adamzan
Moderator
Everything posted by adamzan
  1. What a hack job! I hate fixing other people's rigged fixes. Luckily for me the PO of mine replaced the entire sending unit with a new one from nissan, So hopefully I won't have to worry about that for a while. Also I would change out that worm gear hose clamp for a proper fuel injection one.
  2. I have seen a lot of wd21s,and they have all had the same looking tank as mine. I found the dimensions of the replacement tank I bought: spectra premium tank: 34-3/8" x 20-3/4" x 11-3/4" I'll measure my factory one that's in the scrap pile tomorrow when I get home. I just put 70 liters of gas in it yesterday, that is where the pump stopped at. I am sure the after market ones are labeled wrong.
  3. Link to hoohaa CL: http://www.grassroots4x4.com/index.php?page=shop.browse&category_id=3&option=com_virtuemart&Itemid=1&vmcchk=1&Itemid=1
  4. ^ this. I enlarged some of the holes on the bottom of my frame slightly. You wouldn't believe the crap that came out after that. Find something that will fit in the frame holes for the pressure washer.
  5. Yes it was the same size. My gas light comes on, and the truck took 65 liters before the pump shut off and I was able to squeeze 70 in there, just like before I changed the tank... I haven't got around to measuring mine, been busy. I'll do it tomorrow. 15 gallons would suck. That is terrible range.
  6. Must be something that happens in the heat down there, I've never seen that here.
  7. It says in the manual that it is ok to downshift like that "when engine braking would be advantageous", their words, not mine! I still never do it because why wear the tranny more than necessary when brakes are dirt cheap to change. Only time I do it is on steep trail descents in 4 low.
  8. I have my old 21 gallon tank that I just replaced, I can measure it if you want.
  9. I have seen it done before. It is quite the job, you need to press or hammer the bearings off and there is a lock nut that you can use a hammer and punch to loosen IIRC.
  10. 80mph wow there is your problem lol. I go like 70 max but the highest speed limit here is 100km/h which is around 62mph
  11. Yup, they do that pretty much every time I cross to go shopping even. But the guards at the one near me are complete assholes.
  12. It seems fine, it's been on my truck since I've owned it, and the previous owner was a member here. It has been on there at least 5 + years. The cheapest route, of course is to get a used one somewhere.
  13. Rockauto has glass replacement ones. I have a tyc brand one on mine and it is glass. Looks just like stock.
  14. That's the new york road rage in you flooring it everywhere
  15. Just watch out how high you raise the front end. Without the proper control arms it is hard to get the camber in spec. You wind up with your front tires like this \ / if you look at the truck from the front.
  16. After the headers, I built my own like nefarious. I went to crappy tire and bought cheap bends and welded them together. I still have the stock tailpipe but I haven't had time to finish it yet. I'm using a dynomax muffler. I actually find it fairly quiet. I thought it was going to be louder lol. Does sound like a v8 at idle though which is kinda sweet.
  17. You only need to replace the rods if they've worn through badly.
  18. Rockauto.com has new tanks pretty cheap. I recently bought one, no issues at all.
  19. The poor man's lift is jeep grand Cherokee coils in the rear, and cranking the torsion bars in the front. You can crank them up to a point without needing new control arms. The coils you can get at a junkyard or just buy new ones if you can't find any. A good set of 31" AT tires will probably be your best addition. I recommend the BFGoodrich all terrain.
  20. You could try welding a nut to it and see if it will turn out, if you have access to a welder. That has worked for me on a few things.
  21. Fwiw they are warrantied the same here. Good luck with the tank. I actually lucked out and my frame is mint back there.
  22. Take the rear bumper off, I did, made it a whole lot easier.
