegade's topic in 90-95 WD21 Pathfinders
Hi, sounds like everything is functioning normal. Auto trans will only engage overdrive once the trans fluid temp sensor reaches 80 Celsius. Usually this can take anywhere from 3 - 5 mins depending on weather conditions. I notice if the ambient temp is about 20 Celsius it takes about 3 mins. So by running the engine and then turning it off, the trans fluid will still be heating up a little more before it starts to cool. Which is why you'll find it starts shifting into overdrive after restarting as the fluid will be already heated. Trans cooler is a great idea, heat can kill autos and I recommend changing fluid if you notice it's lost the nice pink color, doesn't smell sweet like it should, also feel the actual dipstick with the fluid on it. If the fluid feels gritty and not smooth then definitely change it...quickly. I change mine every 16,000 miles, some say it's overkill but I have done over 120,000 miles on this current trans, it pulls hard up steep hills with no troubles at all so I must be doing the right thing by keeping the insides clean. -
Water pump still leaking so finally ordered a new one. Just a word of warning - there's two different ones, one fits the fan that has 143 mm between the bolts, the other is smaller at 135 mm between bolts. -
Ok then it might clear by itself after awhile, worst case scenario one of your injectors is fubarred.
Sounds fuel filter related it might be contaminated. Also check air filter, engine can't breathe properly if that's clogged. If it's automatic, change the fluid. Mine behaves the same way, if it's hunting gears usually a fluid drain and refill fixes the problem because after a while atf loses it's viscosity and makes it hard for the gear syncros to change gear. I change mine every 10,000 km (16,000 miles) some say that's overkill but I've done over 100,000 miles on this trans and it's going great so I must be doing something right.
Could be just crud coming loose from the de icer. I'm not really sure what the go is there, we don't have snow in Australia. You said you used a lot of de icer so it might be just the carb burning that cleaner out. Sounds like it just needs a good run up to operating temperature to get rid of any excess de icer in the intake. So do you put this stuff in the gas tank or use it as a carb cleaner?
Flushed out the radiator and cleaned the overflow reservoir. Refilled with Penrite coolant and yes I ran the engine with the heater on and parked on the slope of my driveway to burp the air out when refilling. Put a new rad cap on too. -
truck sitting for years--how to remove old gas
Terranovation replied to Cuong Nguyen's topic in The Garage
Mine does have a drain nut, located under the tank right hand side. There's a hole in the tank splash guard where I can see the nut. It's a Japanese import so it's got those little handy extra things. Go the jdm! I'll take a pic when I get home. -
Took the floor mats out for a most needed wash. I wanted to put them in the washing machine but the wife stopped me at the last minute, doh! Laundry trough it was then. Came out smelling nice and later that day met a curious couple who had a dark blue Pathfinder and were interested in my Terrano and the little differences. I actually thought theirs was a Terrano but it had the Pathfinder decal on the back and the rear bumper had the decorative plastic piece on the top of it. Always great to meet fellow enthusiasts! Gotta stay in touch for when part finding rears it's ugly head. Parts are so hard to find now it's either junkyard or Ebay. -
Check your tyre pressures maybe. If one is a bit flat then ABS thinks hmm something isn't right.
1992 Climate Control teardown?
Terranovation replied to Bobsteriffic's topic in 90-95 WD21 Pathfinders
Can I just mention that in the first pic, up above the climate control top right, is an electric connector, with a yellow plastic piece on it with pink wired. That is actually for the illumination for the altimeter. So you could always go buy an led bulb, drill out the hole bigger in the climate control, connect some wires up to the bulb and to the altimeter connector using spade connectors into that connection, then you'll have an aftermarket illumination set up plus it should be a bit brighter with led. -
Also check Alibaba it might have to be an aftermarket part. Better than nothing I guess. My brake master cylinder cap was leaking so I got an aftermarket one. It was sent from Thailand within the week. It doesn't leak now. The only difference between the original one and the aftermarket one was it doesn't have Nissan marked on the top but who's checking that out. The main thing is it doesn't leak and I'm happy with that.
Odd electric issues... engine work was easier
Terranovation replied to crab's topic in 90-95 WD21 Pathfinders
ATF or graphite powder. WD-40 is ok, but it wears off after a while. -
It's just a plastic cover that goes over the top of the ignition to try and fool a thief that it's been removed to another location.
