ahardb0dy
  1. where does the tube run for the rear windshield washer fluid? I mean where it comes into the truck and runs to the rear? i see it coming thru a grommet inside the fender liner and I think I can feel it inside the kick panel but from there I lose it, does it run along the floor or above under the edge of the headliner?
  2. it seemed to have fixed the leak on mine, haven't had any really hard rain lately but I hosed the area where I did before and I didn't see any water inside the cab.
  3. well today I tried pressing on each setting of the shock switch and pushing down on the rear bumper and I can say now that I can def. feel a difference between sport and comfort !! What a difference sport makes. Well at least I know they work so the light in the switch must be out. thanks
  4. went to the junkyard yesterday, picked up 2 resistors, one out of a older hardbody pickup, and one out of a 95 pathfinder, got home and tried both of them and they both work fine, so I left the newer one installed, also picked up the 2 heater hoses, so now I have all fan speeds and heat, and the AC comes on but still needs to be charged. Still need that hard to find glove box latch!!!
  5. was under the truck yesterday, all the shocks are the factory adjustable type, I pushed down on the rear bumper and the rear of this truck moves up and down very easily, didn't notice if it kept bouncing after I stopped
  6. just hosed down the windshield area and around the door and on the fender to check to see if leak is still there, checked inside after wetting each spot and did not see any water !! Might have got it, going to wait until after a heavy rain before I say it's 100% fixed. Ok here is a pic of where I saw the water leaking from:
  7. shocks are the adjustable type, it's not a big deal if the switch doesn't work, I'll probably replace them with a normal set eventually. In my 87 Hardbody, don't know about now but back in the day when they first came out Rancho did not make the 3 way adjustable shocks for the fronts of the Nissan pickup or pathfinder's, but the funny thing was that Gabriel ( who made the shocks for Rancho at the time) had the 3 way adjustable shocks for the fronts of the Nissan trucks, and those are the ones I had in mine, plus the Gabriel's came with urethane bushings, the rancho's they were seperate.
  8. I'm going to try to take a picture of that bracket so more people can have an idea what we are talking about, for now I put some silicone in the lower corner of the windshield trim, tomorrow I'm going to hit it with the hose again to see what happens, if it still leaks I'll pull the fender and cowl off this weekend to investigate more, thanks for the reply.
  9. I'll probably end up buying a new one they seem pretty cheap, I was just wondering if there was a seal that could be replaced without taking the hole thing apart, thanks
  10. I'm going to grab some switches next time I hit the junk yard, I took the pass. side front switch apart as it would go down but would not go up every time, just taking the switch apart and pressing on the copper contacts made the window work fine. The pass. rear window went down ok but than was dead, I had no power anywhere at the switch or the harness. I than took the drivers side front switch apart and even jumping the pass. side lock with a screwdriver and trying to operate the pass. rear window I got nothing.
  11. just realized I posted this in the wrong section, can a moderator move this please? thanks
  12. ok, went out before and ran some water down over the windshield, water started coming in and running down onto the pass. floor, looked under the dash with a flashlight and see where water is coming in from, still not sure how it is getting in though. there is a bracket that mounts the AC/heater box ?? it is up on the curved part of the floor I guess it is the inner fender, water is coming out from under the top part of this "U" shaped bracket. Also noticed in the lower corner of the windshield there is what appears to be a gap under the trim, no idea if this is where the water is coming in from but I applied some silicone under the trim, after it dries I will try the water test again, and hope fully that was the leak. My truck has a sunroof, we ran water down the drains and it exited out under the truck, no sign of water inside when we did this.
  13. thanks, going to hose it down again after I eat dinner
  14. thanks I'm going to pick up a new resistor in 2 weeks I just can't understand how 3 coils of wire that is in the resistor can fail ??
  15. 94 Pathfinder, I was checking all the power windows and got to the pass. rear, it rolled down fine from the door switch but than wouldn't go back up or down or anything, took the switch apart and tried to make it move by pressing on the contacts, ( as i just finished doing on the pass. front window switch which worked), anyway nothing by pressing the contacts, so I pulled the door panel and checked the connectors going to the switch and the one going to the window motor, nothing no power anywhere, couldn't figure out the FSM diagram so I ended up running a positive and negative directly to the battery and finally got the window to roll back up. So now I have a new problem, any idea where else to check on this? Thanks
  16. I can totally agree that removing the whole fan switch assembly is a royal pain in the butt !! i pulled one out of a pathfinder at the junkyard and with the other 3 sliders all using cables it doesn't want to move at all when you attempt to pull out the assembly. My fan is doing the opposite as yours, only working on 4 anbd hopefully all it will be is the resistor.
  17. I used to have a dual remote mount filter on my 87 hardbody, had it mounted below the pass.side door, but I def. agree a body lift solves any problems in removing the oil filter. Also makes removing the starter much easier too.
  18. I did a search but didn't see anything, is there a thread some where on swapping the auto trans for a manual trans on the WD21 pathfinder?
  19. So any difference in how the steering feels using the manual box instead of the idler arm? Just to be clear on this, you used a manual steering box and a power steering pitman arm to replace the idler arm? I guess you had to drill one hole for the upper left bolt and you had to slot the upper right hole? Other than trimming the bumper bracket and relocating the power steering hose everything else was a bolt on? Thanks
  20. my master cylinder must be leaking into the booster, mechanic filled resovior today than when I went to pick the truck up it was low again, no sign of fluid anywhere on the ground, truck has 4 wheel disc brakes, he said I probably need a new master cylinder and that the fluid is probably leaking into the brake booster, does anyone know if there is a seal I can just replace? I'm on a budget right now and can't afford to replace the master at this time, thanks
  21. I'm pretty sure they still are the adjustable shocks but will double check in a few minutes, thanks
  22. The fan switch only works on the highest setting (#4), tried cleaning the switch with spray from outside, removed the resistor behind the glove box, and took it apart, all it has are 3 coils of wire which from research I did last night just lowers the voltage to the fan motor depending on what fan speed you select. I can't see how this resistor (3 coiled wires) can go bad, I cleaned it and re-installed it and still only have fan on setting 4. Is there something else that controls the fan? Any idea what to check next? THANKS
  23. 94 Pathfinder, I'm getting water on the pass. floor after it rains, I had to remove the carpet and padding from in front of the pass. seat as it was shot from water damage. When I first noticed the water it looked like the water was coming out of the main harness, I removed the factory tape on the harness and spread the wires out to dry, a day later I re-taped it up. I used a garden hose to see where the water was coming in from, both sunroof drains are working properly, the grommet for the door wires on the body side was not in properly and I fixed that but water still is getting in. We thought the water was coming into the outside air intake under the wiper cowl and I removed the plastic cover over it and put some RTV on the edge of the plastic and re-secured it using a few extra screws so it is held down more securely, but still getting water inside. Going out today to see if I can see any daylight from under the dash. I know it is not from the heater core as it is not even connected right now, and it can't be from the AC as the AC doesn't work yet. Anyone have any other places where I can look? THANKS
  24. Hello, just picked up this 94 pathfinder from a co-worker, I had a JDM engine swapped in and am trying to sort out some problems. This post is about the switch for the adjustable shocks. I doubt the shocks even still work as they are probably original, my friend wasn't known to be real good on doing maintenance on this truck. Anyway, I'm not getting anything when I press the rocker switch either way, it's possible a bulb in the switch may be out and will check that today but I removed the switch from the harness and am not getting any power at any of the terminals on the harness side. Anyone ever experience this problem? THANKS
