41
Well than you shouldn't have replied ! If you have nothing to add to my question be silent !!
Anyone that has used seafoam does it do anything to the oil? change the color or anything?
So today my mech. buddy started working on the truck, last week he hooked the radiator back up and filled the cooling system and performed a pressure test after letting the truck warm up , he ran it about an hour, never over heated, temp was normal, he said it never lost pressure so he determined the head and head gasket were ok. I was thinking the oil had to be coming from the timing chain wearing through the front cover. He drained the oil and it did look milky, removed the oil pan and got about another quart of oil out of it. He said the oil did not drain out completely through the drain plug because the broken pieces of the timing chain guide was blocking the hole. Removed the valve cover and said the oil under the cam looked good, no signs of water mixed with it. Remove the front cover, oil was clean at the crank area also. Removed the water pump and other than being all rusty,. probably from PO using straight water it was just water, no signs of oil There was a wear mark on the inside of the front cover but it had not worn all the way through. No idea where the oil and water mixed, starting to think someone put water in the oil, don't know. He said the truck started fine and he drove it into his shop, he said it has a slight tick but it may go away. Tomorrow he will start cleaning everything and said maybe Sunday he will have it back together and running. The brake booster I bought looks identical to the one that is in the truck, did not see the inside of the stock one yet to compare but the under hood parts look the same. He's going to replace the complete timing set, water pump, thermostat, oil pan and valve cover gaskets, PVC valve and possibly the oil pump. Weird there is no sign of where oil mixed with the water, when the water pump was removed it was pure water that came out. Have to wait a few more days and should see how it runs, he also said the truck looked clean ( he had it on his lift and was the first time either of us had seen under it, he said it's definitely a Florid a truck and the PO had spent a lot on all the new parts.
What does the XE stand for on 1991 Pathfinder model #
ahardb0dy replied to Captain_Crazy's topic in General Forums
I don't think ST means anything for a pathfinder, no idea why the Vin number comes up like that, some older Nissan pickups I know were labeled ST -
First thing to check is with the truck running and the AC turned on see if the clutch on the AC compressor is turning, if not you may be low on freon, to check this without gauges find the low pressure (dual pressure switch) usually near the accumulator/drier, unplug the connector, should be 2 wires (2 terminals) jump the 2 terminals with a paper clip or piece of wire, if the clutch engages you most likely are low on freon. Also check any of the AC hoses for oily residue on them near the crimp on fittings, because the AC system uses freon and oil, usually a leak is easy to spot as the oil collects dirt , also check any metal AC lines, my sentra the clutch cable was rubbing on a metal AC line and wore a hole into it one time. The bulb being out in the switch may just be the bulb and may not indicate the AC system is out, as far as I know the lamp not coming on does not indicate the AC is not working, it just lets you know the switch is on. Good luck
Welcome to NPORA , we like to see pics !
Quirks of my new-to-me Pathy & what to do about them..
ahardb0dy replied to Roo's topic in 90-95 WD21 Pathfinders
i just did a write up on removing the alarm in the general section, look at that if you want to remove it, if you want to keep it, you may need a new fob programmed as was said. -
Welcome to NPORA !!! A good rule to follow when ever purchasing a used car/truck/boat what ever is you have no idea when any maint. was last done so plan on doing it all as soon as possible. The timing belt as was mentioned is a very big thing, if it decides to snap while idling in your driveway or going down the road in the middle of no where, either way means new engine. There is no warning, no squeak or squeal it will just break. Change the oil and filters since you don't know when they were last done, you don't need to do everything at once just make a plan to do it. Download the free service manual from the garage section, read it, get to know it, you WILL use it. Unless you plan to pay the dealer a fortune. If you didn't get the owners manual they can be found online for free too, again read through it, you may find something you didn't know your pathfinder can do. welcome again, enjoy your stay !!
