adamzan
Moderator
Everything posted by adamzan
  1. I think the mistake was jamming the bolt in with an impact gun without cleaning up the thread with s tap first. Hopefully the new bolt isn't ruined.
  2. The only time my truck sputtered and ran rich enough to emit black smoke was when the 02 sensor died. And I did not get a code.
  3. I have honestly never broken anything while offroad. The only thing I did do was not pay attention while driving through some tall grass and smash my bumper and fender in... I got stuck more once my truck was lifted and had better tires because I got cocky and thought it could go anywhere. To be totally honest, I had the most fun with my pathy when it was stock
  4. I have just the fender antenna on mine and my fm reception is poor even with an aftermarket head unit. My old rig with both antenna was much better.
  5. I have the same unit. You don't need that adapter. Its just the harness that hooks the cd part up. All you need to do is get a harness adapter for 94 nissan from the parts store and your aftermarket radio will plug right in. You may also need the antenna adapter if you have the two prong antenna connection.
  6. You don't need to pull the timing covers to do the thermostat. Just the ac idler bracket.
  7. If you need a timing light I bought one for around 10 dollars at princess auto. If you have one nearby.
  8. If you want super comfy get monroe sensa tracs.
  9. Make sure it is grade 10.9 and not 8.8. Metric 8.8 is equivalent to standard grade 5.
  10. you can see a ton of rust holes in the side of the frame. probably why they used it for that in the first place.
  11. My dads 00 had one...I thought it was cool but I don't miss it at all in my wd21.
  12. My buddy still has my old rad I gave him to scrap. I will go and see if I can take it apart! It is an aftermarket, metal tank type though.
  13. I'm interested in doing this as well. Let us know what you end up going with and how you hook it up. Apparently the 1st gen xterra has one too so that could be an option.
  14. http://www.nissanpathfinders.net/forum/topic/18653-genuine-nissan-parts/page-36?do=findComment&comment=666009 Just post in that thread or PM him.
  15. If someone wrote wash me in the dirt on my car I'd shoot them.
  16. Mine dings when you have the key in or lights on with the door open. But it beeps on start up with the seat belt light...
  17. For the price rock auto sells a new rad support for I would not waste my time pulling a used one. But that's me. They're like 50 buck's
  18. Check your vacuum lines, coolant temp sensor and the oxygen sensor. The fsm has the specs in the ef or ec section I believe.
  19. There is supposed to be separate parts. Its so if you lose one side or the front or back line (i don't remember) you still have something to stop with.
  20. Turn the fan to off it shuts it off.
  21. While it is quite expensive, the oem part will last another 20 years while the aftermarket one will probably only last you 5 at the most before the boots tear. I went with lifetime warranty rebuilt ones, as the new aftermarkets didn't seem to fit right.
  22. As long as your AC compressor is not cycling on and off (keep it off the defrost and defrost/foot mode) it will not affect MPG.
