vagabond
Everything posted by vagabond
replaced the alt on the 88, thought about washing it, but we are supposed to get some rain here finally
How can the new owner find out what options were installed?
vagabond replied to SpecialWarr's topic in 90-95 WD21 Pathfinders
also some options were dealer installed A/C and fog lights to name a couple -
Loved cruising in my 69 CJ5 doors off top off and windshield strapped down to the hood. Back in the 60s when you passed another fourwheeler you'd give each other the high sign, then in the 70s it was just with your own brand, times change.
that round thingy is a radio suppesor
sounds like you have a gassy battery, or a snake in there. Be very careful hydrogen gas is VERY explosive
I bought my Maxima Alt. today, ? about pully wheel
vagabond replied to mikestewart395's topic in The Garage
it's been awhile but I think I used a spacer between the fan and the bearing in the case on my 88 2 piece pulley -
parts will run about $40.00 and about 2 or 3 hrs to replace the bushings, lubing can be done with a needle fitting or you can tap the grease holes and install zerks just remember to remove the zerks after lubing
My 88 auto with 31s at 65 I'm doing about 2750, at 3000 rpm I'm doing around 70
I've found it's easier to siphon the gas out of the jerry can to the filler neck
some beautiful wheeling in New Mexico, I'm sure you;ll love it when you get there. OH and :welcome:
yeah and he lives on the cold and foggy side of the hill :rofl:
if you have any probs with the 4x4 emblems sticking use 3M molding tape the stuff with the red backing I get mine from NAPA
looks nice I see my 2 old ones in the center. Don't pay any attention to your gas mileage now that they're up there, it's like a little brick wall on top of a big brick wall
A little bit of what I've been up to lately
vagabond replied to unccpathfinder's topic in General Forums
Been planning on doing this to my 88, just looking for the right salvage vehicle -
and I complain went it hits 40, I also complain when it hits 110
I don't remember what year but prob somewhere in the late 80s early 90s, but the later models were plastic with 2 fans but they were wider. The ones I installed on my 88 and 94 were both metal shrouds with 2 fans and fit the radiator almost perfect. My laptop is all messed up. Try going to photobucket and looking at dosvagabonds check the mods for electric fan I've got a bunch of pathy stuff stored there
88 SE had cruise
the way I did mine was the metal maxima fan, the temp sensor in the bottom of the maxima radiator and the fitting that it screws into, I used the metal tube that's in the tbi units upper hose and soldiered the sensor fitting into the metal tube, and a switch on the dash for the high speed fan. On tbi units you can drill a hole below the vent on the metal tube, on the mpfi I just ground off the vent and drilled out the hole to fit the sensor fitting. I'm running both my 88 and my 94 this way
When I was still at Pacific Nissan We'd get Nissans that had been partially submerged, we'd strip them down and let carpet and and interior dry and install a new eccu, You'd be suprised how many of the old eccus would still work after drying out I was able to salvage a radio out of a 88 hardbody the the lifeguards had submerged, when I got the truck in my stall you could see where the water line was half way up the instrument cluster. I pulled the radio and pulled the top and bottom covers and rinsed it out in hot water, took it home that afternoon gave it a soapy bath and rinse. A week later it was working even the cassette player. Sheesh the ramblings of an old man, see what all you young guys have to look forward to
You'll prob need a puller for the crank vibration dampner
Taurus fans, Maxima fans both work. The Max fan fits the rad almost perfect if you use the older style with the metal tubing on it, just notch it a bit to clear the gearbox. The Taurus fan is a single 2 speed fan, the max fan is a dual fan setup
we did a 2500 mile trip last Oct in the 88 and averaged a little over 17 per tank on the road, 1 tank we got 17.8. We left So Ca went to Grand Junction Co to Gallup Nm to Laughjin Nv, then the Barstow area where we playedl in the desert for 3 days
One thing to remember when bleeding brakes start from the corner furthest from the master cyl. and work towards the master cyl.
We're kind of sheltered up close to the hills, it;s been about 3 years since we;ve had frost here. I think the lowest temp so far this year was about 35 F
