Rebelord
Everything posted by Rebelord
  1. I daily drove a Detroit Tru Trac for years in my 2001 Z28. Break away on that was very tight, as close to full spool as possible. So, a tight LSD or locker wont bother me much.
  2. I wont be able to pull it for a couple of weeks. Depending on cost for new clutch packs. Might be cheaper to yank a open from a yard and put a lunch box locker. Sent from my Moto X!
  3. Yes people im not naive. Its the MOBIL 1 75W-80 LSD OIL. Factory came with LSD by vin verification at dealer. Plus still has its orange sticker. Sent from my Moto X!
  4. Mobil 1 75W-90 Synthetic. Fresh. During my trip. Even tried that e-brake trick. Nope, was one wheel wonder even in slick mud.
  5. Title says it all. Its not working at all. Is it worth it to rebuild it to try to make it tighter? Only other option is to opt for a air locker. Unless I can find a open diff and convert to a mechanical locker of sorts. Ideas?
  6. If it happens when a trailer is hooked up. Check the ground on the trailer wiring. Sent from my Moto X!
  7. Put it through the paces at a off road park. A separate thread to follow. Teaser pic:
  8. Clear as in routed correctly in stock locations to not pinch em. Doing them the first time is the worst only because you need to remove the strut assembly to change the upper mount bolts. But put in some some 2" ones. So that way if you want to go bigger, its easier.
  9. ^^^ With everyone above. Buy back rate? Looks like you have quite a bit you could salvage off of it for the new rig. Or even part out to make back buyback+ some $$$.
  10. Sounds like you got some good answers. I made my post as from my manual for my 99 just states Matic-D Sent from my Moto X!
  11. Dex 3? Nissan transmission take Nissan Matic-D. Not Dex 3. Outside of the dealership Castrol Multi Import is the only one my dealer will honor warranty with. There are two import fluids. Get the correct one for Nissan. Hopefully Towncivillian or Alkorhahil or Precise1 can chime in Sent from my Moto X!
  12. Probably half the cost is the bag. But I like the ideas being thrown out so far. Military first aid training: From simple stuff to emergency trauma. Can summarize in a few steps: Stop the bleeding. Start the breathing. Treat for shock. Evac. The one thing that I have noticed that is NOT in some of these kits. Is a simple splint. But that last one has a SAM Splint in it.
  13. Here's the supply list for that Grizzly kit: Supply List Bandage Materials 3 Dressing, Gauze, Sterile, 2" x 2", Pkg./2 2 Bandage, Conforming Gauze, 3" 1 Bandage, Elastic, Self Adhering, 2" 3 Dressing, Gauze, Sterile, 4" x 4", Pkg./2 7 Bandage, Adhesive, Fabric, Knuckle 2 Dressing, Non-Adherent, Sterile, 3" x 4" 9 Bandage, Adhesive, Fabric, 1" x 3" Bleeding 1 QuikClot Sport 25g 1 Trauma Pad, 5" x 9" 1 Instructions, Easy Care Bleeding 2 Gloves, Nitrile (Pair) 1 Trauma Pad, 8" x 10" Blister / Burn 14 Moleskin, Pre-Cut & Shaped (11 pieces) CPR 1 Instructions, Easy Care CPR 1 CPR Face Shield, Laerdal Duct Tape 1 Duct Tape, 2" x 50" Fracture / Sprain 1 Instructions, Easy Care Fracture & Sprain 1 Bandage, Elastic with Clips, 2" 1 Bandage, Elastic with Velcro, 2" 2 Bandage, Triangular Instrument 3 Thermometer, Disposable 1 EMT Shears, 4" 3 Safety Pins Medical Information 1 Comp. Guide to Wilderness & Travel Medicine Medication 5 Ibuprofen (200 mg), Pkg./2 4 Antihistamine (Diphenhydramine 25 mg) 4 Diamode (Loperamide HCI 2 mg), Pkg./1 4 After Bite Wipe 2 Aspirin (325 mg), Pkg./2 1 Instructions, Easy Care Medications Wound Care 1 Instructions, Easy Care Wound 1 Syringe, Irrigation, 20 cc, 18 Gauge Tip 8 After Cuts & Scrapes Antiseptic Wipe 1 Dressing, Petrolatum, 3" x 3" 1 Wound Closure Strips, 1/4" x 4", Pkg./10 4 Triple Antibiotic Ointment, Single Use 2 Skin Tac Topical Adhesive Wipes 1 Tape, 1" x 10 Yards 1 Cotton Tip Applicator, Pkg./2
  14. I was looking at the Adventure Medical Kit Grizzly http://www.amazon.com/dp/B008CZZVB8/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=A8W0WR2YLBTF&coliid=I2T06BET26ZX2F Plus order a few pouches of QuickClot. That stuff works miracles. I take for granted the first aid training I have from the military. But yes, I do need to make sure if I am the one down. Others can help.
  15. Lets get a good discussion going on First Aid kits for off road adventures. Personally I am looking to either get a nice kit or build one. Right now, I only have a very basic kit; band aids, creams, few gauzes. But need something better. Your thoughts?
  16. Heres a question. What is the part number of the Nissan LSD additive? Sent from my Moto X!
  17. Yes. Tri spokes. 16x7 Sent from my Moto X!
  18. There was one guy that got some from Japan. But they were for lowering it though. Do a search and it'll pop up Sent from my Moto X!
  19. Good guys. Lots of help on their forums. Plus if your close to them in Florida you can go by their shop and they provide help. They are only a hour up the road from me. So its easier for me to get odd colors from em. Sent from my Moto X!
  20. Also plausible that it could have been rebuilt with a few extra plates to tighten it up. Sent from my Moto X!
  21. Plausible. But with the way our diffs are setup would be alot of work. Also possible that the truck could have had a original open diff and someone put in one the the detroit or other style locker in it. Id say give your vin to Akorahil or Towncivilian to run and see if they can see stock options. Otherwise get a gasket set and remove your diff and inspect it to see what's up. Sent from my Moto X!
  22. If its not releasing completely it possibly sticking shut. Also possible that your drivers side is barely working. Sent from my Moto X!
  23. Did my DIY skid. Pics i members ride thread. Click the link in my sig... Sent from my Moto X!
  24. From what I have read. Its probably the angle. What seems to be common is to run without the strut spacers for a few months or 2k miles or so. To let the front springs settle in, then install the spacers and you should be good to go. Otherwise, could try a different CV axle.