If it's a factory alarm do you want to remove it completely or just disable the alarm? To remove, the harness they used is pretty cool design, most of the connections are like "tee's", basically you unplug a connector, plug each end you just unplugged into the alarm plug, there are only I think 2 single wire connections, one goes to the wire that runs to the front door switch, one connects under the steering column cover. the rest plug in, So basically to remove the alarm, pull the drivers seat, unplug the alarm module, remove the module, remove the mounting bracket, trace the harness back up under the lower dash, un plug any connections going to the alarm "tee's", plug the male and female plugs back together, remove the wire from under the steering column cover, remove the wire going to the dr. door switch, and you should be good. To disable, unplug the alarm module, locate the ignition kill wire under the steering column cover cut the red wire going to the alarm harness and re connect the 2 halves. this was my alarm out of the 94 I had and the harness, is this the box you unplugged? alarm module in place (red button on top in hole) see also here for the schematic and instructions: http://www.nissanpathfinders.net/forum/topic/19755-fix-your-keyless-entry/?hl=keyless%20entry&fromsearch=1
not sure if they all do it or not but the headrests (fronts) that were in my 94 have a ratchet feature to change the angle.
I'm 48 and I rock out with my two 12's LOL
was going to say if one hose feels hot and the other doesn't than the thermostat isn't opening, if your heat goes hot to cold sometimes than you have air in the system and need to open the air relief screw to bleed it out.
like that one !!
The way I look at it, if you going to do a BL might as well do the 3". Now if someone asks what's involved in doing the Trailmaster 4" suspension ( if you could find one !) I have the instructions for that.
Glad you figured it out.
There is a bunch of stuff behind the rear side panels, I'm sure you could move it out of the way, there is also a brace right in the middle, I'm sure you could have something built that wouldn't stick out to far past the fenderwell, you could even have part of the box protrude into the cavity behind the panel, as I mentioned earlier to match the volume needed by the sub. Here is a pic of the drivers side from my former 94 PF:
I think if you want to maximize floor space you will have to mount the subs to the side panels behind and over the wheel wells, you may need to stretch the box to an irregular shape to keep the internal volume appropriate for the sub you are using, Not really any room under the seats. or move some stuff around inside the rear side cargo area's and do something like this, this box for reference not saying to get this one or this brand: http://www.crutchfield.com/p_236FEX10TN/MTX-ThunderForms.html?tp=113 kind of like this, this is a newer pathfinder but same idea:
Welcome, when my cruise wasn't working in the 94 I had it was the vacuum hose to the actuator, than the steering wheel contacts started acting up but i fixed that
Going to have to create a Hardbody section pretty soon on here !
What am I getting myself into? Advice needed.
ahardb0dy replied to RedRider3141's topic in 86.5-89 WD21 Pathfinders
I had the Warn hubs on my old 94 pathfinder, never took it 4 wheeling but I bought them from a junkyard, when I took them apart I needed a few parts, I e-mailed Warn and told them what I needed and that I bought them from a junkyard, they didn't care that i bought them used, the guy replied asking what I needed, I told him and they sent the parts out for free !! Not many companies will stand behind their products like that, especially when it's not even the original purchaser. Customer service like that will make me buy Warn again. I Don't know if Milemarker would do the same. -
HEY I know you !! LOL Welcome to NPORA !!! The 93 HB I just bought has the red interior too.
Was going to say try the cruise with the jumper wire in place of the switch you think is bad and see if it works
I used semi mud flaps also on my 87 hardbody but I installed the bolts from the inside of the inner fenders sticking out, one washer and nut on the bolt to hold the bolt tight, than the rubber semi flap than a flat washer and another nut, this way if you want to remove the rubber for whatever reason, the bolts stay in place. For the front bumper brackets I just doubled them up on each side, still flimsy but better than using one per side
There is a small vacuum pump next to the that diaphragm, if the cruise is not being told to turn on the pump will not produce vacuum and you will not feel it on the hose, it shouldn't have vacuum on that hose unless all the conditions are met for the cruise to work, ex. driving above 40 mph, see this thread for more info on the cruise not working: http://www.nissanpathfinders.net/forum/topic/38266-94-se-4x4-pathfinder-cruise-control-help/
well if you have only one bumper it must be for your brake lights otherwise the lights would always be on and I think you would notice that, if there is one missing, guess what one it is for ! LOL Good luck
