Rebelord
Everything posted by Rebelord
  1. At least with Amazon. Call them up in the morning and they should be able to cross ship you the correct whiles while you send those back to them.
  2. Search man, plenty of threads on this subject.. On subject, 32" will be a very tight squeeze. But 31" should be no issues.
  3. Being that the plate looks European, it may be a modded Land Rover or Land Cruiser rack. (Thinking of their popularity overseas, compared to the US for offroading.)
  4. Dont recall. But have you done a leak down test? Sent from my Moto X!
  5. No, not really. Only good for light road spray that makes it way up there. But if the fan hits some water and throws water everywhere. Then its getting soaked.
  6. The Nissan dealer near me charges $99 for diagnostic. But if you have them repair it, that $99 goes towards the cost of repair.
  7. The IAC is under the TB, IIRC. Sent from my Moto X!
  8. Not from a retail company. You'd have to make it custom. Even then the retail snorkel is for a non US/Canada R50. So you still have to mod. Sent from my Moto X!
  9. It would greatly negatively affect it. Want to see how? If you have the filter already, try to breath through it and take a shower at the same time. There you go. Remember, just because your not up the filter in water doesnt mean it wont get wet. Once you hit water or something as deep as the lowest part of the fan. The fan will start tossing that water all around like a water wheel.
  10. WJ springs with the adapter piece. The F250/350 shocks are used because they are longer and allow the proper flex and dont limit the rear end articulation. Front, your stuck with stock length struts and springs of your choice. Plus strut spacers.
  11. Same lift as us 4wd guys. Springs for 1-2", strut/spring spacers for any extra. 4wd we are limited by CV angle. You could probably push it being 2wd.
  12. The main risk is that if the drive shaft is left in place, and a freak movement happens the Pathfinder can suddenly be in gear. Which will in turn break a whole lot of parts. Like the Transfer case, transmission, rear end. On top of it trying to self drive itself off the dolly into everything in its path. If you are going to haul it that far. I would just rent the U-haul flat drive on hauler. Why? Because it has surge trailer brakes. Those brakes on the trailer will make towing it 10000% easier than on a dolly. Especially when you start hitting the canyon and hill parts. Its safer, and easier overall for the whole experience. The only time I even use dollys is if I am only towing local, within 20miles or less. Farther, spend the extra $20 for a flat hauler. Just go with the flat hauler. It will save you time and more headache along the way offsetting the extra cost.
  13. I can attest that the Cooper STT are excellent mud tires. Sent from my Moto X! now Free
  14. Thats the Hayden that I run, that I installed in my thread. Was even thinking of getting a second one and running them in series then back to the tranny.
  15. Thats the same symptoms I had when my dizzy went out. Would be great on cold start up, and once warmed up. Was fine at idle. But anything over 2k. Nope, bumpy ride.
  16. Your golden. No worries. Oh, Install a Transmission Cooler! This is the one that I run, works awesome. Click Me --> Hayden 689
  17. You can try cleaning everything up and seeing how it reacts. ? Didnt someone on here replace the upper bearing in a distributor recently? Thought I read a thread on it. Either way, Amazon the distributors are cheaper, and if you want just certain components; Ebay.
  18. Quite possible. I think with lift springs its more along Your Mileage May Vary (YMMV). Stock springs I was still sitting at 33" front, 34" rear. So I didnt gain much. Yes, I looked back up the OME and they are stated at 1.75" using the spring packers, aka lil spacer. So, 2" is very easy for them as you stated. Thorpe991: If you want to run 33". Then just do a sub frame drop. With springs only, I believe you will still rub and will need to do trimming. But doing a quick search on this forum can provide many threads about trimming. Most just have to trim or used a heat gun to reshape the plastic fender liner and bumper part. Only a few that I remember have trimmed metal. But some have and had excellent results.
  19. ^^^ Excellent post. I have used Isopropyl Alcohol. Which is great for cleaning micro components in a PC also.
  20. 1600 lb trailer, heavy on the tongue. Pull this nearly daily from 50miles to 300+ miles. *Note, does not sag as much now with the IronMan springs in the rear, plus tows and tracks much better.
  21. Put in the 93. Because down here, the 93 is the only one that truly gets injected with Techron at the distribution point at the port. The 87 gets about 1/4 as much. I know this, because I calibrate the meters that move the additives and fuels at the port. *But I did not say this, cannot be held accountable in court of law.
  22. ^^^ What everyone said plus check your distributor. Pull the cap, rotor and the plate that covers your module and coil and look for any erroneous grounding or bad ju ju.
