Rebelord
Everything posted by Rebelord
  1. That sums it up. I haven't checked but is the Xterra getting the axe? As long as they refresh the Frontier nicely and it comes with a diesel. Then that may be my next vehicle. Sent from my Moto X
  2. That's barely 17k miles. Hmm. Which strut bearing did you put in? Wonder if one cracked Sent from my Moto X
  3. They are top notch. Fleury takes a lot of pride in his work. Sent from my Moto X
  4. I might get AV chance to look into it this weekend. But do have a big project already planned. Sent from my Moto X
  5. Correct. With your hubs unlocked your CVs wont be rotating at speed. Which brings up fleurys' post.
  6. Oh..what about the one member that got the Tien coilovers from Japan that was trying to sell em after his Pathy got totaled? Might be a old archived For Sale post. But may be able to be dug up for a email address?!?
  7. If he had 1" spacers before. Yes. Sent from my Moto X
  8. Wow. That is the most you'd ever see a luxury large car go off road. I hate calling those SUV. They have no sport, no utility to them. Sent from my Moto X
  9. Back on topic. Karmann. Dont you have unlockable hubs? If so that should rule out CVs and the diff bushings. If you don't. Then I would check your CV axles. Whats to say that creap of a mechanic didnt tighten em down or seat the hub and bearings right. Especially when he did the LCAs. Sent from my Moto X
  10. I found most of the feedback about em on the diesel forums. Like anything else good and bad. But for my truck it was $60 for both rears and $80 for both fronts. Plus at Autozone they give you a limited lifetime warranty. So if one blows a seal etc then I can just swap it out locally. Sent from my Moto X
  11. If you cant get the KYBs I picked up the Gabriel Ultra at Autozone. Good price and they have taken towing abuse and off road like Champs! Sent from my Moto X
  12. H&R makes lowering springs. Sent from my Moto X
  13. I need some power sockets in the rear cargo area. Two would be best. Is there a good fused or just a solid power feed back there somewhere? I can inline fuse it. Also brands in solid retrofit sockets. Was thinking of putting them above where the rear amp is. Thanks in advance Rebelord Sent from my Moto X
  14. ^^^ What he said. If you don't have the factory bracing from originally having a OEM one. Way to much work. You have to fab in the correct braces and such that tie into the structural part of the body. With no actual room constitutes cutting of the body to make a hole..yadda yadda. Better and cheaper to fab a rear bumper with a swing out.
  15. Are those 2" ones? Brave man with the AC springs already. I take it you werent to happy with the AC spacers? I got them also, yea, sucky.
  16. Not sure. But does NAPAAutozone/Advanced Auto sell short or long blocks of our engines? May be a way to go. They're all done by Jasper. Last I checked.
  17. They are where hands do not fit well. Get it up in the air on jack stands and you'll see. Most of the work will be dis assembly and re assembly of parts on the front of the truck. But with good light you'll be able to see them and inspect them. IF you do decide to replace them. Then that would be a good time to either install a air locker or go ahead and put in a Lokka locker up front. Lokka is the US name for a Aussie or Lunch box locker. http://lokka.com/site/
  18. Ironman springs; the rears are setup to hold 440lbs over stock. Fronts give about 35mm of lift. Progressive rate type of spring. OME have a MD and HD setup. Not sure on spring rate. Progressive rate type of spring. AC springs are the stiffest of them all. Does provide a full 2" of lift. But are extremely stiff and hard until broken in.
  19. I have always loved those older Alpine units. Well today. Got it dirty and COMPLETELY blew out the seals on my rack and pinion. Was able to get it home. However its toast. I have to replace it. Good news? Since it spit out all the fluid, its basically flushed itself and I can move to ATF now!
  20. Overdrive IS the converter locking up. Sent from my Moto X
  21. IIRC they are rebadged MM ones. They are also pretty popular on Ebay.
  22. Thats just the converter locking and unlocking. Especially when towing. Down here in South Florida we dont have hills. But the highways overpass near every single road they cross. So its a lot of up and down up and down. The 826/Palmetto is the worst of em.
  23. Didnt you just go through a bunch of hassle with the mechanic that did that work to your truck? I would check out your front bearings. Especially if he pulled the half shafts to replace the lower control arms. You can also swap front with rear tires. See if it goes away or follows. Then you know its a tire balance issue.
  24. Those All-in-one Cobra's work pretty good. Lots of my Heep buddies have them down here.
