10
Everything posted by Terranovation
Terranovation replied to RedRider3141's topic in The Garage
Watched 'King Kong Lives' It's a movie from 1986 and had a brand spanking new Pathfinder pickup truck in the movie. It's a black and silver paint one, with the stock spotlights on the roof. Linda Hamilton driving it like a maniac too lol. -
Ah, the waiting room, I can just imagine it now. The smell of stale tobacco wafting in from somewhere and I bet there's a coffee machine in the corner that doesn't work/hasn't been serviced in years and a spider web in the corner that has been there since 1995.
I saw one where the vehicle had fresh red coolant added, brake fluid was changed and bled and fresh transmission fluid was filled before taking it to a workshop garage. The idiots changed the coolant to green coolant, which was the incorrect color and spec for the vehicle. They also claimed to have changed and bled the brake fluid and done a trans flush. These procedures were completely unnecessary if they checked the color of the trans fluid they would have seen and smelled that it was brand new and the brakes were in top operational condition. They just try to find extra charges to trick unsuspecting customers. The vehicle was taken back to the garage and the owner was shown the video of another mechanic who had done the service before taking to them. The owner bluntly complained saying that the services WERE REQUIRED! There was a court order served on them and they were done for wrongly charging extra costs on numerous occasions and were shut down.
Odd electric issues... engine work was easier
Terranovation replied to crab's topic in 90-95 WD21 Pathfinders
You go ahead and buy one if you want. I know that I can get plastic ones but I'd rather save my money. Butter knife and a bit of electrical tape wrapped around the metal works for me. -
My air con was making a chirp sound when I turned it on. Found the clutch plate on the front of the compressor that makes contact with the metal was rubbing when the switch I activated. I got some ATF and put it in a spray bottle, gave the front of the compressor a few atf squirts, no more noise. I use atf for everything, cleans and lubes, it's great stuff. -
Shouldn't even need to buy a panel removal tool, I just used an old butter knife to pop out the plastic clips holding the door panel. Just slide in under the clip then turn the knife in a twisting action to get them out. Usually after getting a couple out, there's enough room to get your hand in there and just start removing slowly and the rest pop out. There should be 14 clips IIRC. -
These are the original side rails on mine. This first pic shows the mounting bracket bolt circled in red, with a rubber bung circled in green as a reference point. Yours should be identical if you look under there behind your front wheel. This shows three mounting points. Added up, there's about 16 bolts in total. There's two mounting bolts at the rear wheel arch. Final pic shows a view looking towards the front, with the gap between the body and the frame rail where the side rails fit in beautifully. Hope these pics are of some use and good luck
I have the factory boards on my Terrano, I'll take some photos and post them later.
No worries, glad to help. Don't know about the back up lights issue, it might be fuse so check the cabin fuse panel. Might even be a good idea to pull all the fuses and replace with brand new ones just for peace of mind. -
How did you go with the headlight removal or did you just swivel them out to change bulbs? Remember to re aim your lights too. Best way to do it is park about 10 ft from a wall, then put tape against the wall with the tape line 3 ft high from the ground. Then screw the adjusters in until the top edge of the beam makes it to the tape line. Screw the adjusters on the sides of the headlight in until the beams are inwards but only slightly. The headlights should appear straight. Best to do in a dark garage. -
Yes they should swivel outwards but you'll have to hold onto the headlight to avoid it dropping, should just rest it on the edge of the bumper once you swivel it out. If you want to you can even remove the entire headlight by pulling up hard to pop the plastic ball joint out of the socket. Just be careful with the age of the plastic but they are quite tough. If your headlights have dirt in them now would be a good time to vacuum them out or even get them apart to clean with lens cleaner. I never took mine apart but it looks like they have metal clips around the edges that can be removed then I guess some sort of glue holds the glass to the plastic surround. -
I did a write up on how to change a headlight bulb maybe check that out. There is another way of accessing the rear of the headlights but it involves removing the entire front grille, then you can unscrew the headlight adjusters all the way out and remove the bolts (don't lose them) then you can pivot the headlight out by swinging it to one side to have at the rear of the headlight. The headlight is connected to a metal bracket with a plastic ball joint at the base of it. -
This is why I never let anyone else change the oil. The last time I ever let a mechanic change my oil was in 2006. The guy didn't change the oil filter and I know that he didn't because it was still covered in grime. I've been doing my own oil changes ever since then and plus if I make a mistake then I can only blame myself. It's also peace of mind knowing that you've done the job properly and added the correct oil amount.
