27
Everything posted by Rebelord
Should be. But you'll need the whole console assembly. Sent from my Moto X!
^^^^ that too. Makes a difference. I hear you on the ABS throwing you off. Learned to drive in a 1980 GMC K25 long bed. Then drove a '81 Malibu for 8 years till I bought my first car with ABS. After that been a believer in it. Sent from my Moto X!
If your sliding with ABS, you'll slide without. Plus with ABS at least when it pulses you still retain some steering ability. Now, if your ABS kicks in everytime you brake. Either your always applying the brakes to late and to hard, or there may be a fault. However it would have to be a fault of it sensing faster wheel spin that what is actual. If you still have a hard time, I would suggest finding a open area to purposely engage and it and learn to steer with it. Also, check to make sure your LSV is adjust properly. Could be out which is causing excessive force to front brakes and not enough to rear. (My truck on the other hand, doesnt seem to want to engage it but at the very extreme only. Which I have had to do only a few times; go go Miami traffic.)
Probably.
WHY? Why would you want to disable the ABS?
My low light works sometimes. But I have only pushed it that far maybe 4 times. Either way, I think my sending unit is all wonky. The needle can be on the E, no light. Go to fill it up and only takes 16.5 gallons. Where in theory should be closer to 20.
have you taken it to a gas station to fill it up to see if you are indeed empty? If it takes ~15 gallons after your five, then its a save bet. Plus remember, running out of fuel can burn up your fuel pump. It uses the fuel to keep cool.
You can do a spectra filter. Same thing half the cost. Sent from my Moto X!
They used be out west somewhere Sent from my Moto X!
8+ months waiting time. Even after asking for full payment. Shoddy quality and poor craftsmanship. Just Google TAG and Kennasaw Sent from my Moto X!
TAG aka Kennasaw Offroad etc doesn't have the greatest history with them. Sent from my Moto X!
Keep us updated on the TAG bumper. Interested to see "how" it turns out.
Replacement control arm bushing, or replace entire assembly?
Rebelord replied to Fergie's topic in 96-2004 R50 Pathfinders
For parts, this thread: http://www.nissanpathfinders.net/forum/topic/18653-genuine-nissan-parts/ I would replace the bushings with the polyurethane ones. But you will need a press to do them. If your just going with a shop, find a good one that can do them. Otherwise, you can just replace the whole assembly, which will be good itself for another 100k or so. -
Possible to roll the fender lip? Sent from my Moto X!
Thinking about painting my pathy with 3m bedliner
Rebelord replied to reelserenity's topic in General Forums
Why bed liner? From seeing plenty of cars and trucks plastic dipped. I think its a much better option. Sent from my Moto X! -
Theexbrit. Look to the right of your brake booster. Diamond in shape. Youll see it. On the inside its a pain to get to but doable Sent from my Moto X!
Another thing to do. Is if you are in 4 Low, drop down to First gear. Dont stay in Drive with or even without OD on. 1st or 2nd should be plenty. Again, unless your in something really slick like snow, mud. To much skinny pedal breaks stuff.
IronMan springs and 1" spacers here. No issues. However the IronMans are pretty much identical to OME as far as spring lift. Here it is on 1/2 worn 31" Cooper STT. For perspective, the white JK in the picture is on 4" springs, 2" body lift and 35" tires.
Those that do run the AC coils and spacers. Usually didnt put the spacers in until a few months later when the coils would settle. Those that did put them in right off the bat. Usually have had some sort of CV angle issue. Which was resolved by removing the spacer until the springs had some time to settle down.
With the prices Alkorahil posted. What I'm going to do first is drop the diff. Take a good look at it. Take some measurements and see if I can just replace and re arrange it to have Friction Disk - Plate - Disk as much as I can to tighten it up. If not, then totally not worth the money to mess with the stock stuff. Just find a open from a junker and put in a PowerTrax for less than 500 or go all out to a ARB locker.
Pig Mats is a common petroleum absorbent pad. http://www.newpig.com/pig/US/absorbents-503/pig-universal-absorbent-mats-504 Other companies make em too. Ive called the white ones "diapers" for years. Because they resemble old school cloth diapers.
About the only thing to try is if a tire shop will mount some to test fit. Maybe a Discount Tire store, 4 Wheel Parts place. Maybe even a used tire dealer might help you out.
Towncivilian: I have read that thread. Thats why I think it will be easier on my end to rebuild it if possible. By making sure its setup as: Friction Plate - Friction Disc as much as I can and eliminate any Friction Disk - Disk spots. At one point this weekend, if the rear would have been tighter. I could have made it out of a hole easy. But got stuck being it went into basically 2 wheel drive. Left front, right rear...
Jeep XJ bumper. Have to lightly mod the mounting brackets and it pretty much fits. Maybe turn out or cut and side turn in. Look up theexbrit for his posts and threads on it.
