adamzan
Moderator
Everything posted by adamzan
  1. At least it wasn't like mine. There was a poor attempt at fixing it in there as well...You can see the expanding foam they put in the void on the left. A memeber here fixed the whole in the floor but it had moved into the structure of the body, so it cost me 500 dollars to have it all fixed.
  2. I have a question though, why does everyone say put the a/c on max? On my truck the a/c is either on or off.
  3. 93 And up pathfinders have the 134a stuff. Mine doesn't have a "sight glass" either. Maybe that is only on the old r12 systems?. Also that port in your last picture is the one you top it up from. the one in your first picture is the high pressure line, don't mess with that baby! Also if it gets cold, then I wouldn't worry about topping it up.
  4. there is supposed to be one there. Mine has one. that's why when I had a hole, bigger than yours, my carpet didn't feel warm at all.
  5. In your picture the one on the left is the output.
  6. Here is the post that you are looking for, I think. http://npora.ipbhost.com//index.php?s=&amp...st&p=120943 Also, I think the tranny has a breather line that runs either up under the hood or into one of the frame cross members.
  7. adamzan
    4 Issues
    Damn that sucks bro.
  8. You better knock on wood. The last time I said that to my friend my alternator died a week later (it had been screaming like a starving crack baby for months though).
  9. It's really starting to bother me that it's not working, because every time I drive this thing, when not going to school, it's always highway. It's weird, everything seems to be all hooked up right, the steering wheel controls are making contact and all that, the brake switch is working, the actuator tests good, the computer i swapped from a known working one in another 95, still no go. Also replaced the blue relay on the passenger side and it clicks when you turn the main switch on but the damn cruise won't set. Should I just bring it to a mechanic? (don't really want to)
  10. You have the tensioner on the wrong way. The straight part of the spring is supposed to be hitting that little stud that is to the right of the tensioner in your picture.
  11. Thats what happened when my alty died. It would only charge above 2500 rpms
  12. Mine used to do something like that in the winter, when my alternator was going. It kept going in and out of torque lock or w/e it's called.
  13. What? that is the same one in each pic in my sig. I don't have 3 pathys
  14. Spray some wd40 on it, I had to do that on my other pathy. Damn it was annoying.
  15. You are becoming a collector lol.
  16. Maybe something to do with your rear brakes?
  17. You might get lucky calling around, some dealers still have stuff in the back just sitting there.
  18. Oil transmission differentials (front and rear) transfer case do them all
  19. Well it is only like 155hp to begin with. But mine can make it up inclines with ease. You probably need a tune up. I would start there. New plugs, wires, cap, rotor, oil and filter change, fuel filter change, air filter change or put a K&N filter in it, check the o2 sensor because if it is bad it can make the truck lose power as well. Also change the pcv valve.
  20. I tried to find a new alternator and could around here. I had to settle for a reman. But I got a reman nissan one, not champion or any of those garbage ones.
  21. I hit 283,000kms the other day. Won't hit 284 for a while yet.