I often wonder the same thing. Every six months it's best to just take the resistor out and vacuum out the box through the hole, then spray some air freshener in there. If you don't park under trees a lot then a simple inspection once a year wouldn't hurt. 15 minutes for peace of mind.
I noticed my head rests were really hard to pull up. I had to really pull to get them out then I, ahem, lubricated the shafts on them using atf using an old medicine dropper and wiped the excess off with a tissue. Now they slide up easily. -
I just flushed mine out, it's surprising to see how much sand comes out of there even though they appear clean.
Helped a lady out with her flat battery, her poor old mother was also with her and had mild heat exhaustion. I help jump start their battery and told her to keep the car running for half an hour to recharge it. As I was driving away they were still sitting there. I said to her "you can drive the vehicle." Poor woman didn't know anything. -
95 XE Standard - No Juice getting to the starter relay.
Terranovation replied to Paulmall's topic in 90-95 WD21 Pathfinders
It might be flooded maybe try pressing the gas pedal to the floor while turning it over. -
Something like this should help you. Obviously you need a relay to power the accessories you want to run with an inline fuse to the positive terminal and your switch will go to that relay in order to turn things on/off.
Yeah that's the idea, it might at least confuse them. I was bored and just mucking around lol
Correct. Ok, please check your ground wiring for the starter. Even remove the bolt to the chassis, wire brush the metal until it's clean then reinstall the ground connection. The connection to the starter is good too? Also, if you can push start it, check the voltage of the battery with the engine running. It should be somewhere from 13.8 - 14.5 volts. If it's around 12.5 or less then alternator isn't charging the battery but you said the alternator was ok. Wouldn't hurt just to double check it. Also, do your headlights work but nothing else? If that's the case then check the wiring near positive terminal on the battery, check the fusible link isn't busted. -
Check battery terminal connections- are they good and tight? You might want to also try testing the voltage. It's gotta have at the minimum 11 volts to start the engine. At rest, batteries should have a voltage from 12 - 12.7 volts. Secondly, check the wires going to the back of the alternator. Is it secured and tight? Try pulling at the wire to see if it's loose. Third, check the fuses under the dash next to the driver's seat. Nothing blown there? Ok good. Try taking off the battery terminals and clean everything with a wire brush until it's shined up with no corrosion. Take the negative cable off first, then the positive cable to ensure no sparks. Reinstall positive, then negative. Tighten clamps. To me it sounds like the battery might be on it's way out. You said it would start after a couple of tries. That is symptomatic of a failing battery. If it's manual have you tried push starting? -
Sounds like who ever tried fixing the electricals didn't really know what the f they were doing. Sounds like a nightmare. If I can give some advice, if you have a burnt out fusible link, you shouldn't have ANY power to the electrics at all. The fusible link is there in case of a massive power spike and it's purpose is to burn out to cut all power to the battery, eliminating the chance of a fire. So if you have constant dash lights even with the key removed, I'm thinking it's a switch that has been left on, there's a switch on the centre console (not all of em have it but mine does anyway) that is for park lamps. This turns on rear brakes, front corner lamps and dash lights. I'm thinking that switch or wires are on and could simply just need switching off. Either that or you do have a bad relay, whether it's original equipment or something someone stuck in there because they didn't know what they were doing remains to be seen.
I give you - the ignition lock concealer. Needs some paint so it matches the interior but you get the idea.
